changed some water grid into land grid,the model blow up
fanzhongya
#1 Unread post by fanzhongya »
hello everyone
I had a problem.Please help me.THANKS!
I run a real case in Changjiang Estuary.The model can run well in pictureI and pictureII.However,only changed some water grid into land grid as described in pictureIII,the model blow up abnormally.
the record file as followed:
Process Information:
Node # 0 (pid= 7529) is active.
Node # 2 (pid= 7524) is active.
Model Input Parameters: ROMS/TOMS version 3.2
Thursday - June 24, 2010 - 11:01:58 AM
Node # 5 (pid= 7526) is active.
Node # 3 (pid= 7523) is active.
Node # 14 (pid= 4698) is active.
Node # 30 (pid= 28175) is active.
Node # 12 (pid= 4695) is active.
Node # 26 (pid= 28173) is active.
Node # 25 (pid= 28174) is active.
Node # 7 (pid= 7528) is active.
Node # 16 (pid= 6493) is active.
Node # 8 (pid= 4693) is active.
Node # 10 (pid= 4692) is active.
Node # 22 (pid= 6499) is active.
Node # 9 (pid= 4691) is active.
Node # 1 (pid= 7522) is active.
Node # 19 (pid= 6495) is active.
Node # 20 (pid= 6497) is active.
Node # 24 (pid= 28170) is active.
Node # 23 (pid= 6500) is active.
Node # 11 (pid= 4694) is active.
Node # 21 (pid= 6498) is active.
Node # 18 (pid= 6496) is active.
Node # 15 (pid= 4696) is active.
Node # 31 (pid= 28177) is active.
Node # 17 (pid= 6494) is active.
Node # 4 (pid= 7525) is active.
Node # 13 (pid= 4697) is active.
Node # 28 (pid= 28172) is active.
Node # 27 (pid= 28171) is active.
Node # 29 (pid= 28176) is active.
Node # 6 (pid= 7527) is active.
Yangtz River Estuary
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /usr/mpi/intel/mvapich2-1.2p1/bin/mpif90
Compiler flags : -ip -O3 -xW -free
Input Script : ./cjk_in/cjk0402.in
SVN Revision : 347M
Local Root : /export/home/pxding/fan/cjk
Header Dir : ./ROMS/Include
Header file : cjk.h
Analytical Dir: /export/home/pxding/fan/cjk/ROMS/Functionals
Resolution, Grid 01: 0270x0232x010, Parallel Nodes: 32, Tiling: 004x008
57600 ntimes Number of timesteps for 3-D equations.
60.000 dt Timestep size (s) for 3-D equations.
5 ndtfast Number of timesteps for 2-D equations between
F LcycleRST Switch to recycle time-records in restart file.
129599 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
60 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
1440 nAVG Number of timesteps between the writing of
14400 nDIA Number of timesteps between the writing of
1.0000E+01 tnu2(01) Horizontal, harmonic mixing coefficient (m2/s)
1.0000E+01 tnu2(02) Horizontal, harmonic mixing coefficient (m2/s)
for tracer 02: salt
0.0000E+00 visc2 Horizontal, harmonic mixing coefficient (m2/s)
2.5000E-06 Akt_bak(01) Background vertical mixing coefficient (m2/s)
2.5000E-06 Akt_bak(02) Background vertical mixing coefficient (m2/s)
for tracer 02: salt
for turbulent energy.
0.000 gls_p GLS stability exponent.
1.000 gls_m GLS turbulent kinetic energy exponent.
1.000 gls_n GLS turbulent length scale exponent.
5.0000E-06 gls_Kmin GLS minimum value of turbulent kinetic energy.
5.0000E-06 gls_Pmin GLS minimum value of dissipation.
5.5440E-01 gls_cmu0 GLS stability coefficient.
9.0000E-01 gls_c1 GLS shear production coefficient.
5.2000E-01 gls_c2 GLS dissipation coefficient.
2.5000E+00 gls_c3m GLS stable buoyancy production coefficient.
1.9600E+00 gls_sigk GLS constant Schmidt number for TKE.
1.9600E+00 gls_sigp GLS constant Schmidt number for PSI.
0.0000E+00 rdrg Linear bottom drag coefficient (m/s).
0.0000E+00 rdrg2 Quadratic bottom drag coefficient.
3.0000E-04 Zob Bottom roughness (m).
5.0000E-01 Dcrit Minimum depth for wetting and drying (m).
6.0000E-06 theta_s S-coordinate surface control parameter.
1.0000E+00 theta_b S-coordinate bottom control parameter.
0.000 Tcline S-coordinate surface/bottom layer width (m) used
1024.000 rho0 Mean density (kg/m3) for Boussinesq approximation.
20040120.00 time_ref Reference time for units attribute (yyyymmdd.dd)
for tracer 02: salt
for 3D momentum.
Output Restart File: cjk_in/Output/cjk_rst.nc
Output History File: cjk_in/Output/yz_0402_4_his.nc
Output Averages File: cjk_in/Output/cjk_avg.nc
Output Diagnostics File: cjk_in/Output/cjk_dia.nc
Input Grid File: cjk_in/Input/yz_3.2_4.nc
Input Nonlinear Initial File: cjk_in/Input/cjk_0402_4_ini.nc
Input Forcing File 01: cjk_in/Input/cjk_0402_tides.nc
Input Forcing File 02: cjk_in/Input/yz0402_rvr.nc
Input Forcing File 03: cjk_in/Input/cjk_0402_smf.nc
Tile partition information for Grid 01: 0270x0232x0010 tiling: 004x008
tile Istr Iend Jstr Jend Npts
0 1 67 1 29 19430
1 68 135 1 29 19720
2 136 203 1 29 19720
3 204 270 1 29 19430
4 1 67 30 58 19430
5 68 135 30 58 19720
6 136 203 30 58 19720
7 204 270 30 58 19430
8 1 67 59 87 19430
9 68 135 59 87 19720
10 136 203 59 87 19720
11 204 270 59 87 19430
12 1 67 88 116 19430
13 68 135 88 116 19720
14 136 203 88 116 19720
15 204 270 88 116 19430
16 1 67 117 145 19430
17 68 135 117 145 19720
18 136 203 117 145 19720
19 204 270 117 145 19430
20 1 67 146 174 19430
21 68 135 146 174 19720
22 136 203 146 174 19720
23 204 270 146 174 19430
24 1 67 175 203 19430
25 68 135 175 203 19720
26 136 203 175 203 19720
27 204 270 175 203 19430
28 1 67 204 232 19430
29 68 135 204 232 19720
30 136 203 204 232 19720
31 204 270 204 232 19430
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 67.50 0.50 29.50 RHO-points
1 67.50 135.50 0.50 29.50 RHO-points
2 135.50 203.50 0.50 29.50 RHO-points
3 203.50 270.50 0.50 29.50 RHO-points
4 0.50 67.50 29.50 58.50 RHO-points
5 67.50 135.50 29.50 58.50 RHO-points
6 135.50 203.50 29.50 58.50 RHO-points
7 203.50 270.50 29.50 58.50 RHO-points
8 0.50 67.50 58.50 87.50 RHO-points
9 67.50 135.50 58.50 87.50 RHO-points
10 135.50 203.50 58.50 87.50 RHO-points
11 203.50 270.50 58.50 87.50 RHO-points
12 0.50 67.50 87.50 116.50 RHO-points
13 67.50 135.50 87.50 116.50 RHO-points
14 135.50 203.50 87.50 116.50 RHO-points
15 203.50 270.50 87.50 116.50 RHO-points
16 0.50 67.50 116.50 145.50 RHO-points
17 67.50 135.50 116.50 145.50 RHO-points
18 135.50 203.50 116.50 145.50 RHO-points
19 203.50 270.50 116.50 145.50 RHO-points
20 0.50 67.50 145.50 174.50 RHO-points
21 67.50 135.50 145.50 174.50 RHO-points
22 135.50 203.50 145.50 174.50 RHO-points
23 203.50 270.50 145.50 174.50 RHO-points
24 0.50 67.50 174.50 203.50 RHO-points
25 67.50 135.50 174.50 203.50 RHO-points
26 135.50 203.50 174.50 203.50 RHO-points
27 203.50 270.50 174.50 203.50 RHO-points
28 0.50 67.50 203.50 232.50 RHO-points
29 67.50 135.50 203.50 232.50 RHO-points
30 135.50 203.50 203.50 232.50 RHO-points
31 203.50 270.50 203.50 232.50 RHO-points
0 1.00 67.50 0.50 29.50 U-points
1 67.50 135.50 0.50 29.50 U-points
2 135.50 203.50 0.50 29.50 U-points
3 203.50 270.00 0.50 29.50 U-points
4 1.00 67.50 29.50 58.50 U-points
5 67.50 135.50 29.50 58.50 U-points
6 135.50 203.50 29.50 58.50 U-points
7 203.50 270.00 29.50 58.50 U-points
8 1.00 67.50 58.50 87.50 U-points
9 67.50 135.50 58.50 87.50 U-points
10 135.50 203.50 58.50 87.50 U-points
11 203.50 270.00 58.50 87.50 U-points
12 1.00 67.50 87.50 116.50 U-points
13 67.50 135.50 87.50 116.50 U-points
14 135.50 203.50 87.50 116.50 U-points
15 203.50 270.00 87.50 116.50 U-points
16 1.00 67.50 116.50 145.50 U-points
17 67.50 135.50 116.50 145.50 U-points
18 135.50 203.50 116.50 145.50 U-points
19 203.50 270.00 116.50 145.50 U-points
20 1.00 67.50 145.50 174.50 U-points
21 67.50 135.50 145.50 174.50 U-points
22 135.50 203.50 145.50 174.50 U-points
23 203.50 270.00 145.50 174.50 U-points
24 1.00 67.50 174.50 203.50 U-points
25 67.50 135.50 174.50 203.50 U-points
26 135.50 203.50 174.50 203.50 U-points
27 203.50 270.00 174.50 203.50 U-points
28 1.00 67.50 203.50 232.50 U-points
29 67.50 135.50 203.50 232.50 U-points
30 135.50 203.50 203.50 232.50 U-points
31 203.50 270.00 203.50 232.50 U-points
0 0.50 67.50 1.00 29.50 V-points
1 67.50 135.50 1.00 29.50 V-points
2 135.50 203.50 1.00 29.50 V-points
3 203.50 270.50 1.00 29.50 V-points
4 0.50 67.50 29.50 58.50 V-points
5 67.50 135.50 29.50 58.50 V-points
6 135.50 203.50 29.50 58.50 V-points
7 203.50 270.50 29.50 58.50 V-points
8 0.50 67.50 58.50 87.50 V-points
9 67.50 135.50 58.50 87.50 V-points
10 135.50 203.50 58.50 87.50 V-points
11 203.50 270.50 58.50 87.50 V-points
12 0.50 67.50 87.50 116.50 V-points
13 67.50 135.50 87.50 116.50 V-points
14 135.50 203.50 87.50 116.50 V-points
15 203.50 270.50 87.50 116.50 V-points
16 0.50 67.50 116.50 145.50 V-points
17 67.50 135.50 116.50 145.50 V-points
18 135.50 203.50 116.50 145.50 V-points
19 203.50 270.50 116.50 145.50 V-points
20 0.50 67.50 145.50 174.50 V-points
21 67.50 135.50 145.50 174.50 V-points
22 135.50 203.50 145.50 174.50 V-points
23 203.50 270.50 145.50 174.50 V-points
24 0.50 67.50 174.50 203.50 V-points
25 67.50 135.50 174.50 203.50 V-points
26 135.50 203.50 174.50 203.50 V-points
27 203.50 270.50 174.50 203.50 V-points
28 0.50 67.50 203.50 232.00 V-points
29 67.50 135.50 203.50 232.00 V-points
30 135.50 203.50 203.50 232.00 V-points
31 203.50 270.50 203.50 232.00 V-points
HaloSizeI(1) = 246
HaloSizeJ(1) = 129
TileSide(1) = 76
TileSize(1) = 2812
cjk_calculate Yangtz River Estuary
AVERAGES Writing out time-averaged fields.
EAST_FSCLAMPED Eastern edge, free-surface, Clamped condition.
EAST_M2REDUCED Eastern edge, 2D momentum, reduced-physics condition.
FSOBC_REDUCED Using free-surface data in reduced physics condtions
INLINE_2DIO Processing 3D IO level by level to reduce memory needs.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NORTH_FSCLAMPED Northern edge, free-surface, Clamped condition.
NORTH_M2REDUCED Northern edge, 2D momentum, reduced-physics condition.
OUT_DOUBLE Double precision output fields in NetCDF files.
PERFECT_RESTART Processing perfect restart variables.
RAMP_TIDES Ramping tidal forcing for one day.
SALINITY Using salinity.
SOUTH_FSCLAMPED Southern edge, free-surface, Clamped condition.
SOUTH_M2REDUCED Southern edge, 2D momentum, reduced-physics condition.
THREE_GHOST Using three Ghost Points in halo regions.
TS_PSOURCE Tracers point sources and sinks.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_PSOURCE Mass point sources and sinks.
WESTERN_WALL Wall boundary at Western edge.
Vertical S-coordinate System:
10 0.0000000 0.0000000 0.000 0.000 0.000
9 -0.1000000 -0.1000000 -0.050 -4.037 -8.023
8 -0.2000000 -0.2000000 -0.100 -8.074 -16.047
7 -0.3000000 -0.3000000 -0.151 -12.110 -24.070
6 -0.4000000 -0.4000000 -0.201 -16.147 -32.094
5 -0.5000000 -0.5000000 -0.251 -20.184 -40.117
4 -0.6000000 -0.6000000 -0.301 -24.221 -48.140
3 -0.7000000 -0.7000000 -0.351 -28.258 -56.164
2 -0.8000000 -0.8000000 -0.402 -32.294 -64.187
1 -0.9000000 -0.9000000 -0.452 -36.331 -72.210
0 -1.0000000 -1.0000000 -0.502 -40.368 -80.234
Time Splitting Weights: ndtfast = 5 nfast = 7
1 0.0119306869089341 0.2000000000000000 0.0119306869089341 0.2000000000000000
2 0.0475049776008205 0.1976138626182131 0.0594356645097547 0.3976138626182131
3 0.1047629417620785 0.1881128670980491 0.1641986062718331 0.5857267297162622
4 0.1760826281731955 0.1671602787456334 0.3402812344450286 0.7528870084618955
5 0.2416469636634478 0.1319437531109943 0.5819281981084765 0.8848307615728898
6 0.2602974116474964 0.0836143603783047 0.8422256097559728 0.9684451219511945
7 0.1577743902440273 0.0315548780488054 1.0000000000000000 0.9999999999999999
ndtfast, nfast = 5 7 nfast/ndtfast = 1.40000
1.000000000000 1.084198606272 0.542099303136 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.00000
Minimum X-grid spacing, DXmin = 1.20649429E-02 km
Maximum X-grid spacing, DXmax = 1.26877789E+01 km
Minimum Y-grid spacing, DYmin = 3.82419589E-02 km
Maximum Y-grid spacing, DYmax = 1.04691316E+01 km
Minimum Z-grid spacing, DZmin = 5.02027180E-02 m
Maximum Z-grid spacing, DZmax = 8.02338420E+00 m
Minimum barotropic Courant Number = 1.53122431E-02
Maximum barotropic Courant Number = 7.93292092E+00
Maximum Coriolis Courant Number = 4.83202820E-03
(File: cjk_0402_4_ini.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 1.50000000E+01 Max = 1.50000000E+01)
- salinity
(Min = 0.00000000E+00 Max = 3.40000000E+01)
GET_NGFLD - tidal period
(Min = 4.30820424E+04 Max = 9.67260960E+04)
(Min = 0.00000000E+00 Max = 2.67858389E+00)
(Min = 2.53042579E-06 Max = 6.28313850E+00)
GET_NGFLD - river runoff XI-positions at RHO-points
(Min = 1.00000000E+00 Max = 1.00000000E+00)
GET_NGFLD - river runoff ETA-positions at RHO-points
(Min = 1.15000000E+02 Max = 1.22000000E+02)
GET_NGFLD - river runoff direction
GET_NGFLD - river runoff mass transport vertical profile
(Min = 2.00000000E-02 Max = 1.50000000E-01)
GET_NGFLD - river runoff flag
(Min = 2.00000000E+00 Max = 2.00000000E+00)
GET_NGFLD - river runoff mass transport, t = 0 00:00:00
(Rec=0001, Index=2, File: yz0402_rvr.nc)
(Tmin= 0.0000 Tmax= 59.5000)
(Min = 3.50000000E+03 Max = 3.50000000E+03)
GET_NGFLD - river runoff salinity, t = 0 00:00:00
GET_2DFLD - surface u-momentum stress, t = 0 00:00:00
(Rec=0001, Index=1, File: cjk_0402_smf.nc)
(Tmin= 0.0000 Tmax= 157.0000)
(Min = -8.10309795E-05 Max = 3.76189468E-05)
GET_2DFLD - surface v-momentum stress, t = 0 00:00:00
(Min = 2.75237187E-05 Max = 2.15437673E-04)
Maximum grid stiffness ratios: rx0 = 3.027411E-01 (Beckmann and Haidvogel)
rx1 = 5.752081E+00 (Haney)
Initial basin volumes: TotVolume = 6.38128429852600E+12 m3
MinVolume = 3.11297470446051E+03 m3
MaxVolume = 9.75363793296542E+08 m3
Max/Min = 3.13322106954151E+05
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00057600)
GET_NGFLD - river runoff mass transport, t = 0 12:00:00
(Rec=0002, Index=1, File: yz0402_rvr.nc)
(Min = 1.25000000E+03 Max = 1.25000000E+03)
GET_NGFLD - river runoff salinity, t = 0 12:00:00
GET_2DFLD - surface u-momentum stress, t = 1 00:00:00
(Rec=0002, Index=2, File: cjk_0402_smf.nc)
(Min = -1.03412595E-04 Max = 3.15749988E-05)
GET_2DFLD - surface v-momentum stress, t = 1 00:00:00
(Min = 7.95569603E-06 Max = 1.50063234E-04)
0 0 00:00:00 0.000000E+00 2.359258E+02 2.359258E+02 6.402577E+12
DEF_HIS - creating history file: cjk_in/Output/yz_0402_4_his.nc
DEF_AVG - creating average file: cjk_in/Output/cjk_avg.nc
DEF_DIAGS - creating diagnostics file: cjk_in/Output/cjk_dia.nc
1 0 00:01:00 4.761448+158 -Infinity -Infinity -3.213876E+60
Node # 0 CPU: 1.438
Node # 1 CPU: 1.679
Node # 2 CPU: 1.682
Node # 6 CPU: 1.680
Node # 3 CPU: 1.679
Node # 13 CPU: 1.656
Node # 5 CPU: 1.681
Node # 11 CPU: 1.656
Node # 8 CPU: 1.656
Node # 7 CPU: 1.681
Node # 16 CPU: 1.679
Node # 14 CPU: 1.676
Node # 10 CPU: 1.668
Node # 9 CPU: 1.668
Node # 21 CPU: 1.678
Node # 22 CPU: 1.678
Node # 30 CPU: 1.680
Node # 29 CPU: 1.680
Node # 19 CPU: 1.675
Node # 17 CPU: 1.678
Node # 15 CPU: 1.672
Node # 31 CPU: 1.680
Node # 28 CPU: 1.681
Node # 12 CPU: 1.672
Node # 27 CPU: 1.678
Node # 24 CPU: 1.682
Node # 23 CPU: 1.677
Node # 25 CPU: 1.680
Node # 26 CPU: 1.680
Node # 18 CPU: 1.678
Node # 20 CPU: 1.675
Node # 4 CPU: 1.622
Total: 53.320
Initialization ................................... 23.142 (43.4018 %)
Reading of input data ............................ 7.677 (14.3985 %)
Processing of input data ......................... 0.165 ( 0.3094 %)
Computation of vertical boundary conditions ...... 0.017 ( 0.0319 %)
Computation of global information integrals ...... 0.151 ( 0.2832 %)
Writing of output data ........................... 13.461 (25.2452 %)
Model 2D kernel .................................. 2.402 ( 4.5044 %)
Tidal forcing .................................... 0.043 ( 0.0806 %)
2D/3D coupling, vertical metrics ................. 0.327 ( 0.6132 %)
Omega vertical velocity .......................... 0.257 ( 0.4820 %)
Equation of state for seawater ................... 0.512 ( 0.9601 %)
GLS vertical mixing parameterization ............. 1.297 ( 2.4322 %)
3D equations right-side terms .................... 0.339 ( 0.6357 %)
3D equations predictor step ...................... 0.601 ( 1.1271 %)
Pressure gradient ................................ 0.161 ( 0.3019 %)
Harmonic mixing of tracers, S-surfaces ........... 0.073 ( 0.1369 %)
Harmonic stress tensor, S-surfaces ............... 0.115 ( 0.2157 %)
Corrector time-step for 3D momentum .............. 0.825 ( 1.5471 %)
Corrector time-step for tracers .................. 1.312 ( 2.4604 %)
Total: 52.876 99.1673
Message Passage: 2D halo exchanges ............... 1.528 ( 2.8655 %)
Message Passage: 3D halo exchanges ............... 1.473 ( 2.7623 %)
Message Passage: 4D halo exchanges ............... 0.631 ( 1.1833 %)
Message Passage: data broadcast .................. 26.207 (49.1497 %)
Message Passage: data reduction .................. 0.146 ( 0.2738 %)
Message Passage: data gathering .................. 3.609 ( 6.7680 %)
Message Passage: data scattering.................. 8.186 (15.3529 %)
Message Passage: boundary data gathering ......... 0.032 ( 0.0600 %)
Total: 41.811 78.4155
All percentages are with respect to total time = 53.320
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_fsobc.h
ROMS/Functionals/ana_m2obc.h
ROMS/Functionals/ana_stflux.h
Re: changed some water grid into land grid,the model blow up
That's quite a grid you have there!
As for why it's blowing up in the very first timestep, it's hard to say from here. I attack this sort of thing in the debugger. Having it go bad so very fast makes it easier to see what's going on - I can get it to blow up after running for a year. You know you have some infinities - where did they come from? Where did you divide by zero? You don't have zero depth anywhere, do you?
