Problem reading netcdf module in make stage
austinctodd
#1 Unread post by austinctodd »
I have tried to follow fairly closely with some of the suggested methods of installing and configuring ROMS on my MacBook with OSX 10.4.11 (especially the wonderful post by Parker MacCready at UW). However, I am still having unresolved issues when typing "make" in the ROMS directory that do not look like the same issues others are having. First off, here are the options I am using:
OSX 10.4.11
gfortran
netcdf-4.0 (also tried w/ netcdf-3.6.3 but receive same error)
hdf5
The error I am receiving is:
cd Build; /usr/local/bin/gfortran -c -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none mod_netcdf.f90
Fatal Error: Reading module netcdf at line 23 column 27: Expected string
make: *** [Build/mod_netcdf.o] Error 1
Any suggestions would be greatly appreciated.
Re: Problem reading netcdf module in make stage
The first thing to do is to actually look at Build/mod_netcdf.f90 and see what is on line 23. I get:
      INTERFACE netcdf_get_fvar
as the start of this block:
        MODULE PROCEDURE netcdf_get_fvar_0d
        MODULE PROCEDURE netcdf_get_fvar_1d
        MODULE PROCEDURE netcdf_get_fvar_2d
        MODULE PROCEDURE netcdf_get_fvar_3d
        MODULE PROCEDURE netcdf_get_fvar_4d
      END INTERFACE netcdf_get_fvar
Is this what you have?
austinctodd
#3 Unread post by austinctodd »
Hi Kate. This is exactly what I have in my Build/mod_netcdf.f90 starting at line 23.
The gfortran on my Mac has no problem with this code:
gfortran --version
GNU Fortran (GCC) 4.4.0 20081219 (experimental)
austinctodd
#5 Unread post by austinctodd »
OK, so I was running version 4.3. I updated to the newer version (4.4) and attempted to compile again.
I now receive a different error associated with the mod_netcdf.f90
mod_netcdf.f90:18.19:
USE mod_kinds
1
Fatal Error: Parse error when checking module version for file 'mod_kinds.mod' opened at (1)
I am not clear on how to solve a parse error.
m.hadfield
#6 Unread post by m.hadfield »
The first thing to do now is to delete all files created during the build process and try again. I doubt it will fix the problem, but it should make it easier to identify the cause.
Edit: From the original post I suspect that you have a compiler-version mismatch. Gfortran's mod-file format changed in the last year or so. I suggest you build netCDF from source, using the same compiler as the one you use to build ROMS.
