I would to replace Original grid(Landform)
pip39
#1 Unread post by pip39 »
However, an error running upwelling examples
I used 'seagrid'tool to produced ' grid.nc' of '87x156'grid
Lm == 88 ! Number of I-direction INTERIOR RHO-points
Mm == 157 ! Number of J-direction INTERIOR RHO-points
or I try form 89x158 , 87x156, 85x154 ..... very much of form is not ok
What happened?
Please help me to solve!
and my grid.nc data have 'x_u' not have't 'xi_u' !!!
my grid.nc is not Success ?
Process Information:
Thread # 0 (pid= 736) is active.
Model Input Parameters: ROMS/TOMS version 3.2
Saturday - January 9, 2010 - 3:34:20 AM
Operating system : Linux
CPU/hardware : i686
Compiler system : gfortran
Compiler flags : -frepack-arrays -g -fbounds-check -ffree-form -ffree-line-length-none
SVN Revision : 412M
Local Root : /home/pip/paul/trunk
Header Dir : /home/pip/paul/Projects/Upwelling
Header file : upwelling.h
Analytical Dir: /home/pip/paul/Projects/Upwelling
Resolution, Grid 01: 0087x0158x016, Parallel Threads: 1, Tiling: 001x001
into restart fields.
to standard output.
into history file.
time-averaged data.
72 nAVG Number of timesteps between the writing of
72 nDIA Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
50.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
of State.
Output Diagnostics File: ocean_dia.nc
Input Grid File: roms_grd.nc
Tile partition information for Grid 01: 0087x0158x0016 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 87 1 158 219936
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 -2.50 89.50 -0.50 160.50 RHO-points
0 -2.50 89.50 -0.50 160.50 U-points
0 -2.50 89.50 -0.50 160.50 V-points
ANA_VMIX Analytical vertical mixing coefficients.
AVERAGES Writing out time-averaged fields.
EW_PERIODIC East-West periodic boundaries.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
NETCDF_CHECK_DIM - inconsistent size of dimension: xi_u 155 88
in file: roms_grd.nc
Thread # 0 CPU: 1.588
Total: 1.588
Total: 0.000 0.0000
All percentages are with respect to total time = 1.588
REASON: No error
Re: I would to replace Original grid(Landform)
It is telling you that although Lm=87, you have passed it a grid file with Lm=154. It is perhaps unfortunate, but a grid with Lm=88, Mm=154 should have these dimensions in the Netcdf file:
netcdf NEP_grid_5a {
dimensions:
        eta_rho = 156 ;
        xi_rho = 90 ;
        eta_psi = 155 ;
        xi_psi = 89 ;
        eta_u = 156 ;
        xi_u = 89 ;
        eta_v = 155 ;
        xi_v = 90 ;
