I'm examining the budget of transport equation for sediments in a shallow idealized estuary. I have only one sediment class, and the domain of interest is constantly wet and dry due to tides. Strangely, with DIAGNOSTICS_TS turned on, the transport equation is not closed??? The salt and temperature transport equations are closed, as expected. Have anybody seen this before?
Here is how I did the budget:
mud_01_rate = mud_01_hadv + mud_01_vadv + mud_01_vdiff.
The RHS (righ-hand side) is consistently larger than LHS. There is an offset between LHS and RHS, but this offset is not constant in space and time.
Questions:
1. Should I expect the equation for sediment to be closed?? In step3d_t.F, it looks like the vertical settling flux is not included in diagnostics calculation. But, when I added a settling flux to mud_01_vadv, the transport equation is still not closed. Any suggestion is highly appreciated!!
Diagnostics for sediment not closed??
Re: Diagnostics for sediment not closed??
Yes, I will expect that. We haven't coded yet the contributions due to the source and sink terms in the sediment equations. Perhaps, we need volunteers to help us code these terms. I think it is not that difficult to code and test these contributions. Of course, it can get complicate if the contribution by processes is desired.
Hernan,
Thanks for the clarification. Since vertical flux is what no fully represented in the sediment diagnostics, I tried to avoid it for now. So, I depth-integrated each term and expected the following to balance :
Integral (mud_01_rate) ~= Integral (mud_01_hadv) - d/dt (bed_thickness * 2650 * (1-porosity))
Integral means depth-integral. 2650 is sediment grain density.
The first two terms are available from the diagnostic output, and the last one is from the field variable (bed_thickness: meter). The last term represents the bed mass changes. I know that the time-derivative may introduce some errors, but I expect they should roughly balance.
Result:
They do not balance (sigh.....). Term 1 - Term 2 is roughly twice as big as the last term. Did I do something wrong?? Any suggestion is appreciated!! ---- Shih-Nan
Result:
