convert sigma coordinate to depth coordinate
fdaryabor
#1 Unread post by fdaryabor »
Hi Everybody
ROMS is in xi,eta,sigma
coordiantes. I want to convert sigma co-ordinates to
depth coordinates. I will get the output nc file in
the following form. Everybody could help me for guide or have script for converting thanks so much.
netcdf roms_avg_Y1M1 {
dimensions:
xi_rho = 103 ;
xi_u = 102 ;
eta_rho = 104 ;
eta_v = 103 ;
s_rho = 20 ;
s_w = 21 ;
time = UNLIMITED ; // (30 currently)
auxil = 4 ;
variables:
char spherical ;
spherical:option_T = "spherical" ;
spherical:option_F = "cartesian" ;
float xl ;
xl:long_name = "domain length in the XI-direction" ;
xl:units = "meter" ;
float el ;
el:long_name = "domain length in the ETA-direction" ;
el:units = "meter" ;
float h(eta_rho, xi_rho) ;
h:long_name = "bathymetry at RHO-points" ;
h:units = "meter" ;
h:field = "bath, scalar" ;
float f(eta_rho, xi_rho) ;
f:long_name = "Coriolis parameter at RHO-points" ;
f:units = "second-1" ;
f:field = "coriolis, scalar" ;
float pm(eta_rho, xi_rho) ;
pm:long_name = "curvilinear coordinate metric in XI" ;
pm:units = "meter-1" ;
pm:field = "pm, scalar" ;
float pn(eta_rho, xi_rho) ;
pn:long_name = "curvilinear coordinate metric in ETA" ;
pn:units = "meter-1" ;
pn:field = "pn, scalar" ;
float lon_rho(eta_rho, xi_rho) ;
lon_rho:long_name = "longitude of RHO-points" ;
lon_rho:units = "degree_east" ;
lon_rho:field = "lon_rho, scalar" ;
float lat_rho(eta_rho, xi_rho) ;
lat_rho:long_name = "latitude of RHO-points" ;
lat_rho:units = "degree_north" ;
lat_rho:field = "lat_rho, scalar" ;
float angle(eta_rho, xi_rho) ;
angle:long_name = "angle between XI-axis and EAST" ;
angle:units = "radians" ;
angle:field = "angle, scalar" ;
float mask_rho(eta_rho, xi_rho) ;
mask_rho:long_name = "mask on RHO-points" ;
mask_rho:option_0 = "land" ;
mask_rho:option_1 = "water" ;
int time_step(time, auxil) ;
time_step:long_name = "time step and record numbers from initialization" ;
float scrum_time(time) ;
scrum_time:long_name = "averaged time since initialization" ;
scrum_time:units = "second" ;
scrum_time:field = "time, scalar, series" ;
float zeta(time, eta_rho, xi_rho) ;
zeta:long_name = "averaged free-surface" ;
zeta:units = "meter" ;
zeta:field = "free-surface, scalar, series" ;
float ubar(time, eta_rho, xi_u) ;
ubar:long_name = "averaged vertically integrated u-momentum component" ;
ubar:units = "meter second-1" ;
ubar:field = "ubar-velocity, scalar, series" ;
float vbar(time, eta_v, xi_rho) ;
vbar:long_name = "averaged vertically integrated v-momentum component" ;
vbar:units = "meter second-1" ;
vbar:field = "vbar-velocity, scalar, series" ;
float u(time, s_rho, eta_rho, xi_u) ;
u:long_name = "averaged u-momentum component" ;
u:units = "meter second-1" ;
u:field = "u-velocity, scalar, series" ;
float v(time, s_rho, eta_v, xi_rho) ;
v:long_name = "averaged v-momentum component" ;
v:units = "meter second-1" ;
v:field = "v-velocity, scalar, series" ;
float temp(time, s_rho, eta_rho, xi_rho) ;
temp:long_name = "averaged potential temperature" ;
temp:units = "Celsius" ;
temp:field = "temperature, scalar, series" ;
float salt(time, s_rho, eta_rho, xi_rho) ;
salt:long_name = "averaged salinity" ;
salt:units = "PSU" ;
salt:field = "salinity, scalar, series" ;
float omega(time, s_w, eta_rho, xi_rho) ;
omega:long_name = "averaged S-coordinate vertical momentum component" ;
omega:units = "meter second-1" ;
omega:field = "omega, scalar, series" ;
float w(time, s_rho, eta_rho, xi_rho) ;
w:long_name = "averaged vertical momentum component" ;
w:units = "meter second-1" ;
w:field = "w-velocity, scalar, series" ;
float AKt(time, s_w, eta_rho, xi_rho) ;
AKt:long_name = "averaged temperature vertical diffusion coefficient" ;
AKt:units = "meter2 second-1" ;
AKt:field = "AKt, scalar, series" ;
float hbl(time, eta_rho, xi_rho) ;
hbl:long_name = "averaged depth of planetary boundary layer" ;
hbl:units = "meter" ;
hbl:field = "hbl, scalar, series" ;
float hbbl(time, eta_rho, xi_rho) ;
hbbl:long_name = "averaged depth of bottom boundary layer" ;
hbbl:units = "meter" ;
hbbl:field = "hbbl, scalar, series" ;
float bostr(time, eta_rho, xi_rho) ;
bostr:long_name = "averaged Kinematic bottom stress" ;
bostr:units = "N/m2" ;
// global attributes:
:type = "ROMS averages file" ;
:title = "Southern Benguela" ;
:date = ;
:rst_file = "ROMS_FILES/roms_rst.nc" ;
:his_file = "ROMS_FILES/roms_his.0000.nc" ;
:avg_file = "ROMS_FILES/roms_avg.0000.nc" ;
:grd_file = "ROMS_FILES/roms_grd.nc" ;
:ini_file = "ROMS_FILES/roms_ini.nc" ;
:frc_file = "ROMS_FILES/roms_frc.nc" ;
:theta_s = 5.f ;
:theta_s_expl = "S-coordinate surface control parameter" ;
:theta_b = 0.4f ;
:theta_b_expl = "S-coordinate bottom control parameter" ;
:Tcline = 10.f ;
:Tcline_expl = "S-coordinate surface/bottom layer width" ;
:Tcline_units = "meter" ;
:hc = 10.f ;
:hc_expl = "S-coordinate parameter, critical depth" ;
:hc_units = "meter" ;
:sc_w = -1.f, -0.95f, -0.9f, -0.85f, -0.8f, -0.75f, -0.7f, -0.65f, -0.6f, -0.55f, -0.5f, -0.45f, -0.4f, -0.35f, -0.3f, -0.25f, -0.2f, -0.15f, -0.1f, -0.05f, 0.f ;
:sc_w_expl = "S-coordinate at W-points" ;
:Cs_w = -1.f, -0.8655258f, -0.7593114f, -0.6742046f, -0.6041494f, -0.5437741f, -0.4881475f, -0.4328656f, -0.3746809f, -0.3126323f, -0.2489214f, -0.188284f, -0.1356491f, -0.09380978f, -0.06283176f, -0.04099445f, -0.02601683f, -0.01581968f, -0.008792158f, -0.003783539f, -2.220446e-17f ;
:Cs_w_expl = "S-coordinate stretching curves at W-points" ;
:sc_r = -0.975f, -0.925f, -0.875f, -0.825f, -0.775f, -0.725f, -0.675f, -0.625f, -0.575f, -0.525f, -0.475f, -0.425f, -0.375f, -0.325f, -0.275f, -0.225f, -0.175f, -0.125f, -0.075f, -0.025f ;
:sc_r_expl = "S-coordinate at W-points" ;
:Cs_r = -0.9287272f, -0.8093643f, -0.7145184f, -0.6376433f, -0.5730692f, -0.5156592f, -0.4607052f, -0.4042644f, -0.3440788f, -0.2807264f, -0.2178818f, -0.1607245f, -0.1133185f, -0.07704455f, -0.05091174f, -0.0327879f, -0.02043305f, -0.01199137f, -0.006092094f, -0.001777454f ;
:Cs_r_expl = "S-coordinate stretching curves at RHO-points" ;
:ntimes = 216000 ;
:ndtfast = 48 ;
:dt = 720.f ;
:dtfast = 15.f ;
:nwrt = 120 ;
:ntsavg = 1 ;
:ntsavg_expl = "starting time-step for accumulation of time-averaged fields" ;
:navg = 120 ;
:navg_expl = "number of time-steps between time-averaged records" ;
:visc2 = 0.f ;
:visc2_expl = "Laplacian mixing coefficient for momentum" ;
:visc2_units = "meter2 second-1" ;
:tnu2 = 0.f ;
:tnu2_expl = "Laplacian mixing coefficient for tracers" ;
:tnu2_units = "meter2 second-1" ;
:Zob = 0.01f ;
:Zob_expl = "VonKarman/Prandtl log layer : roughness scale" ;
:Zob_units = "meter" ;
:Cdb_max = 0.1f ;
:Cdb_min = 0.0001f ;
:Cdb_expl = "Range of quadratic drag coefficient\000M" ;
:rho0 = 1025.f ;
:rho0_expl = "Mean density used in Boussinesq approximation" ;
:rho0_units = "kilogram meter-3" ;
:gamma2 = 1.f ;
:gamma2_expl = "Slipperiness parameter" ;
:x_sponge = 200000.f ;
:v_sponge = 800.f ;
:sponge_expl = "Sponge parameters : extent (m) & viscosity (m2.s-1)" ;
:SRCS = "main.F step.F read_inp.F timers.F init_scalars.F init_arrays.F set_weights.F set_scoord.F ana_grid.F setup_grid1.F setup_grid2.F set_nudgcof.F ana_initial.F analytical.F setup_kwds.F check_kwds.F check_srcs.F check_switches1.F check_switches2.F zoom.F set_nudgcof_fine.F step2d.F u2dbc.F v2dbc.F zetabc.F obc_volcons.F pre_step3d.F step3d_t.F step3d_uv1.F step3d_uv2.F prsgrd.F rhs3d.F set_depth.F omega.F uv3dmix.F t3dmix.F smagorinsky.F u3dbc.F v3dbc.F t3dbc.F rho_eos.F ab_ratio.F alfabeta.F ana_vmix.F bvf_mix.F lmd_vmix.F lmd_skpp.F lmd_bkpp.F lmd_swfrac.F lmd_wscale.F diag.F wvlcty.F checkdims.F grid_stiffness.F bio_diag.F get_date.F lenstr.F closecdf.F ana_initracer.F insert_node.F nf_fread.F get_grid.F get_initial.F def_grid.F def_his.F def_rst.F set_avg.F wrt_grid.F wrt_his.F wrt_rst.F wrt_avg.F def_diags.F wrt_diags.F output.F wrt_diags_avg.F set_diags_avg.F put_global_atts.F get_vbc.F set_cycle.F get_wwave.F get_tclima.F get_uclima.F get_ssh.F get_sss.F get_smflux.F get_stflux.F get_srflux.F get_sst.F get_tides.F clm_tides.F get_bulk.F bulk_flux.F get_bry.F nf_read_bry.F MPI_Setup.F MessPass2D.F MessPass3D.F exchange.F biology.F sediment.F bbl.F init_floats.F wrt_floats.F step_floats.F rhs_floats.F interp_rho.F def_floats.F init_arrays_floats.F random_walk.F get_initial_floats.F init_sta.F wrt_sta.F step_sta.F interp_sta.F def_sta.F init_arrays_sta.F AMRDIR AGRIFZOOM/AGRIF_YOURFILES" ;
:CPP-options = "REGIONAL BENGUELA OPENMP TIDES OBC_EAST OBC_NORTH OBC_SOUTH SOLVE3D UV_COR UV_ADV SSH_TIDES UV_TIDES TIDERAMP CURVGRID SPHERICAL MASKING AVERAGES AVERAGES_K SALINITY NONLIN_EOS SPLIT_EOS QCORRECTION SFLX_CORR DIURNAL_SRFLUX BULK_FLUX BULK_EP BULK_SMFLUX BULK_WVEC BULK_WSTR SPONGE CLIMATOLOGY ZCLIMATOLOGY M2CLIMATOLOGY M3CLIMATOLOGY TCLIMATOLOGY ZNUDGING M2NUDGING M3NUDGING TNUDGING FRC_BRY Z_FRC_BRY M2_FRC_BRY M3_FRC_BRY T_FRC_BRY ANA_BSFLUX ANA_BTFLUX UV_VIS2 MIX_GP_UV TS_DIF2 MIX_GP_TS CLIMAT_TS_MIXH LMD_MIXING LMD_SKPP LMD_BKPP LMD_RIMIX LMD_CONVEC OBC_M2FLATHER OBC_M3ORLANSKI OBC_TORLANSKI M2FILTER_FLAT" ;
staalstrom
Re: convert sigma coordinate to depth coordinate
#2 Unread post by staalstrom »
Hallo
Here's a matlab script to convert from sigma to z coordinates.
% USAGE: z=zdepth_roms(h,hc,theta,b,N)
% z z-coordinate center of layer (m)
% h depth (m)
% hc = 20;
% theta = 5;
% b = 0.6;
% N number of layers
function z=zdepth_roms(h,hc,theta,b,N)
% Center of layers
ds=1/N;
s = -1+ds/2:ds:0-ds/2;
A = sinh(theta*s)/sinh(theta);
B = (tanh(theta*(s+.5))-tanh(theta*.5))/(2*tanh(theta*.5));
C = (1-b)*A + b*B;
z = hc*s + (h-hc)*C;
Andre Staalstrom
fdaryabor
#3 Unread post by fdaryabor »
Hi my friend
Thanks so much for your guide.
I have model output to following form for 5 years.
roms_avg_Y1M1,roms_avg_Y1M2,...,roms_avg_Y1M12
roms_avg_Y2M1,roms_avg_Y2M2,...,roms_avg_Y2M12
roms_avg_Y3M1,roms_avg_Y3M2,...,roms_avg_Y3M12
roms_avg_Y4M1,roms_avg_Y4M2,...,roms_avg_Y4M12
roms_avg_Y5M1,roms_avg_Y5M2,...,roms_avg_Y5M12
for example size(roms_avg_Y1M1)
ans =
30 20 104 102
time record for first month from model of 1 year=30(30 day)
N number of layers
eta_rho = 104 and xi_u = 102
Totally for per file we have 13 variables and have following metrics
function [n3dvars,varcell,L,M,N]=get_3dvars(nc)
n3dvars =
13
varcell =
'zeta'
'ubar'
'vbar'
'u'
'v'
'temp'
'salt'
'omega'
'w'
'AKt'
'hbl'
'hbbl'
'bostr'
L =
103 102 103 102 103 103 103 103 103 103 103 103 103
M =
104 104 103 104 103 104 104 104 104 104 104 104 104
N =
1 1 1 20 20 20 20 21 20 21 1 1 1
I want computing mean monthly climatology for first month from 1 year until 5 year,second month from 1 year until 5 year,...,12th month from 1 year until 5 year. could you please guide or help me for a matlab script for computing it.
Best Regards
F.Daryabor
magaesco
#4 Unread post by magaesco »
staalstrom wrote:Hallo
% h depth (m)
% hc = 20;
% theta = 5;
% b = 0.6;
% Center of layers
ds=1/N;
C = (1-b)*A + b*B;
Andre Staalstrom
maga O teu comentario está á espera de ser moderado. Marzo 11, 2011 ás 23:54 | Responder
I understand what parameter I need to use, but Could you tell me please which depth is “h”¿¿??
Because, from roms configuration I get the following:
N = 32; vertical levels
theta_s = 6.; theta surface control parameter
theta_b = 0.; theta b bottom control parameter
hc = 0.9;
nacholibre
#5 Unread post by nacholibre »
That is the depth at each grid cell. It is saved in the grid file and all history files with the name "h".
#6 Unread post by wilkin »
That code is not correct for sea level zeta not equal to zero.
It also is not applicable to coordinate stretching options other than the old default ocean-s-coordinate.
The coordinate stretching is explained in detail here:
https://www.myroms.org/wiki/index.php/V ... coordinate
There are directions to accurate and up-to-date Matlab code (Utility/scoord.m) for computing the z coordinate at this post:
viewtopic.php?f=13&t=1240&p=4334&hilit= ... oord#p4334
