I had problem with setting TIME_REF parameter. When i set it into 19990701.0d0 i expect that the caldate method in ROMS/Utility/get_date.F must return model start date as 1999-07-01 but it returns 1999-06-30. I add some print statement into this method and i figure out that the INT must be replaced with NINT. When you set the TIME_REF greater than zero it select gregorian calendar.
The r_date value is;
r_date = 19990701.0000000000 1999.00000000000000 182.000000000000000 7.00000000000000000 1.00000000000000000 0.000000000000000000E+00 0.000000000000000000E+00 0.000000000000000000E+00
and the values from method are,
tdays = 0.000000000000000000E+00
rday = 182.000000000000000
year = 1999
yday = 182.000000000000000
month = 6
day = 30
if i modify the line,
month=MIN(12,1+INT(yday/30.6001_r8))
month=MIN(12,1+NINT(yday/30.6001_r8))
day=INT(yday)-iydl(month)+1
day=INT(yday)-iyd(month)+1
