Currently, the matlab repository (https://www.myroms.org/svn/src/matlab) have the following sub-directory structure:
matlab/ Main repository directory
/bathymetry Bathymetry extracting tools
/coastlines Coastline extracting tools
/landmask ROMS Land/Sea mask tools and GUIs
/seagrid/ Charles Denham grid generation GUI
/@seagrid SeaGrid internal utility functions
/test_data SeaGrid test data
/seawater Phillip Morgan (CSIRO) SeaWater library
/utility Generic pre- and post-processing library
/startup.m Workspace configuration script
- To check-out the files from the matlab repository (latest version), enter (notice https instead of http):
svn checkout https://www.myroms.org/svn/src/matlab MyDir or svn checkout --username joe_roms https://www.myroms.org/svn/src/matlab MyDir
- The script utility/depths.m is the official Matlab script to compute ROMS depths for any 3D-variable. I highly recommend to you to use this script. Recall, that the depths (z_r and z_w) in ROMS change at each time step because of its dependency on the time-varying free-surface. See
WikiROMS description of ROMS Vertical S-coordinate.
- The script utility/scoord.m can be used to select the optimal set of vertical stretching parameters, vertical transformation equation, and vertical stretching function for a particular applications. See
WikiROMS for more details. This script was used to produce the plots shown in this wiki page.
- The NetCDF interface to Matlab is via the
MEXNC developed by John Evans. MEXNC is a mex-file interface very similar to the NetCDF C-library. John Evans developed a very clever design (starting with version 2.9.1) for this interface. It performs a series of internal checks to either use Matlab native interface (available in version R2008b) or the MEXNC library. MEXNC It is possible to compile MEXNC to support both NetCDF-3 and NetCDF4/HDF5 type files.
- It is possible to build an OpenDAP enabled MEXNC. There are notes online
here. Unfortunately, you won't be able read NetCDF4/HDF5 files though. We are investigating whether MEXNC can be modified to use the NetCDF-Java library for reading OpenDAP URLs.
Mark Hadfield remind me that there is an experimental version of OpenDAP in the latest version of the NetCDF4 library. It has the ncdump/ncgen utilility that can read files from an OpenDAP server and read/write NetCDF-4 files. He also adds:The only problem, a fairly big one, is that the OpenDAP interface is written in C++, which means that programs (like MEXNC, Fortran programs, etc) that use this library must be linked with the C++ linker. This just isn't worth the bother to me, so I haven't tried to link to it with ROMS. However the netCDF developers plan to reqrite the OpenDAP code in C for version 4.1. I don't know when they plan to release 4.1, but it won't be soon.
