Problems with Sediment Applications
carniel
#1 Unread post by carniel »
I think there is a bit of confusion under the Wiki page for Sediment Applications.
https://www.myroms.org/wiki/index.php/Test_Cases
This is probably due to some not correct synchronization beten the WIKI pages and the ROMS release. However, since it is all "out there", I think we should harmonize this.
Point 1
If you click on TEST_CHAN casem there are no pages linked to.
If you click on SED_TEST1, you have back a rather exaustive page of explanations.
However the page describes a domain of 10000x1000 m, while in the ana_grid.h file it appears that the grid sizes are 300x36x10 meters, and in the *.in file we have 100x12x10 grid points.
It seems therefore that the documentation shown for SED_TEST1 is not the correct one
(maybe it is the one originally emplyed for TEST_CHAN?)
Point 2
If it is so, i.e. if the link currently valid for SED_TEST1 should be directed for the case TEST_CHAN, it would be nice, if possible, to have better described the 2 different simulation carried out, since it is not really clear in the corresponding cppdefs.h file what is used for Sim. 1 or Sim. 2 in the current release.
Point 3
Assuming that SED_TEST1 case comes with no documentation, then, I would be interested in getting some lines of documentation on this (I volunteer to contribute together with the "father" of the case) since I find this a vey instructive test case.
Namely, it would be nice to discuss the kind of B.C. adopted. The case as it is released runs for a very limited time period (1000 time steps having 1 sec of integration, i.e. around 16 minutes). This is more than enough to show ROMS potentialities, and if you run it longer, say 2 hours, the model seems to hold together with no problems.
Re: Problems with Sediment Applications
Sandro-
This page:
https://www.myroms.org/wiki/index.php/SED_TEST1_CASE
is really the test_chan case and should be
https://www.myroms.org/wiki/index.php/TEST_CHAN_CASE
do you want to email Dave Robertson and ask to have it changed? Also, that app is described in our paper:
Warner, J.C., Sherwood, C., Arango, H., and Signell, R. (2005). “Performance of Four Turbulence Closure Models Implemented Using a Generic Length Scale Method.” Ocean Modelling, v. 8/1-2, p. 81-113.
and should be referenced. I am not sure if it is set up for case 1 or 2. if u run the code and compare results to the figures it should be obvious. I think the worst scenario was with MY25 depending on how the length scale was imposed.
The sed_toy test case does not currently have any demanding functionality. It was set up to test 1D sed applications, such as waves, Erate, etc. But it is open for modifications. I think we could just keep it basic, and tell people that it is available for easy modification to test 1D functionalities.
carniel
#3 Unread post by carniel »
jcwarner wrote:Sandro-
This page:
Dear John,
thanks for your prompt answer. Concerning the last point, tough, I was *not* referring to SED_TOY (the 1-D case), but to SED_TEST1. Indeed in herelease, besides SED_TOY, we do have 2 distinct cases, SED_TEST1 and TEST_CHANNEL. The 2 tests seem somehow similar in the release, but not quite for size and BCs. That is why I was suggesting to add some lines of documentation. Or maybe there are no reasons to have both of them?
thanks
Sandro
