About the TEST_HEAD case
liangliang
#1 Unread post by liangliang »
Dear everyone:
Happy new year!
Now i try to run the TEST_HEAD case,i know that it is a case of coupling between roms and swan.I have installed the MCT and MPI,and then i want to install the ARPACK lib,but i have a trouble in compling it.I want to ask whether the version of MPI is specified,or the MPICH2 is better? And for the TEST_HEAD,is the ARPACK essential? under what condition is the ARPACK is essential ?
Thank you !
liangliang
Re: About the TEST_HEAD case
#2 Unread post by liangliang »
Everyone:
Hello!
I have succeeded in compiling the case of TEST_HEAD without ARPACK and created the "oceanM".
And then ,when I ran the model,i writed the command line "mpirun -np 2 oceanM coupling_test_head.in",
but the result is only one line "coupled input file = coupling_test_head.in",then it's over,without any other error information.
whether is my command line wrong? It's my first to run the coupling model,please help me!
Thank you !
#3 Unread post by jcwarner »
did you give the full location of the coupling file?
did swan create any files?
were there any error or output files created?
liangliang
#4 Unread post by liangliang »
jcwarner:
Thank you very much! You are right,my input file's location is wrong.
but after i corrected the location,the model still didn't run.The difference is that it created some files
Now ,my computer is a two-kernel PC,and i have installed MCT and MPI,which have been tested.
next is the information on the screen:
root@c12:/home/roms/projects/TEST_HEAD# mpirun -np 2 oceanM coupling_test_head.in
root@localhost's password:
Coupled Input File name = coupling_test_head.in
Model Coupling Parallel Threads:
Ocean Model MPI nodes: 000 - 000
Waves Model MPI nodes: 001 - 001
Waves Export: Wdir:Wamp:Wlen:Wptop:Wpbot:Wubot
Process Information:
Node # 0 (pid= 3127) is active.
Model Input Parameters: ROMS/TOMS version 3.2
Monday - January 4, 2010 - 7:03:30 PM
p1_3133: p4_error: : 4
rm_l_1_3136: (0.030020) net_send: could not write to fd=5, errno = 32
[1] MPI Abort by user Aborting program !
[1] Aborting program!
p1_3133: (0.030660) net_send: could not write to fd=5, errno = 32
next is the information in the "log" file:
bm_list_25268: p4_error: interrupt SIGx: 1
p0_25267: p4_error: Timeout in making connection to remote process on localhost: 0
p0_25267: (151314.414767) net_send: could not write to fd=4, errno = 32
next is the information in the "PI1585" file:
c12 0 /home/roms/projects/TEST_HEAD/oceanM
localhost 1 /home/roms/projects/TEST_HEAD/oceanM
Besides there are 3 files created by SWAN: "PRINT"、"Errfile"、"swanint"
the "Errfile" say 'Terminating error: Input file missing'.
I think that swan is no problem .The "Input file missing" should result from the abnormal end of roms.
#5 Unread post by jcwarner »
you need to be careful about the paths. When you go to run the program, you need to point to the coupling input file. That file has paths to the input files for roms and swan. Those paths need to be relative to the location of oceanM. Within the roms and swan input files, there are paths to their forcing files and output files. So check that all the paths are correct.
liangliang
#6 Unread post by liangliang »
jcwarner:
Thank you for your suggestion!
Before,i use the absolute path,which is wrong.now,i have changed the path relative to the oceanM.It is available.
But there are some other problems.
I think the program have read the input files,but i don't know what lead the program aborted.
The information on the screen is such as:
root@c12:/home/roms/trunk# mpirun -np 2 ./oceanM coupling_test_head.in
Node # 0 (pid= 8611) is active.
Tuesday - January 5, 2010 - 11:09:42 AM
Sediment Test Headland Case
Operating system : Linux
CPU/hardware : i686
Compiler system : gfortran
Compiler command : /usr/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -I/usr/local/mct/include -ffree-form -ffree-line-length-none
Input Script : ocean_test_head.in
SVN Revision :
Local Root : /home/roms/trunk
Header Dir : /home/roms/projects/TEST_HEAD
Header file : test_head.h
Analytical Dir: /home/roms/trunk/ROMS/Functionals
Resolution, Grid 01: 0056x0026x010, Parallel Nodes: 1, Tiling: 001x001
30.000 dt Timestep size (s) for 3-D equations.
(……………………elide)
Physical parameters File: ocean_test_head.in
Input Grid File: test_head_curv_grd.nc
Input Nonlinear Initial File: test_head_ini.nc
Tile partition information for Grid 01: 0056x0026x0010 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 56 1 26 14560
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 56.50 0.50 26.50 RHO-points
0 1.00 56.00 0.50 26.50 U-points
0 0.50 56.50 1.00 26.00 V-points
HaloSizeI(1) = HaloSizeI(1) = 201p1_8619: p4_error: : 172879
rm_l_1_8622: (0.081741) net_send: could not write to fd=5, errno = 32
p1_8619: (0.082079) net_send: could not write to fd=5, errno = 32
SWAN is preparing computation ...
1 - <NO ERROR MESSAGE> : Could not convert index -1082024444 into a pointer
The index may be an incorrect argument.
Possible sources of this problem are a missing "include 'mpif.h'",
a misspelled MPI object (e.g., MPI_COM_WORLD instead of MPI_COMM_WORLD)
or a misspelled user variable for an MPI object (e.g.,
com instead of comm).
[1] Aborting program !
MCT::m_MCTWorld::initm_: MP_comm_size() error, "Communicator argument is not a valid communicator
Special bit pattern 6 in communicator is incorrect. May indicate an
out-of-o"
001.MCT(MPEU)::die.: from MCT::m_MCTWorld::initm_()
MCT::m_MCTWorld::initm_: MP_comm_rank() error, "Communicator argument is not a valid communicator
out-of-o"
MCT::m_MCTWorld::initm_: MPI_SEND(mysize) error, "Communicator argument is not a valid communicator
out-of-o"
MCT::m_MCTWorld::initm_: MPI_SEND(Gprocids) error, "Communicator argument is not a valid communicator
out-of-o"
MCT::m_MCTWorld::initr_: MP_comm_size() error, "Communicator argument is not a valid communicator
out-of-o"
001.MCT(MPEU)::die.: from MCT::m_MCTWorld::initr_()
MCT::m_MCTWorld::initr_: MP_comm_rank() error, "Communicator argument is not a valid communicator
out-of-o"
MCT::m_MCTWorld::initr_: MP_comm_dup() error, "Invalid communicator"
Sometimes,the information on the screen is also like this:
Node # 0 (pid= 8700) is active.
Tuesday - January 5, 2010 - 11:10:17 AM
CPU/hardware : i686
SVN Revision :
(…………………………………………elide)
Sediment Parameters, Grid: 01
1 2.5000E-01 0.0000E+00 2.6500E+03 3.0000E+01 5.0000E-04 9.0000E-01
tau_ce tau_cd tnu2 tnu4 Akt_bak Tnudg
1 1.9000E-01 6.0000E-02 0.0000E+00 0.0000E+00 5.0000E-06 0.0000E+00
morph_fac
(nondim)
1 1.0000E+01
New bed layer formed when deposition exceeds 0.10000E-01 (m).
Two first layers are combined when 2nd layer smaller than 0.00000E+00 (m).
Rate coefficient for bed load transport = 0.50000E-01
T Hout(idTvar) Write out sediment01: sand_01
T Hout(idfrac) Write out bed fraction, sediment 01: sandfrac_01
T Hout(idfrac) Write out mass, sediment 01: sandmass_01
T Hout(idUbld) Write out bed load at U-points, sediment 01: bedload_Usand_01
T Hout(idVbld) Write out bed load at V-points, sediment 01: bedload_Vsand_01
T Hout(idSbed) Write out BED property 04: bed_biodiff
TEST_HEAD Sediment Test Headland Case
BEDLOAD_MPM Activate bed load sediment transport Meyer-Peter-Mueller.
EAST_FSCLAMPED Eastern edge, free-surface, Clamped condition.
EAST_M2REDUCED Eastern edge, 2D momentum, reduced-physics condition.
EAST_M3RADIATION Eastern edge, 3D momentum, radiation condition.
EAST_TGRADIENT Eastern edge, tracers, gradient condition.
FSOBC_REDUCED Using free-surface data in reduced physics condtions
MASKING Land/Sea masking.
MCT_LIB Using Model Coupling Toolkit library.
NEARSHORE_MELLOR Nearshore RAdiation Stress Terms.
NONLINEAR Nonlinear Model.
NORTHERN_WALL Wall boundary at Northern edge.
OUT_DOUBLE Double precision output fields in NetCDF files.
SED_MORPH Allow bottom model elevation to evolve.
SOUTHERN_WALL Wall boundary at Southern edge.
SWAN_COUPLING Two-way SWAN/ROMS coupling.
THREE_GHOST Using three Ghost Points in halo regions.
UV_ADV Advection of momentum.
WAVES_OCEAN Two-way wave-ocean models coupling.
WEST_FSCLAMPED Western edge, free-surface, Clamped condition.
WEST_M2REDUCED Western edge, 2D momentum, reduced-physics condition.
WEST_M3RADIATION Western edge, 3D momentum, radiation condition.
WEST_TGRADIENT Western edge, tracers, gradient condition.
0 - MPI_IRECV : Invalid count argument is -1209793328
[0] Aborting program !
[0] Aborting program!
p0_8700: p4_error: : 8258
p0_8700: (1.866909) net_send: could not write to fd=4, errno = 32
Besides,the swan created 'PRINT' and 'swanint' file,no Errfile.
the PRINT file is such as:
1
Execution started at 20100105.111017
SWAN
SIMULATION OF WAVES IN NEAR SHORE AREAS
VERSION NUMBER 40.51AB
PROJECT 'TEST HEAD' ''
'ocean_test_head test case to drive ROMS'
MODE NONSTATIONARY TWODIMENSIONAL
SET INRHOG 1 NAUTICAL
COORDINATES CARTESIAN
&& KEYWORDS TO CREATE AND READ COMPUTATIONAL GRID &&
CGRID CURVILINEAR 57 27 EXC 9.999000e+003 9.999000e+003 &
CIRCLE 36 0.04 1.0 30
Resolution in sigma-space: df/f = 0.1133
READGRID COORDINATES 1 'Waves/SWAN/External/test_head_curv_grid_coord.grd' 4 0 0 FREE
&& KEYWORDS TO CREATE AND READ BATHYMETRY GRID &&
INPGRID BOTTOM CURVILINEAR 0 0 57 27 EXC 9.999000e+003
READINP BOTTOM 1 'Waves/SWAN/External/test_head_curv_bathy.bot' 4 0 FREE
&& KEYWORD TO CREATE CURRENT GRID &&
INPGRID CURRENT CURVILINEAR 0 0 57 27 EXC 9.999000e+003 &
NONSTATIONARY 20030101.0000 30 DAY 20030131.0000
&& KEYWORD TO CREATE WATER LEVEL GRID &&
INPGRID WLEV CURVILINEAR 0 0 57 27 EXC 9.999000e+003 &
&& KEYWORD TO CREATE FRICTION LEVEL GRID &&
INPGRID FRIC CURVILINEAR 0 0 57 27 EXC 9.999000e+003 &
BOUNDPAR1 SHAPESPEC JONSWAP 3.3 PEAK DSPR DEGREES
BOUNDPAR2 SEGMENT IJ 0 27 57 27 CONSTANT PAR 2.0 10.0 0. 20.
& Restart name **********************************
&INIT HOTSTART 'swan_restart.dat'
& PHYSICS ****************************************
&BREAKING CONSTANT 1.0 0.73
FRICTION MADSEN 0.05
OFF QUAD
GEN3
PROP BSBT
BLOCK 'COMPGRID' NOHEADER 'depth.mat' LAY 4 DEPTH 1. OUTPUT 20030101.000000 2 HR
BLOCK 'COMPGRID' NOHEADER 'dissip.mat' LAY 4 DISSIP 1. OUTPUT 20030101.000000 2 HR
BLOCK 'COMPGRID' NOHEADER 'force.mat' LAY 4 FORCE 1. OUTPUT 20030101.000000 2 HR
BLOCK 'COMPGRID' NOHEADER 'fric.mat' LAY 4 FRCOEEF 1. OUTPUT 20030101.000000 2 HR
BLOCK 'COMPGRID' NOHEADER 'hsig.mat' LAY 4 HSIGN 1. OUTPUT 20030101.000000 2 HR
BLOCK 'COMPGRID' NOHEADER 'rtp.mat' LAY 4 RTP 1. OUTPUT 20030101.000000 2 HR
BLOCK 'COMPGRID' NOHEADER 'tm01.mat' LAY 4 TM01 1. OUTPUT 20030101.000000 2 HR
BLOCK 'COMPGRID' NOHEADER 'setup.mat' LAY 4 SETUP 1. OUTPUT 20030101.000000 2 HR
BLOCK 'COMPGRID' NOHEADER 'tmbot.mat' LAY 4 TMBOT 1. OUTPUT 20030101.000000 2 HR
BLOCK 'COMPGRID' NOHEADER 'ubot.mat' LAY 4 UBOT 1. OUTPUT 20030101.000000 2 HR
BLOCK 'COMPGRID' NOHEADER 'vel.mat' LAY 4 VEL 1. OUTPUT 20030101.000000 2 HR
BLOCK 'COMPGRID' NOHEADER 'wdir.mat' LAY 4 DIR 1. OUTPUT 20030101.000000 2 HR
BLOCK 'COMPGRID' NOHEADER 'wlen.mat' LAY 4 WLEN 1. OUTPUT 20030101.000000 2 HR
BLOCK 'COMPGRID' NOHEADER 'xp.mat' LAY 4 XP 1. OUTPUT 20030101.000000 2 HR
BLOCK 'COMPGRID' NOHEADER 'yp.mat' LAY 4 YP 1. OUTPUT 20030101.000000 2 HR
COMPUTE NONSTAT 20030101.000000 120 SEC 20030101.120000
** Warning : Limiter is de-activated in case of no quadruplets
what dose the "Warning" mean?
And dose my MPI have problem ? why is the program aborted?
liangliang
#7 Unread post by liangliang »
jcwarner:
I have succeeded in running the case of TEST_HEAD.
the problem is from MCT.When i install mct ,i use the mpi-serial and the real4double8.that is wrong.
Thanks for your help! Best wish to you!
besides,some variables in the "test_head_ini.nc" are wrong.
zhaoqian
Location: National Marine Environmental Mornitoring Center
#8 Unread post by zhaoqian »
Hi liangliang:
Is the variable Tcline? In ocean_test_head.in, it is 0.1 while in *.nc file it is very large.
