Hi, I had a question about the horizontal grid set-up in ana_grid.h for BL_TEST, in which 'dx' is a function of the x-coordinate. I am interested in using nonuniform horizontal grid resolution and in specifying my grid following this form. When running BL_TEST, I noticed that the locations of the x_rho gridpoints aren't exactly halfway between the x_u gridpoints. From the horizontal discretization, I thought that the x_rho gridpoints should be located within the center of the cell. Will I run into problems if I set-up a grid in this way following BL_TEST?
Instead, should I set it up so that I make sure that the x_rho gridpoints are located at the center of the cell, halfway in between the x_u gridpoints?
Thank you,
Jessica
nonuniform horizontal grid- BL_TEST
Re: nonuniform horizontal grid- BL_TEST
ROMS does not use the x_rho for the numerics at all. It only needs pm and pn, 1 over the grid box extents.
