Error with SHOREFACE after update
fancer
Location: NNSTU, The Nizhniy Novgorod State Technical University named after R.E.Alekseev, Russia
#1 Unread post by fancer »
After "svn up", when I make SHOREFACE example, show up next error:
/usr/bin/cpp -P -traditional -DLINUX -DI686 -DGFORTRAN -D'ROOT_DIR="/root/program_files/ROMS/roms3"' -DSHOREFACE -D'HEADER="shoreface.h"' -D'ROMS_HEADER="shoreface.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/root/program_files/ROMS/roms3/ROMS/Functionals"' -D'SVN_REV="351M"' -IROMS/Include -IROMS/Nonlinear -IROMS/Utility -IROMS/Drivers -IROMS/Functionals -IMaster -ICompilers -D'HEADER_DIR="/root/program_files/ROMS/roms3/ROMS/Include"' ROMS/Utility/set_3dfld.F > Build/set_3dfld.f90
ROMS/Bin/cpp_clean Build/set_3dfld.f90
cd Build; /usr/bin/gfortran -c -frepack-arrays -O3 -ffast-math set_3dfld.f90
cd Build; /usr/bin/gfortran -c -frepack-arrays -O3 -ffast-math set_data.f90
set_data.f90:179.10:
cff=Dcrit(ng)-GRID(ng)%h(0,j))
1
Error: Unclassifiable statement at (1)
You can see, what here superfluous bracket))) And set_data.f90 is generated file))) After deleting superfluous bracket all work correctly)))
I deleted all ROMS and download all packаges afresh, but error save((((
Re: Error with SHOREFACE after update
thanks for the post.
That change was identified and a ticket was issued. The main trunk was not updated yet but i am sure it will get changed shortly. For now, just remove that extra parenthesis and it should allow you to compile.
