Hi everyone.
I finally have roms running on linux (Red Hat vs. 5.2) and I have successfully run the upwelling test case. However, once I intent to use ROMS-SWAN coupling model, the inlet test case seemed more realistic to my case. For that, I installed mpich2 and mct library. Then, I compiled it just like that:
./build.bash -j 8
And I got the executable oceanG without any problem. But when I tried to run it:
mpiexec -np 8 ./oceanG ./coupling_inlet_test.in
I've got the error:
Coupled Input File name = ./coupling_inlet_test.in
MOD_COUPLER - Number assigned processors: 007
not equal to spawned MPI nodes: 001
Once I've got a 8 processor pc, in my coupling_inlet_test.in I have the following thread definition:
Nthreads(ocean) = 4
Nthreads(waves) = 4
I don't know what is happening. I tried to re-install mpich2 and recompile MCT but it didn't work. It seems that mpich only see 1 processor (node). Anybody has seen this error before? Thank you very much.
Ivana
ROMS-SWAN coupling test case. Missing mpi nodes.
- Location: Faculdade de Ciências, Universidade de Lisboa
Re: ROMS-SWAN coupling test case. Missing mpi nodes.
Problem solved!
The paths to the mpirun and mpiexec were by default to openmpi library
Ivana
![Smile :)](./images/smilies/icon_smile.gif)
Ivana
