conservative interpolation
turuncu
#1 Unread post by turuncu »
I try to interpolate heat fluxes from atmospheric model to ROMS and i want to use conservative type interpolation for heat and rain fluxes. To do that i need to calculate area of the each grid cell in ROMS model. I was using following code to calculate rho centered grid area,
          area(i,j) = (1.0d0/pm(i,j))*(1.0d0/pn(i,j))
As it can see from code, the pm and pn can be used to calculate grid area but in this case the grid area is in projected coordinate and area of all grid cells are in same value. Otherwise, the area of the grid cell is different in spherical coordinate (not projected one). Which one must be used to interpolate data into ROMS grid? Projected area or non-projected one? The non projected grid areas can be calculated using following formula,
          area(i,j) = (6.3712d6*6.3712d6)*
     &                     abs(grid_corner_lon(1,i,j)*deg2rad-
     &                         grid_corner_lon(4,i,j)*deg2rad)*
     &                     abs(dsin(grid_corner_lat(3,i,j)*deg2rad)-
     &                         dsin(grid_corner_lat(4,i,j)*deg2rad))
Any suggestion are welcome :)
Re: conservative interpolation
I assume you want to be consistent with what ROMS considers the area, or 1/(pm*pn). That could be the projected area or the unprojected area, depending on how you set up your pm,pn. What I do is make the grid in a flat coordinate system, then recompute the pm,pn based on distance on a sphere (or ellipsoid) once I know the lat,lon of the gridpoints.
