Illegal domain partition
rduran
#1 Unread post by rduran »
Can someone help me understand what I need to do:
if i try running:
./oceanS < ./User/External/RomsInit_03_Jul1.in
I get this error:
Tile partition information for Grid 01:  0000x0000x0000  tiling: 001x001
        0        1        0        1        0        0
 INP_PAR - domain decomposition error in input script file for grid:  1
           The domain partition parameter, NtileI =   1
           is incompatible with grid size, Lm =    0
           because it yields too small tile, Istr =   1  Iend =   0
           Decrease partition parameter: NtileI
 Thread #  0 CPU:       0.045
 Total:                 0.045
                                              Total:         0.000    0.0000
 All percentages are with respect to total time =            0.045
 ROMS/TOMS - Partition error ......... exit_flag:   6
 ERROR: Illegal domain partition.
Rodrigo.
Re: Illegal domain partition
You are missing the "Lm == xxx" and "Mm == xxx" lines from your /User/External/RomsInit_03_Jul1.in. Please compare it to say ocean_upwelling.in to make sure you have everything you need.
rduran
#3 Unread post by rduran »
This is what I have put in my .in file:
! these parameters correctly.
          Lm == 248            ! Number of I-direction INTERIOR RHO-points
          Mm == 294            ! Number of J-direction INTERIOR RHO-points
          N == 31            ! Number of vertical levels
In matlab I would have a variable for a rho point with dimensions:
31x296x250
But for some reason it is not reading the dimensions right I get similar error:
Tile partition information for Grid 01:  0248x0000x0000  tiling: 001x001
        0        1      248        1        0        0
           The domain partition parameter, NtileJ =   1
           is incompatible with grid size, Mm =    0
           because it yields too small tile, Jstr =   1  Jend =   0
           Decrease partition parameter: NtileJ
 Thread #  0 CPU:       0.018
 Total:                 0.018
                                              Total:         0.000    0.0000
 All percentages are with respect to total time =            0.018
Any suggestions?
thanks,
Rodrigo.
Do you have a tab on the line for Mm? You have somehow prevented ROMS from parsing that line.
rduran
#5 Unread post by rduran »
Yes there was a tab, thanks.
