Typos
Discussions, suggestions and corrections to ROMS/TOMS documentation currently under developement.
Typos
#1 Unread post by arango »
Use this thread to point out typographical errors in the ROMS/TOMS user manual.
bjorn
Typo in the model formulation
#2 Unread post by bjorn »
Not a big deal, but the documentation should be correct.
In the v momentum equation, -fu should changed to +fu
Bjørn Ådlandsvik
stef
#3 Unread post by stef »
In the vertical boundary conditions for z=zeta there should be the total time derivative of zeta for the w condition. If I understand correctly, the advective terms are missing.
rsoutelino
Re: Typos
#4 Unread post by rsoutelino »
I was browsing on wikiroms User Guide > Source Code > Functionals section and I think I found a typo regarding ana_hmixcoef.h. It says "For providing analytic atmospheric cloud fraction." in spite of something related to horizontal mixing.
Kind regards,
Rafael
rsoutelino
Typo in Wikiroms Functionals Section
#5 Unread post by rsoutelino »
Hi, I found another typo at WikiROMS Functionals section:
ana_nudgcoef.h is defined as: "For providing analytic atmospheric humidity"
Kind Regards,
Rafael
Re: Typos
#6 Unread post by kate »
Right you are, thanks!
kchu.tw
Re: Typos
#7 Unread post by kchu.tw »
I guess that there is a typo in P.91 of ROMS Manual.
The "ana_sbflux" in the sixth line from section 7.2.6 (Model forcing) is not in /Functionals.
Should it be "ana_srflux" ?
Best regards, Kai-Cheng, Hu.
Re: Typos
#8 Unread post by kate »
You are most likely correct although I don't have the manual with me. Thanks!
kthyng
Re: Typos
#9 Unread post by kthyng »
The WikiROMS page on open boundary conditions (https://www.myroms.org/wiki/index.php/B ... _condition) appears to have the multiplying gravity terms mixed up between the Flather and Chapman boundary conditions. The Flather boundary condition should have \sqrt{g/h} not \sqrt{gD} and vice versa for Chapman.
kthyng
Re: Typos
#10 Unread post by kthyng »
I think there is another typo on WikiROMS in the section for horizontal and vertical advection (https://www.myroms.org/wiki/index.php/N ... _Advection). The units don't seem to be working out in the equation for advection of tracer C, or perhaps I am missing something.
kthyng
Re: Typos
#11 Unread post by kthyng »
At risk of being super annoying, I have another possible typo:
On WikiROMS, under Equations of Motion > Horizontal Boundary Conditions (https://www.myroms.org/wiki/index.php/E ... Conditions), it says
Boundary conditions on these masked regions are straightforward, with a choice of no-slip or free-slip walls.
However, the code in Utilities/metrics.F, when masking is defined for the simulation, says (Line 521)
Set no-slip boundary conditions on land-mask boundaries regardless of supplied value of gamma2.
Re: Typos
#12 Unread post by kate »
kthyng wrote:The WikiROMS page on open boundary conditions (https://www.myroms.org/wiki/index.php/B ... _condition) appears to have the multiplying gravity terms mixed up between the Flather and Chapman boundary conditions. The Flather boundary condition should have \sqrt{g/h} not \sqrt{gD} and vice versa for Chapman.
I'm glad someone is finally reading this.
Perhaps you are missing the fact that u,v still have units of m/s while omega is simply 1/s.
The code here is setting the land mask on psi points, used in:
! Compute flux-components of the horizontal divergence of the stress
! tensor (m5/s2) in XI- and ETA-directions.
It seems that only the outside walls can have free slip or no slip if I understand the code correctly.
kthyng
Re: Typos
#13 Unread post by kthyng »
I think that the terms are inconsistent regardless of omega's units because the time derivative term has an extra length scale in the denominator. Also, with units of 1/s, the omega term then has two extra length scales in it, relative to the x- and y-derivative terms.
That is my understanding as well. I do think it is then worth noting that masked regions in the interior of numerical domains are always no-slip.
Re: Typos
#14 Unread post by kate »
kthyng wrote:I think that the terms are inconsistent regardless of omega's units because the time derivative term has an extra length scale in the denominator. Also, with units of 1/s, the omega term then has two extra length scales in it, relative to the x- and y-derivative terms.
You should know that m is like 1/dx, n is like 1/dy, both having units of 1/m.
You are right. It didn't used to be the case (when I understood what was going on), but Sasha has touched everything.
kapitzah
Re: Typos
#15 Unread post by kapitzah »
In the explanation of cppdefs.h in WikiROMS UV_COR links to a page which has the wrong content. What is shown there is actually a copy of the page pointed to by UV_ADV.
kapitzah
Re: Typos
#16 Unread post by kapitzah »
On page 123 of the user manual right after formula (244) the value of z for sigma=-1 should be -h (not h).
kapitzah
Re: Typos
#17 Unread post by kapitzah »
In the explanation of variable "Vstretching" the possible (and default) value of 4 is not present.
Re: Typos
#18 Unread post by kate »
Are you sure you have the 2012 manual?
kapitzah
Re: Typos
#19 Unread post by kapitzah »
kate wrote:Are you sure you have the 2012 manual?
OK, my fault. My comment referred to the 2010 manual and not to the draft.
But the issues concerning "Vstretching" and "UV_COR" are still open since they refer to the Wiki. To be more specific here are the pages I refer to:
www.myroms.org/wiki/index.php/Variables#Vstretching
www.myroms.org/wiki/index.php/UV_COR
Re: Typos
#20 Unread post by kate »
Please contact Dave Robertson if you would like to become a wiki editor.
