Problem reading atmospheric forcing file
Diego
#1 Unread post by Diego »
Hello all,
I spend most of my day trying to add atmospheric forcing to my application... and I haven't been successful... now, with a headache and a slight desire to shoot my screen... I decided it is time to ask for help.
1) I compiled ROMS using BULK_FLUXES
2) I created a forcing file (myapp_frc.nc) in matlab using more or less this:
NOTE: To facilitate debugging... I made sure that first and last number in the series were NOT zero.
time = [0:1800:31536000]';
nc = netcdf('myapp_frc.nc','clobber');
nc('time') = length(time);
dims                  = { 'time'};
nc{ 'data_time'}      = ncdouble(dims);
nc{ 'data_time'}(:)   = time;
dims                  = { 'time'};
nc{ 'Qair'}           = ncdouble(dims);
nc{ 'Qair'}(:)        = Qair;
nc{ 'Qair'}.time      = 'data_time' ;
dims                  = { 'time'};
nc{ 'Pair'}           = ncdouble(dims);
nc{ 'Pair'}(:)        = Pair;
nc{ 'Pair'}.time      = 'data_time' ;
dims                  = { 'time'};
nc{ 'Tair'}           = ncdouble(dims);
nc{ 'Tair'}(:)        = Tair;
nc{ 'Tair'}.time      = 'data_time' ;
...etc
3) I have in my ocean.in file the following time-stamping
  DSTART =  0.0d0
   TIDE_START =  0.0d0
     TIME_REF =  0.0d0
4) I called the forcing file from the ocean.in file:
FRCNAME == ../myapp_frc.nc
RESULT:
ROMS reads the forcing file ... but all variables are ZEROS.
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00120000)
    GET_2DFLD   - surface u-wind component,                  t =     0 00:29:59
                   (Rec=0002, Index=2, File: myapp_frc.nc)
                   (Tmin=          0.0000 Tmax=        364.9833)
    GET_2DFLD   - surface v-wind component,                  t =     0 00:29:59
    GET_2DFLD   - cloud fraction,                            t =     0 00:29:59
    GET_2DFLD   - solar shortwave radiation flux,            t =     0 00:29:59
    GET_2DFLD   - surface air pressure,                      t =     0 00:29:59
    GET_2DFLD   - surface air temperature,                   t =     0 00:29:59
    GET_2DFLD   - surface air relative humidity,             t =     0 00:29:59
    GET_2DFLD   - rain fall rate,                            t =     0 00:29:59
    GET_NGFLD   - free-surface eastern boundary condition,   t =     0 00:29:10
                   (Rec=0002, Index=1, File: sessile_toy_bry.nc)
                   (Tmin=          0.0000 Tmax=         29.9971)
                   (Min =  2.06691772E-03 Max =  2.32506194E-03)
    GET_NGFLD   - 2D u-momentum eastern boundary condition,  t =     0 00:29:10
                   (Min =  1.45433019E-04 Max =  4.58126160E-04)
    GET_NGFLD   - 2D v-momentum eastern boundary condition,  t =     0 00:29:10
                   (Min =  1.80534989E-04 Max =  1.35378519E-03)
    GET_NGFLD   - 3D u-momentum eastern boundary condition,  t =     0 00:29:10
                   (Min =  1.34837115E-04 Max =  4.78165835E-04)
    GET_NGFLD   - 3D v-momentum eastern boundary condition,  t =     0 00:29:10
                   (Min =  1.74097040E-04 Max =  1.51734304E-03)
    GET_NGFLD   - temperature eastern boundary condition,    t =     0 00:29:10
                   (Min =  8.90690041E+00 Max =  9.00000000E+00)
    GET_NGFLD   - salinity eastern boundary condition,       t =     0 00:29:10
                   (Min =  3.00000000E+01 Max =  3.00008259E+01)
    GET_NGFLD   - nitrate eastern boundary condition,        t =     0 00:29:10
                   (Min =  5.00000000E-01 Max =  5.00000000E-01)
    GET_NGFLD   - ammonium eastern boundary condition,       t =     0 00:29:10
                   (Min =  1.00000001E-01 Max =  1.00000001E-01)
    GET_NGFLD   - chlorophyll eastern boundary condition,    t =     0 00:29:10
                   (Min =  1.00000000E+00 Max =  1.00000000E+00)
    GET_NGFLD   - phytoplankton eastern boundary condition,  t =     0 00:29:10
    GET_NGFLD   - zooplankton eastern boundary condition,    t =     0 00:29:10
                   (Min =  2.00000003E-01 Max =  2.00000003E-01)
    GET_NGFLD   - large fraction nitrogen detritus eastern bot =     0 00:29:10
    GET_NGFLD   - small fraction nitrogen detritus eastern bot =     0 00:29:10
I triple checked... and the forcing file definitely contains the correct (i.e. non-zero) data.
Also note that the boundary forcing from a different file (sessile_toy_bry.nc ... which I created using a similar procedure) is read just fine.
I am puzzled. :?
I am probably missing something simple... maybe new eyes (and fresh minds) would pick my mistake easily. Any help will be greatly appreciated.
Thank you,
Diego
Diego
Re: Problem reading atmospheric forcing file
#2 Unread post by Diego »
Hello all,
I've been working on this "zero wind" issue for a week...
So far, I think I found why ROMS outputs zeros on the screen... if found a difference between the version I am running (301 2009-01-22) and the older version where ROMS last read winds ok
In get_2dflg.F ...I added:
Fmin = Fval
Fmax = Fval
...as shown below:
              CALL netcdf_get_fvar (ng, model, ncfile, Vname(1,ifield), &
     &                              Fval,                               &
     &                              ncid = ncid,                        &
     &                              start = (/Trec/),                   &
     &                              total = (/1/))
              Fpoint(Tindex,ifield,ng)=Fval*Fscale(ifield,ng)
              Fmin = Fval
              Fmax = Fval
            IF (exit_flag.ne.NoError) THEN
              IF (Master) WRITE (stdout,40) TRIM(Vname(1,ifield)), Trec
              RETURN
            Finfo(8,ifield,ng)=Fmin
            Finfo(9,ifield,ng)=Fmax
I know Laura was also having troubles with "zeros on the output screen". I think this should fix that.
However... I am still getting U and V velocities that are consistent with only tidal forcing and "no winds" ... which means that I am still not done fixing my problem.
I'll keep you updated.
Cheers
Diego
#3 Unread post by arango »
Yes, good catch. Thank you. The local variables Fmin and Fmax were not initialized when processing point data. I updated the repository, check the following :arrow: ticket.
I will recommend you to write out surface wind stress (sustr, svstr) into output NetCDF files to check if indeed the wind stress forcing is zero.
anna.morgante
#4 Unread post by anna.morgante »
Hi Diego. I have been working on implementing my first test case with winds from a netcdf file. However I'm running into a similar problem that you mentioned. The log file shows a non zero value for my v surface momentum stress (u stress is purposefully set to zero), however, my results show no sign of any wind stress. Did you solve your problem? Could you tell me how?
Thank you,
Anna
Diego
#5 Unread post by Diego »
My problem was only with "zeros on the output screen"... which should be solved by upgrading to the newest ROMS.
I figured that wind was actually working fine... by generating a file with rather large wind... that way the effect was evident.
Hope this helps.
Diego
