WRF_ROMS coupling compiling error
stone
#1 Unread post by stone »
I run into this error while I am going use WRF_ROMS coupling (Ideal test case coupling_test.h):
Master/ocean_coupler.F > /lun/home/roms/Projects/OA/Build/ocean_coupler.f90
In file included from Master/ocean_coupler.F:118:
Master/mct_roms_wrf.h:88: unterminated #ifndef
make: *** [/lun/home/roms/Projects/OA/Build/ocean_coupler.f90] Error 1
What is it ? Can anyone help me please?
Re: WRF_ROMS coupling compiling error
This is not a currently supported option in ROMS.
stone
#3 Unread post by stone »
Thanks for your quick reply.
Yes,I notice that the svn distribution does not include WRF source code.
Is there any helpful information I can follow on web? (I have installed WRF3.1 correctly under trunk/Atmosphere/WRF )I even haven't found where to specify the WRF Rootdir yet
What is the basic steps I should follow,would you please give me some advice?
Thank you, Kate.
There's more to it than that - you need the coupling bits.
What I hear is that there is at least one working version of this out there in ROMS land, but whoever has it isn't willing to share at this time.
#5 Unread post by jcwarner »
I am not sure if I am the magic person mentioned by Kate, but I have a working version of wrf v 3.1.1 coupled to roms. I have updated to roms svn 455, and am going thru some test cases to make sure it works. I am planning to have this finished by end of the week. If people are registered as roms users and registered as wrf users, they can contact me and we can go from there.
jcwarner@usgs.gov
#6 Unread post by kate »
Make that at least two.
turuncu
#7 Unread post by turuncu »
Hi All,
I am also working on coupling ROMS and WRF using ESMF library. I have already created a prototype version of coupled system using WRF 3.1.1, ROMS rev 382 and ESMF 3.1.0rp2. The report about this study can be found in the attached progress report. It is not cover all issues but it can give a brief introduction about my study.
--ufuk
wrf+roms progress report.pdf
Progress Report (Coupled ROMS+WRF via ESMF library)
(840.46 KiB) Downloaded 625 times
