i have gotten the 'oceanM',but i have some question
duckweed
#1 Unread post by duckweed »
i have gotten the 'oceanM', the next step?
However i have not gotten:
ocean_avg.nc
ocean_dia.nc
ocean_his.nc
ocean_rst.nc
Re: i have gotten the 'oceanM',but i have some question
If you have oceanM, you have compiled the model for running under MPI. Do you have a parallel system to run on? If so, fine, otherwise, recompile it without the USE_MPI option.
Now you need to run the model. When it runs, it produces the netcdf output and the text output. For instructions on running, see the bottom of:
https://www.myroms.org/wiki/index.php/Getting_Started
