My ROMS application is finally running; however, all outputs are zero. I'm forcing the application with tides and have set up initial and bounary files too. To the best of my knowledge, all of these files have reasonable inputs and each variable has values(!), but my outputs are telling me otherwise. There is clearly some confliction somewhere but I've not been able to find examples of other users having similar outputs (i.e. nothing) without errors in tow.
Some information on my set-up:
5400 ntimes Number of timesteps for 3-D equations.
40.000 dt Timestep size (s) for 3-D equations.
10 ndtfast Number of timesteps for 2-D equations between
F LcycleRST Switch to recycle time-records in restart file.
10800 nRST Number of timesteps between the writing of data
into restart fields.
90 ninfo Number of timesteps between print of information
to standard output.
15 nSTA Number of timesteps between the writing of data
the stations file.
90 nHIS Number of timesteps between the writing fields
into history file.
1.0000E+01 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
1.0000E+01 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
2.000 Tcline S-coordinate surface/bottom layer width (m) used
1.000 dstart Time-stamp assigned to model initialization (days).
1.000 tide_start Reference time origin for tidal forcing (days).
for tracer 02: salt
for 3D momentum.
33.000 S0 Background salinity (PSU) constant.
1025.000 R0 Background density (kg/m3) used in linear Equation
of State.
0.0000E+00 Scoef Saline contraction coefficient (1/PSU).
Output Restart File: output/ocean_rst.nc
Output History File: output/ocean_his.nc
Output Stations File: output/ocean_sta.nc
Input Grid File: roms_grid_nwess00.nc
Input Nonlinear Initial File: nwess_ini_0.nc
Input Boundary File: ocean_bry.nc
Station positions File: stations.in
zeta 1 Chapman Chapman Chapman Chapman
ubar 1 Flather Flather Flather Flather
vbar 1 Flather Flather Flather Flather
temp 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
salt 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
tke 1 Gradient Gradient Gradient Gradient
NWESS_0 NWESS_O
ADD_FSOBC Adding tidal elevation to processed OBC data.
ADD_M2OBC Adding tidal currents to processed OBC data.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
RAMP_TIDES Ramping tidal forcing for one day.
SALINITY Using salinity.
SPHERICAL Spherical grid configuration.
STATIONS Writing out station data.
TS_A4VADVECTION Fourth-order Akima vertical advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
0 0 00:00:00 0.000000E+00 3.774337E+04 3.774337E+04 4.971514E+15
(000,000,00) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
DEF_HIS - creating history file: output/ocean_his.nc
90 0 01:00:00 0.000000E+00 3.772642E+04 3.772642E+04 4.971514E+15
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000002
180 0 02:00:00 0.000000E+00 3.772607E+04 3.772607E+04 4.971514E+15
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000003
270 0 03:00:00 0.000000E+00 3.772596E+04 3.772596E+04 4.971514E+15
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000004
360 0 04:00:00 0.000000E+00 3.772592E+04 3.772592E+04 4.971514E+15
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000005
450 0 05:00:00 0.000000E+00 3.772590E+04 3.772590E+04 4.971514E+15
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000006
540 0 06:00:00 0.000000E+00 3.772589E+04 3.772589E+04 4.971514E+15
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000007
630 0 07:00:00 0.000000E+00 3.772588E+04 3.772588E+04 4.971514E+15
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000008
etc.
Have I got some odd preprocessor options selected? I've tried all sorts of timesteps, time vectors etc. I've not been able to find conflicting days/seconds time units anywhere. I've created my input netcdf files by adapting scripts in Roms_tools, if that adds anything. I've had other applications running on this system so I don't think it's a problem with that.
If it's something simple and/or obvious and/or daft to you then I'd be most grateful if you'd share it with me as I've hit a wall!
Thanks in advance,
Sophie
