Hello every body!
Using ROMSTOOLS, I ran a simulation with FLOATS using the original Benguela example. The steps I followed to do so were:
- To define FLOATS and RANDOM_WALK in the cppdefs.h file
- make_grid, *_forcing, pathfinder_sst, make_bulk, and *_clim
- ./jobcomp
- ./roms roms.in
The compilation and simulation ran without problems, so I decided to make a simulatión with FLOATS but now for a Pacific Ocean region.
Once the model configuration successfully simulated the region (without floats), I:
- define FLOATS and RANDOM_WALK in the cppdefs.h
- ./jobcomp
However, during the compilation ocurred and error. The last part of the error is:
read_inp_.f(493): error #5082: Syntax error, found ',' when expecting one of: <END-OF-STATEMENT> ;
nrpfflt="nrpfflt",nrpfflt
read_inp_.f(491): warning #6043: This Hollerith or character constant is too long and cannot be used in the current numeric context. ['ldefflt']
ldefflt="ldefflt",ldefflt
read_inp_.f(493): warning #6043: This Hollerith or character constant is too long and cannot be used in the current numeric context. ['nrpfflt']
compilation aborted for read_inp_.f (code 1)
make: *** [read_inp.o] Error 1
mv: cannot stat `roms': No such file or directory
So, I can't run simulations with FLOATS for my study area.
Do I have to define something else in the cppdefs.h, param.h, roms.in, or floats.in files?, or what else do I have to change?
¿Can you help me with this please?
Thank you in advance, and best regards!!!!
Julio Lara
FLOATS: compiling error
Re: FLOATS: compiling error
It is telling you exactly what the error is and which line of code. I would check read_inp_.f and see what's going on there. Can you see what's wrong and fix it?jul10lara wrote:read_inp_.f(493): error #5082: Syntax error, found ',' when expecting one of: <END-OF-STATEMENT> ;
Note that the error seems to be for code that's different from the myroms.org code, so perhaps there's a better place to report bugs in it than here.
Ok Kate
I'll check the file
Thank you very much and best regards!
I'll check the file
