what's the error?
duckweed
what's the error?
#1 Unread post by duckweed »
when i mpirun the oceanM ,the out.log is:
running /upwelling/Forward/oceanM on 4 LINUX ch_p4 processors
Created /upwelling/Forward/PI27445
Process Information:
Node # 0 (pid= 27648) is active.
Node # 2 (pid= 27782) is active.
Node # 1 (pid= 27715) is active.
Node # 3 (pid= 27849) is active.
Sunday - July 12, 2009 - 10:48:08 PM
Operating system : Linux
CPU/hardware : x86_64
Compiler system : pgi
Compiler command : mpif90
Compiler flags : -fastsse -Mipa=fast -tp k8-64 -Mfree
Input Script : ocean_upwelling.in
SVN Revision :
Local Root : /ROMS
Header Dir : /Forward
Header file : upwelling.h
Analytical Dir: /ROMS/ROMS/Functionals
Resolution, Grid 01: 0041x0080x016, Parallel Nodes: 4, Tiling: 001x001
ROMS/TOMS: Wrong choice of domain 01 partition or number of parallel threads.
NtileI * NtileJ must be equal to the number of parallel nodes.
Change -np value to mpirun or
Tile partition information for Grid 01: 0041x0080x0016 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 41 1 80 52480
HaloSizeI(1) = 156
HaloSizeJ(1) = 267
TileSide(1) = 83
TileSize(1) = 3818
ANA_VMIX Analytical vertical mixing coefficients.
AVERAGES Writing out time-averaged fields.
EW_PERIODIC East-West periodic boundaries.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
TS_U3HADVECTION Third-order upstream bias horizontal advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_U3HADVECTION Third-order upstream bias advection of momentum.
0: ALLOCATE: 16721214976 bytes requested; not enough memory
p2_27782: p4_error: interrupt SIGSEGV: 11
ROMS/TOMS - Partition error ......... exit_flag: 6
rm_l_1_27717: (0.410156) net_send: could not write to fd=6, errno = 9
p4_error: latest msg from perror: Bad file descriptor
rm_l_1_27717: p4_error: net_send write: -1
rm_l_2_27784: (0.210938) net_send: could not write to fd=5, errno = 32
p3_27849: p4_error: interrupt SIGx: 13
p3_27849: (6.031250) net_send: could not write to fd=5, errno = 32
m.hadfield
Re: what's the error?
ROMS has already told you:
Wrong choice of domain 01 partition or number of parallel threads. NtileI * NtileJ must be equal to the number of parallel nodes.
Hint: NtileI and NtileJ are set in your input file.
mariafattorini
#3 Unread post by mariafattorini »
I have a similar error message but I don't know where the error is.
When the application runs I get:
         T  Hout(idBott)    Write out bottom property 18: dep_net
             Output History File:  ocean_his.nc
            Output Averages File:  ocean_avg.nc
 READ_PHYPAR - could not find input file:  ocean_frc.nc
 Thread #  0 CPU:       0.062
 Total:                 0.062
                                              Total:         0.000    0.0000
 All percentages are with respect to total time =            0.062
 ROMS/TOMS - I/O error ............... exit_flag:   4
 ERROR: I/O related problem.
In my log.out there is not any suggestion to found the error.
Can somebody help me to found the error, please?
Many thanks,
Maria
I think this is what you are looking for.
drews
#5 Unread post by drews »
This error message:
probably means that the ROMS executable has run out of memory, based on the grid size that you are using. 16 Gigabytes is a lot of space; I found a similar problem on my Linux workstation, when ROMS could not allocate about 138 Mb. You can try decreasing the array sizes in the ROMS input file (yourApp.in) to see if that fixes the problem temporarily, as I did here:
! Lm == 2399 ! Number of I-direction INTERIOR RHO-points
! Mm == 2399 ! Number of J-direction INTERIOR RHO-points
Lm == 1199 ! Number of I-direction INTERIOR RHO-points
Mm == 1199 ! Number of J-direction INTERIOR RHO-points
N == 1 ! Number of vertical levels
ROMS will likely produce an error later when the Lm and Mm numbers don't match the NetCDF grid file, but you can at least discover if you have a memory problem or something else. Use 'top' to monitor your memory usage. Changing the stack size to unlimited had no effect here.
If you are really running out of memory, you can install more, increase the size of your process space somehow, move to a bigger machine, or reduce your number of grid points. I'm reading about how to set up nested grids. :D
