Found the answers hehe:
my Err...My inifile. Recently i create a new one with the ocean_time variable fixed to a value =1 (ncks).
So if u have a file with :
double ocean_time ;
ocean_time:long_name = "time since initialization" ;
ocean_time:units = "days since 1968-05-23 00:00:00 GMT" ;
double salt(ocean_time, s_rho, eta_rho, xi_rho) ;
salt:long_name = "salinity" ;
salt:time = "ini_time" ;
salt:coordinates = "lon_rho lat_rho s_rho" ;
and try to run with MPI with more than 1x1 tiles, u get an error with mpiBcast.
But, if u do a ncecat in the ifle them:
double ocean_time(record) ;
and this will work.
I think this is still a bug (
), because u can run with both configurations in Serial,OpenMP, but not in MPI, and there is no warning for the lacks of dimension.
The error with the debug flag:
At line 198 of file get_state.f90
Fortran runtime error: Array reference out of bounds for array 'mytime', upper bound of dimension 1 exceeded (1 > 0)
Fortran runtime error: Array reference out of bounds for array 'mytime', upper bound of dimension 1 exceeded (1 > 0)At line 198 of file get_state.f90
additionally, in the search of this bug i think i have found another one:
When running with OpenMP and Tiles the "TotVolume" output in the stdout changes ( with grep):
Ok, all the numbers r in the same magnitude, but I was using the default flags of the gfortran compiler in the ROMS folder, i was expecting the exact value, right?. Maybe this is not the only field that ahve diferent calculations with the default flags
Below the output of Totalvolume:
Without Tiling in OpenMP:
Trynumber = 2
Initial basin volumes: TotVolume = 5.2601331615E+14 m3
Trynumber = 3
Trynumber = 4
Trynumber = 5
Trynumber = 6
Trynumber = 7
Trynumber = 8
Trynumber = 9
Trynumber = 10
Trynumber = 11
Trynumber = 12
Trynumber = 13
Trynumber = 14
With Tiling in OpenMP:
Trynumber = 2
Initial basin volumes: TotVolume = 3.7050210981E+14 m3
Trynumber = 3
Trynumber = 4
Initial basin volumes: TotVolume = 2.2462582921E+14 m3
Trynumber = 5
Trynumber = 6
Trynumber = 7
Trynumber = 8
Trynumber = 9
Trynumber = 10
Trynumber = 11
Trynumber = 12
Trynumber = 13
Trynumber = 14
Initial basin volumes: TotVolume = 4.5740565073E+14 m3
Trynumber = 15
With Tiling in MPI:
Trynumber = 2
Trynumber = 3
Trynumber = 4
Trynumber = 5
Trynumber = 6
Trynumber = 7
Trynumber = 8
Trynumber = 9
Trynumber = 10
Trynumber = 11
Trynumber = 12
Trynumber = 13
Trynumber = 14
Trynumber = 15
