In my case, i use the QUIKSCAT wind data to fore roms. However,it error:
REASON: No error
242.3180
Data Tmin = 242.3182 Data Tmax = 275.6818
Data Tstr = 275.6818 Data Tend = 242.3182
TINTRP1 = 275.6818 TINTRP2 = 242.3182
FAC1 = 0.0002 FAC2 = -33.3638
SET_2DFLD - current model time exceeds ending value for variable: svstr
TDAYS = 242.3180
Thank you!
Other input file code
Minimum X-grid spacing, DXmin = 3.00007950E+00 km
Maximum X-grid spacing, DXmax = 3.00009878E+00 km
Minimum Y-grid spacing, DYmin = 2.97288700E+00 km
Maximum Y-grid spacing, DYmax = 2.99985632E+00 km
Minimum Z-grid spacing, DZmin = 2.50000000E-01 m
Maximum Z-grid spacing, DZmax = 5.32957328E+01 m
Minimum barotropic Courant Number = 2.96585185E-02
Maximum barotropic Courant Number = 2.62072930E-01
Maximum Coriolis Courant Number = 1.69204408E-02
NLM: GET_STATE - Read state initial conditions, t = 242.3180
(File: pearl_ini.nc, Rec=0001, Index=1)
- free-surface
(Min = 9.96920997E+36 Max = 9.96920997E+36)
- u-momentum component
(Min = 1.00000000E+35 Max = 9.96920997E+36)
- v-momentum component
- potential temperature
(Min = 1.10000000E+01 Max = 2.60000000E+01)
- salinity
(Min = 1.90000000E+01 Max = 3.40000000E+01)
GET_2DFLD - surface u-momentum stress, t = 275.6818
(File: pearl_wind.nc, Rec=0024, Index=1)
(Tmin= 242.3182 Tmax= 275.6818)
(Min = -1.54025410E-04 Max = -2.93977201E-05)
GET_2DFLD - surface v-momentum stress, t = 275.6818
(Min = -5.96063565E-05 Max = -4.04749284E-06)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 242.3180
(File: pearl_bry.nc, Rec=0001, Index=2)
(Tmin= 242.3180 Tmax= 242.3180)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 242.3180
GET_NGFLD - 3D u-momentum southern boundary condition, t = 242.3180
GET_NGFLD - 3D v-momentum southern boundary condition, t = 242.3180
GET_NGFLD - temperature southern boundary condition, t = Node # 2 CPU: 0.587
Total: 2.348
