How to impose variable
isabelmonteiro
#1 Unread post by isabelmonteiro »
I'm running a ROMS upwelling configuration for north-eastern off Iberia.
Is it possible to prescribe, with ROMS, a variable resolution, that is; if I want to get a finer resolution near the coast can I prescribe a variable resolution in the x-direction (across-shelf direction)?
Re: How to impose variable
Yes, ROMS can handle variable horizontal resolution if the change is sufficiently smooth, but it depends on your grid generation tools. How are you making the grid?
isabelmonteiro
#3 Unread post by isabelmonteiro »
My grid is generated using seagrid.
I believe there's a way to push the resolution around in SeaGrid.
