Vertical mixing scheme in ROMS
susonic
#1 Unread post by susonic »
Hi, I'm trying to use GLS vertical mixing with k-epsilon.
First of all, I ran under Kantha clayson with k-epsilon. It ran until 9th model day
and blew up. Then I changed stability function to CANUTO_A. The model ran until 20th model day.
I also changed the viscosity value. But it didn't help me out to fix this problem.
I don't really know what the problem is. I'm trying to attach my log file. But I don't know
how to attach my file.
Regards,
-Peter
Resolution, Grid 01: 0147x0161x020, Parallel Nodes: 8, Tiling: 004x002
105120 ntimes Number of timesteps for 3-D equations.
28800 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
12 nSTA Number of timesteps between the writing of data
the stations file.
144 nHIS Number of timesteps between the writing fields
into history file.
8640 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
288 nAVG Number of timesteps between the writing of
17280 ndefAVG Number of timesteps between creation of new
time-averaged file.
for tracer 02: salt
for turbulent energy.
2.5000E-03 rdrg2 Quadratic bottom drag coefficient.
1.0000E-03 Zob Bottom roughness (m).
1.0000E+01 blk_ZQ Height (m) of surface air humidity measurement.
1.0000E+01 blk_ZT Height (m) of surface air temperature measurement.
1 lmd_Jwt Jerlov water type.
50.000 Tcline S-coordinate surface/bottom layer width (m) used
1.000 dstart Time-stamp assigned to model initialization (days).
1.000 tide_start Reference time origin for tidal forcing (days).
19960101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
3.6000E+02 Tnudg(01) Nudging/relaxation time scale (days)
1.2000E+02 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
3.6500E+02 Znudg Nudging/relaxation time scale (days)
3.6500E+02 M2nudg Nudging/relaxation time scale (days)
3.6500E+02 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.2000E+02 obcfac Factor between passive and active
my cpp header is like this
ECSY10 ROMS 3.2 - East China Sea & Yellow sea
ADD_FSOBC Adding tidal elevation to proccesed OBC data.
ADD_M2OBC Adding tidal currents to proccesed OBC data.
ANA_CLOUD Analytical cloud fraction.
ANA_RAIN Analytical rain fall rate.
AVERAGES Writing out time-averaged fields.
AVERAGES_AKS Writing out time-averaged vertical S-diffusion.
AVERAGES_AKT Writing out time-averaged vertical T-diffusion.
AVERAGES_FLUXES Writing out time-averaged surface fluxes.
BULK_FLUXES Surface bulk fluxes parametererization.
CANUTO_B Canuto B-stability function formulation.
DIFF_3DCOEF Horizontal, time-dependent 3D diffusion coefficient.
EAST_FSCHAPMAN Eastern edge, free-surface, Chapman condition.
EAST_M2FLATHER Eastern edge, 2D momentum, Flather condition.
EAST_M3CLAMPED Eastern edge, 3D momentum, Clamped condition.
EAST_TCLAMPED Eastern edge, tracers, Clamped condition.
LONGWAVE Compute net longwave radiation internally.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NORTHERN_WALL Wall boundary at Northern edge.
PERFECT_RESTART Processing perfect restart variables.
SALINITY Using salinity.
SOUTH_FSCHAPMAN Southern edge, free-surface, Chapman condition.
SOUTH_M2FLATHER Southern edge, 2D momentum, Flather condition.
SOUTH_M3CLAMPED Southern edge, 3D momentum, Clamped condition.
SOUTH_TCLAMPED Southern edge, tracers, Clamped condition.
STATIONS Writing out station data.
TS_PSOURCE Tracers point sources and sinks.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_PSOURCE Mass point sources and sinks.
VISC_3DCOEF Horizontal, time-dependent 3D viscosity coefficient.
WEST_FSCHAPMAN Western edge, free-surface, Chapman condition.
WEST_M2FLATHER Western edge, 2D momentum, Flather condition.
WEST_M3CLAMPED Western edge, 3D momentum, Clamped condition.
WEST_TCLAMPED Western edge, tracers, Clamped condition.
Sorry for the long post.
Re: Vertical mixing scheme in ROMS
it is difficult to determine why your application is having troubles. It may/may not be related to the vertical mixing scheme that was selected. You need to investigate why it blew up. Is the problem at a lateral boundary? At an internal land/sea boundary? At a river source ????
susonic
#3 Unread post by susonic »
Hi Dr.Warner,
I already tested my application with using LMD and MY 2.5 vertical scheme. It ran well without any
problem. And I have just tested k-omega and gen vertical mixing and it also ran well without any problem. For the k-epsilon, my final history file gives me that there is an increasing speed at the lateral boundary. But it didn't happen with other stability functions as well as vertical schemes.
It blew up only with k-epsilon scheme.
Anyway, if the lateral boundary current speed increasing is the problem, what do I need to do?
Would you give me a suggestion?
Best,
-Peter
ggerbi
#4 Unread post by ggerbi »
Peter,
I have had trouble with k-epsilon being a bit less stable than the other closure schemes. Reducing the time step has helped fix this. Not an entirely satisfactory solution, I know.
Greg
susonic
#5 Unread post by susonic »
Hi ggerbi,
Thank you for your suggestion.
I'm running the model with time reduced(one third of the original time step). And now
it's woring without any problem.
It has still a little bit unstable speed near the boundary, though.
Again, thank you so much for your advice.
Best,
-Peter
