Why are so much circulation?
free
#1 Unread post by free »
When i run a model, I don't know Why are so much circulation?
Who can help me?
#define UV_ADV		/* advection terms */
#define UV_COR		/* Coriolis terms */
#define UV_VIS2		/* harmonic horizontal mixing */
#define UV_LDRAG		/* linear bottom friction    */
#undef  UV_QDRAG   	/* Use quadratic bottom drag law...but no waves*/
/* tracers equations */
#define TS_MPDATA	/* recursive MPDATA 3D advection */
			/* need a positive-definate advection scheme for sediment */
#define TS_DIF2		/* harmonic horizontal mixing */
/* pressure gradient algorithm */
#define DJ_GRADPS	/* splines density Jacobian (Shchepetkin, 2000) */
/* model configuration */
#define SPLINES		/* parabolic splines reconstruction of vertical derivatives */
#define SPHERICAL 	/* analytical spherical grid */
#undef AVERAGES
#undef DIAGNOSTICS_TS	/* writing out tracer diagnostics */
#undef DIAGNOSTICS_UV	/* writing out momentum diagnostics  */
#define STATIONS	/* writing out station data to file */
/* horizontal mixing of momentum*/
#define MIX_S_UV	/* mixing along constant S-surfaces */
/* horizontal mixing of tracers*/
#define  MIX_GEO_TS	/* mixing along geopotential (constant depth) surfaces */
/* NetCDF input and output*/
#define OUT_DOUBLE	/* Double precision output fields in NetCDF files*/
/* boundary conditions*/
#define NORTHERN_WALL
#define SOUTHERN_WALL
#define WESTERN_WALL
#undef EW_PERIODIC
#define ANA_M2OBC
#define ANA_FSOBC
#define ADD_FSOBC
#define ADD_M2OBC
#define EAST_M3RADIATION
#define EAST_TGRADIENT
/* define UV_TIDES to specify boundary tidal currents from data e.g. ADCIRC */
/* define UV_TIDES to compute tidal currents using reduced physics */
#define RAMP_TIDES	/* ramping (over one day) tidal forcing */
#define SSH_TIDES       /* read tidal SSH     from file */
#define EAST_FSCHAPMAN
#define UV_TIDES        /* read tidal U and V from file */
#define EAST_M2FLATHER
#undef UV_PSOURCE
#undef Q_PSOURCE
#undef TS_PSOURCE
/* sediment transport model */
#undef SEDIMENT
#ifdef SEDIMENT
# define SED_MORPH
# define SED_DENS
# define SUSPLOAD	/* suspended load transport */
# undef  BEDLOAD_SOULSBY
# define  BEDLOAD_MPM
#ifdef SEDIMENT
#undef ANA_SEDIMENT
/*bottom boundary layer closure */
#undef  MB_BBL
#undef  SG_BBL
#undef  SSW_BBL
/* vertical mixing of momentum and tracers */
#define MY25_MIXING
#ifdef MY25_MIXING
# undef  CANUTO_A
#define ANA_SMFLUX
#define ANA_STFLUX
#define ANA_SPFLUX
#define ANA_SSFLUX 	/* analytical surface salt flux defaults to zero */
#define ANA_BPFLUX	/*bottom passive tracers fluxes */
#define ANA_BSFLUX 	/* bottom temp flux...defaults to zero */
The log file:
 Process Information:
 Thread #  0 (pid=       0) is active.
 Model Input Parameters:  ROMS/TOMS version 3.4
                          Tuesday - January 18, 2011 - 10:44:20 AM
 ZHANJIANG Model
 Operating system : CYGWIN
 CPU/hardware     : i686
 Compiler system  : gfortran
 Compiler command : /usr/bin/gfortran-4
 Compiler flags   : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none
 SVN Revision  : 510:527M
 Local Root    : /cygdrive/e/ROMS/CASE/NEW/trunk
 Header Dir    : /cygdrive/e/ROMS/CASE/NEW/trunk/ROMS/Include
 Header file   : zhanjiang_1225.h
 Analytical Dir: /cygdrive/e/ROMS/CASE/NEW/trunk/ROMS/Functionals
 Resolution, Grid 01: 0218x0238x016,  Parallel Threads:  1,  Tiling: 001x001
      28800  ntimes          Number of timesteps for 3-D equations.
      5.000  dt              Timestep size (s) for 3-D equations.
         10  ndtfast         Number of timesteps for 2-D equations between
        360  nRST            Number of timesteps between the writing of data
                               into restart fields.
                               to standard output.
        360  nSTA            Number of timesteps between the writing of data
                               the stations file.
        360  nHIS            Number of timesteps between the writing fields
                               into history file.
 2.0000E+01  nl_tnu2(01)     NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for tracer 01: temp
 2.0000E+01  nl_tnu2(02)     NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for tracer 02: salt
 1.0000E+01  nl_visc2        NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for momentum.
 1.0000E-06  Akt_bak(01)     Background vertical mixing coefficient (m2/s)
 1.0000E-06  Akt_bak(02)     Background vertical mixing coefficient (m2/s)
                               for tracer 02: salt
 1.0000E-05  Akv_bak         Background vertical mixing coefficient (m2/s)
 1.0000E-05  Akk_bak         Background vertical mixing coefficient (m2/s)
                               for turbulent energy.
 1.0000E-05  Akp_bak         Background vertical mixing coefficient (m2/s)
 2.0000E-02  Zob             Bottom roughness (m).
          1  Vtransform      S-coordinate transformation equation.
          1  Vstretching     S-coordinate stretching function.
 5.0000E+00  theta_s         S-coordinate surface control parameter.
 4.0000E-01  theta_b         S-coordinate bottom  control parameter.
      1.000  Tcline          S-coordinate surface/bottom layer width (m) used
      0.000  tide_start      Reference time origin for tidal forcing (days).
20101105.00  time_ref        Reference time for units attribute (yyyymmdd.dd)
 2.0000E+00  Tnudg(01)       Nudging/relaxation time scale (days)
 2.0000E+00  Tnudg(02)       Nudging/relaxation time scale (days)
                               for tracer 02: salt
 2.0000E+00  Znudg           Nudging/relaxation time scale (days)
 2.0000E+00  M2nudg          Nudging/relaxation time scale (days)
 2.0000E+00  M3nudg          Nudging/relaxation time scale (days)
                               for 3D momentum.
 2.0000E+01  obcfac          Factor between passive and active
     12.000  T0              Background potential temperature (C) constant.
     35.000  S0              Background salinity (PSU) constant.
             Output History File:  ocean_his.nc
            Output Stations File:  ocean_sta.nc
                 Input Grid File:  Data/ROMS/Grid/zhanjiang_grd.nc
    Input Nonlinear Initial File:  Data/ROMS/Initial/zhanjiang_ini.nc
          Station positions File:  ROMS/External/stations_zhanjiang.in
 Tile partition information for Grid 01:  0218x0238x0016  tiling: 001x001
        0        1      218        1      238   830144
   (interior points only)
        0    -0.50   220.50    -0.50   240.50  RHO-points
        0    -0.50   220.50    -0.50   240.50    U-points
        0    -0.50   220.50    -0.50   240.50    V-points
 Stations Parameters, Grid: 01
          7  Nstation        Number of stations to write out into stations file.
          T  Sout(idFsur)    Write out free-surface.
          T  Sout(idUbar)    Write out 2D U-momentum component.
          T  Sout(idVbar)    Write out 2D V-momentum component.
          T  Sout(idUvel)    Write out 3D U-momentum component.
          T  Sout(idVvel)    Write out 3D V-momentum component.
          T  Sout(idWvel)    Write out W-momentum component.
          T  Sout(idOvel)    Write out omega vertical velocity.
          T  Sout(idTvar)    Write out tracer 01: temp
          T  Sout(idTvar)    Write out tracer 02: salt
             Flag and positions for station 0001:  0    78.0000  143.0000
             Flag and positions for station 0002:  0    67.0000  133.0000
             Flag and positions for station 0003:  0    71.0000  144.0000
             Flag and positions for station 0004:  0    81.0000  135.0000
             Flag and positions for station 0005:  0    84.0000  145.0000
             Flag and positions for station 0006:  0   104.0000  145.0000
             Flag and positions for station 0007:  0   105.0000  145.0000
 ZHANJIANG_1225      ZHANJIANG Model
 ADD_FSOBC           Adding tidal elevation to proccesed OBC data.
 ADD_M2OBC           Adding tidal currents to proccesed OBC data.
 ANA_FSOBC           Analytical free-surface boundary conditions.
 ANA_M2OBC           Analytical 2D momentum boundary conditions.
 ANA_SMFLUX          Analytical kinematic surface momentum flux.
 ANA_SSFLUX          Analytical kinematic surface salinity flux.
 ANA_STFLUX          Analytical kinematic surface temperature flux.
 EAST_FSCHAPMAN      Eastern edge, free-surface, Chapman condition.
 EAST_M2FLATHER      Eastern edge, 2D momentum, Flather condition.
 EAST_M3RADIATION    Eastern edge, 3D momentum, radiation condition.
 EAST_TGRADIENT      Eastern edge, tracers, gradient condition.
 MIX_GEO_TS          Mixing of tracers along geopotential surfaces.
 MY25_MIXING         Mellor/Yamada Level-2.5 mixing closure.
 NORTHERN_WALL       Wall boundary at Northern edge.
 OUT_DOUBLE          Double precision output fields in NetCDF files.
 RAMP_TIDES          Ramping tidal forcing for one day.
 SOUTHERN_WALL       Wall boundary at Southern edge.
 SPHERICAL           Spherical grid configuration.
 SSH_TIDES           Add tidal elevation to SSH climatology.
 STATIONS            Writing out station data.
 TS_MPDATA           Recursive flux corrected MPDATA 3D advection of tracers.
 UV_LDRAG            Linear bottom stress.
 UV_TIDES            Add tidal currents to 2D momentum climatologies.
 WESTERN_WALL        Wall boundary at Western edge.
 Vertical S-coordinate System:
 level   S-coord     Cs-curve          at_hmin  over_slope     at_hmax
    16   0.0000000  -0.0000000           0.000      -0.000      -0.000
    15  -0.0625000  -0.0048948          -0.063      -0.119      -0.175
    14  -0.1250000  -0.0119914          -0.125      -0.263      -0.401
    13  -0.1875000  -0.0230908          -0.188      -0.453      -0.719
    12  -0.2500000  -0.0409944          -0.250      -0.722      -1.194
    11  -0.3125000  -0.0696342          -0.313      -1.114      -1.916
    10  -0.3750000  -0.1133185          -0.375      -1.680      -2.984
     9  -0.4375000  -0.1742175          -0.438      -2.443      -4.449
     8  -0.5000000  -0.2489214          -0.500      -3.366      -6.232
     7  -0.5625000  -0.3284417          -0.563      -4.344      -8.125
     6  -0.6250000  -0.4042644          -0.625      -5.279      -9.933
     5  -0.6875000  -0.4744488          -0.688      -6.150     -11.612
     4  -0.7500000  -0.5437741          -0.750      -7.010     -13.271
     3  -0.8125000  -0.6205544          -0.813      -7.957     -15.101
     2  -0.8750000  -0.7145184          -0.875      -9.101     -17.327
     1  -0.9375000  -0.8366254          -0.938     -10.569     -20.201
     0  -1.0000000  -1.0000000          -1.000     -12.513     -24.025
 Time Splitting Weights: ndtfast =  10    nfast =  15
  1 0.0014850648765542 0.1000000000000000 0.0014850648765542 0.1000000000000000
  2 0.0059386031399402 0.0998514935123446 0.0074236680164944 0.1998514935123445
  3 0.0133457074936657 0.0992576331983506 0.0207693755101601 0.2991091267106951
  4 0.0236484051180389 0.0979230624489840 0.0444177806281990 0.3970321891596791
  5 0.0366959666818608 0.0955582219371801 0.0811137473100598 0.4925904110968592
  6 0.0521753389587947 0.0918886252689940 0.1332890862688545 0.5844790363658532
  7 0.0695217010484137 0.0866710913731145 0.2028107873172682 0.6711501277389678
  8 0.0878091442019233 0.0797189212682732 0.2906199315191915 0.7508690490072409
  9 0.1056214752525633 0.0709380068480808 0.3962414067717548 0.8218070558553218
 10 0.1209031436506851 0.0603758593228245 0.5171445504224399 0.8821829151781463
 11 0.1307902921035067 0.0482855449577560 0.6479348425259466 0.9304684601359023
 12 0.1314219308195445 0.0352065157474053 0.7793567733454911 0.9656749758833076
 13 0.1177312353577226 0.0220643226654509 0.8970880087032138 0.9877392985487585
 14 0.0832169680811588 0.0102911991296786 0.9803049767843727 0.9980304976784371
 15 0.0196950232156274 0.0019695023215627 1.0000000000000000 0.9999999999999999
 ndtfast, nfast =   10  15   nfast/ndtfast = 1.50000
    1.000000000000 1.083803072626 0.541901536313 1.000000000000 1.000000000000
 Power filter parameters, Fgamma, gamma =  0.28400   0.00000
 Minimum X-grid spacing, DXmin =  1.93639455E-01 km
 Maximum X-grid spacing, DXmax =  6.04239487E-01 km
 Minimum Y-grid spacing, DYmin =  2.68942210E-01 km
 Maximum Y-grid spacing, DYmax =  7.28061065E-01 km
 Minimum Z-grid spacing, DZmin =  6.25000000E-02 m
 Maximum Z-grid spacing, DZmax =  3.82426846E+00 m
 Minimum barotropic Courant Number =  1.22495929E-02
 Maximum barotropic Courant Number =  4.45839358E-02
 Maximum Coriolis   Courant Number =  5.32083094E-04
                   (File: zhanjiang_ini.nc, Rec=0001, Index=1)
                - free-surface
                - u-momentum component
                - v-momentum component
                - potential temperature
                   (Min =  2.24573922E+01 Max =  2.27319504E+01)
                - salinity
                   (Min =  3.41531521E+01 Max =  3.41673488E+01)
    GET_NGFLD   - tidal period
                   (Min =  4.30819210E+04 Max =  9.67262421E+04)
    GET_2DFLD   - tidal elevation amplitude
                   (Min =  5.73345254E-02 Max =  5.85054670E-01)
    GET_2DFLD   - tidal elevation phase angle
                   (Min =  1.36518644E+00 Max =  5.21264685E+00)
    GET_2DFLD   - tidal current inclination angle
                   (Min =  1.11310007E-05 Max =  6.28318263E+00)
    GET_2DFLD   - tidal current phase angle
                   (Min =  1.71641227E-03 Max =  6.28239915E+00)
    GET_2DFLD   - maximum tidal current, ellipse major axis
                   (Min =  9.59182533E-03 Max =  1.28520087E-01)
    GET_2DFLD   - minimum tidal current, ellipse minor axis
                   (Min = -1.56127638E-02 Max =  7.50047868E-03)
 Maximum grid stiffness ratios:  rx0 =   2.088082E-01 (Beckmann and Haidvogel)
                                 rx1 =   3.468923E+00 (Haney)
 Initial basin volumes: TotVolume =  3.4728667676E+10 m3
                        MinVolume =  3.8897822161E+03 m3
                        MaxVolume =  1.6160127023E+06 m3
                          Max/Min =  4.1545068915E+02
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00028800)
      0     0 00:00:00  0.000000E+00  5.585238E+01  5.585238E+01  3.817329E+10
      DEF_HIS   - creating history file: ocean_his.nc
      DEF_STATION - creating stations file: ocean_sta.nc
      1     0 00:00:10  1.090756E-16  5.585238E+01  5.585238E+01  3.817329E+10
      2     0 00:00:20  5.301220E-11  5.585239E+01  5.585239E+01  3.817329E+10
      3     0 00:00:30  1.836297E-10  5.585240E+01  5.585240E+01  3.817330E+10
      4     0 00:00:40  3.694276E-10  5.585241E+01  5.585241E+01  3.817330E+10
      5     0 00:00:50  6.179113E-10  5.585243E+01  5.585243E+01  3.817331E+10
      6     0 00:01:00  9.592319E-10  5.585244E+01  5.585244E+01  3.817331E+10
      7     0 00:01:10  1.431474E-09  5.585247E+01  5.585247E+01  3.817332E+10
      8     0 00:01:20  2.067357E-09  5.585249E+01  5.585249E+01  3.817333E+10
      9     0 00:01:30  2.888218E-09  5.585252E+01  5.585252E+01  3.817334E+10
     10     0 00:01:40  3.905421E-09  5.585255E+01  5.585255E+01  3.817335E+10
     11     0 00:01:50  5.125385E-09  5.585258E+01  5.585258E+01  3.817336E+10
     12     0 00:02:00  6.554275E-09  5.585261E+01  5.585261E+01  3.817337E+10
     13     0 00:02:10  8.200629E-09  5.585265E+01  5.585265E+01  3.817338E+10
     14     0 00:02:20  1.007634E-08  5.585269E+01  5.585269E+01  3.817340E+10
     15     0 00:02:30  1.219682E-08  5.585273E+01  5.585273E+01  3.817341E+10
     16     0 00:02:40  1.458062E-08  5.585277E+01  5.585277E+01  3.817343E+10
     17     0 00:02:50  1.724820E-08  5.585282E+01  5.585282E+01  3.817345E+10
     18     0 00:03:00  2.022000E-08  5.585287E+01  5.585287E+01  3.817346E+10
     19     0 00:03:10  2.351452E-08  5.585292E+01  5.585292E+01  3.817348E+10
 ROMS/TOMS: DONE... Tuesday - January 18, 2011 -  8:56:44 PM
The topo:
The zeta:
The ubar:
The vbar:
free
Re: Why are so much circulation?
#2 Unread post by free »
Who can help me ?
Thank you very much!
#3 Unread post by kate »
So you have some kind of tidal forcing? Do you expect tidal resonances in your domain? I'm not sure what it is you are concerned about.
