Problems with stations.in
staalstrom
#1 Unread post by staalstrom »
Hello
I want to write data from 2 positions to station output files.
I have defined stations in my cpp options.
The right staions.in file is spesified in ocean.in
But ROMS thinks ocean_sta.nc should already exist!
How do I make one?
Here's the output:
0 0 00:00:00 0.000000E+00 4.878751E+02 4.878751E+02 3.733559E+10
DEF_HIS - creating history file: ocean_his_s_0001.nc
DEF_STATION - inquiring stations file: ocean_sta.nc
ocean_sta.nc
call from: def_station.F
best regards
Andre Staalstrom (ans@niva.no)
Re: Problems with stations.in
Did you set LDEFOUT == T in the input file? Stations, floats, averages, and history files all share this flag. If it is F, ROMS will try to read existing files.
staalstrom
#3 Unread post by staalstrom »
Hi
Yes, according to ocean.out LDEFOUT=F.
But in ocean.in LDEFOUT is set to True.
There is no problems creating a new history file.
I see from some old runs without STATIONS that LDEFOUT=F even if it is set to T in ocean.in.
Is it set to F somewhere in the code?
Best regards
staalstrom
#4 Unread post by staalstrom »
Hi again
I managed to make it work in a horrible way.
I went into ROMS/Utility/def_stations.F and changed
DEFINE : IF (ldef) THEN
CALL netcdf_create (ng, iNLM, TRIM(ncname), ncSTAid(ng))
to
DEFINE : IF (.not.ldef) THEN
and now the ocean_sta.nc file is created (and also ocean_his)
But still LDEFOUT is set to False even if it is set to True in ocean.in. Why?
Here are the CPPoptions I used:
#define UV_ADV /* turn ON or OFF advection terms */
#define UV_COR /* turn ON or OFF Coriolis term */
#define UV_SADVECTION
#define TS_MPDATA
#define SALINITY /*
#define SPLINES
#define ANA_BSFLUX /* analytical bottom salinity flux */
#define ANA_SSFLUX /* analytical surface salinity flux */
#define ANA_STFLUX
#define MIX_GEO_UV
#define MIX_GEO_TS
#define MY25_MIXING
# define KANTHA_CLAYSON /* Kantha and Clayson stability
#define SPONGE
#define RADIATION_2D
#define SOUTH_FSCHAPMAN
#define SOUTH_M2FLATHER
#define SOUTH_TRADIATION
#define SOUTH_TNUDGING
#define SOUTH_M3RADIATION
#define SOUTH_M3NUDGING
#define EASTERN_WALL
#define WESTERN_WALL
#define NORTHERN_WALL
#define TCLIMATOLOGY /* Processing of tracer climatology */
#define TCLM_NUDGING /* Nudging of tracer climatology */
#define STATIONS
brgds
Andre
#5 Unread post by kate »
I wonder if there's a new bug? My floats stopped making floats files even with FLOATS defined. I'll investigate once I'm back in the office.
