Good morning all,
Do you have any idea what can I do? I explain my simulation and my problems below. Here it is attached the initial file (inifile.nc),the forcing file (frc_bulk.nc), the cpp file (westmed.h), and the ROMS input file (westmed.in).
Many thanks in advance.
The main features of my simulation are:
Lm == 59 ! Number of I-direction INTERIOR RHO-points
Mm == 43 ! Number of J-direction INTERIOR RHO-points
N == 15 ! Number of vertical levels
NTIMES == 10000
DT == 30d0
NDTFAST == 5
Vtransform == 1 ! transformation equation
Vstretching == 1 ! stretching function
THETA_S == 6.0d0 ! surface stretching parameter
THETA_B == 0.d0 ! bottom stretching parameter
TCLINE == 10.0d0 ! critical depth (m)
The activated CPP:
#ifdef TS_U3ADV_SPLIT
# define TS_DIF4
# define DIFF_GRID
# define MIX_GEO_TS
#ifdef UV_U3ADV_SPLIT
# define UV_VIS4
# define VISC_GRID
# define MIX_GEO_UV
#define BULK_FLUXES
#undef LONGWAVE
#undef SALINITY
#define SOLAR_SOURCE
#define SPLINES
#undef QCORRECTION
#undef SRELAXATION
#undef SPONGE
#ifdef LMD_MIXING
# define LMD_RIMIX
# define LMD_CONVEC
# define LMD_SKPP
# define LMD_NONLOCAL
#undef TCLIMATOLOGY
#undef TCLM_NUDGING
I am trying to run ROMS. It starts , but it blows-up after having computed 4 minutes time:
0 0 00:00:01 1.515601E-03 8.226723E+03 8.226724E+03 1.137087E+15
(14,09,14) 1.677379E-04 3.639111E-04 0.000000E+00 3.901709E-01
DEF_HIS - creating history file: westmed_his.nc
1 0 00:00:31 1.560854E-03 8.226681E+03 8.226682E+03 1.137087E+15
(46,15,15) 1.427931E-03 2.246364E-03 6.938058E-05 2.816670E+00
2 0 00:01:01 1.691695E-03 8.226640E+03 8.226642E+03 1.137087E+15
(31,27,15) 1.731919E-04 2.605589E-04 1.364881E-01 5.444033E+00
3 0 00:01:31 1.922482E-03 8.226602E+03 8.226604E+03 1.137087E+15
(31,27,15) 2.390360E-04 3.932507E-04 1.219707E-01 8.060204E+00
4 0 00:02:01 2.273733E-03 8.226567E+03 8.226569E+03 1.137087E+15
(31,27,15) 3.047909E-04 5.254843E-04 9.950828E-02 1.066188E+01
5 0 00:02:31 2.766925E-03 8.226534E+03 8.226537E+03 1.137087E+15
(31,27,15) 3.706933E-04 6.575518E-04 7.113620E-02 1.324395E+01
6 0 00:03:01 3.419784E-03 8.226505E+03 8.226508E+03 1.137087E+15
(37,31,15) 4.478399E-04 7.782489E-04 4.986929E-02 1.580115E+01
7 0 00:03:31 4.243094E-03 8.226478E+03 8.226482E+03 1.137087E+15
(47,14,15) 7.060503E-03 1.023748E-02 3.565038E-02 1.832808E+01
8 0 00:04:01 5.240034E-03 8.226454E+03 8.226460E+03 1.137087E+15
(29,26,15) 7.358719E-04 1.392776E-03 5.624096E-02 2.081915E+01
WRT_RST - wrote re-start fields (Index=1,1) into time record = 0000001
ROMS blows-up after a few time-steps
westmed.h
- (1.22 KiB) Downloaded 583 times
westmed.in
- (100.69 KiB) Downloaded 620 times
- WESTMED_grd.nc
- (405.98 KiB) Downloaded 590 times
- inifile.nc
- (672.84 KiB) Downloaded 584 times
- frc_bulk.nc
- (773.92 KiB) Downloaded 565 times
Re: ROMS blows-up after a few time-steps
1. I would look at the rst file where it saved the bad state in ncview (or whatever) to see where it went bad. Top, bottom or middle? u/v or T/S? Shallow or deep water?
2. I would turn on either GLS_MIXING or LMD_MIXING - I don't see either in your listing.
3. Currently recommended values of Vstretching and friends are more like:(which of course needs a new ini file to be created.)
4. I would try a shorter timestep.
Oh, and you don't have many grid points at all. Is it enough? Looking at your grid file, you have 4-5 independent patches of water - you should mask out the unconnected edge ones and the lake. Also, you can save on some grid points by truncating your easternmost part of the domain which is all land.
Vtransform == 2 ! transformation equation
Vstretching == 4 ! stretching function
THETA_S == 7.0d0 ! surface stretching parameter
THETA_B == 2.0d0 ! bottom stretching parameter
TCLINE == 250.0d0 ! critical depth (m)
Hi Kate,
thank you very much for your recommedations. I just try it and, if I have more questions, I ask you again. I have already tried with GLS_MIXING and it works! I'll post the results for the next improved simulation.
Many thanks,
Josep Maria Solé
Many thanks,
Josep Maria Solé
Good morning,
I have the same problem again. I attach the restart file (westmed_rst.nc), the forcing file (frc_bulk2.nc), the initial file (inifile2.nc), the input file (westmed.in) and the log file (westmed.log). It just blows up after 40 min of computation time approximately. My activated CPP options are:
# define TS_DIF4
# define DIFF_GRID
# define MIX_GEO_TS
# define UV_VIS4
# define VISC_GRID
# define MIX_GEO_UV
#define BULK_FLUXES
#undef LONGWAVE
#undef SALINITY
#define SPLINES
#undef QCORRECTION
#undef SRELAXATION
#define SPONGE
#undef GLS_MIXING
#define LMD_MIXING
#ifdef LMD_MIXING
# define LMD_RIMIX
# define LMD_CONVEC
# define LMD_SKPP
#undef TCLIMATOLOGY
#undef TCLM_NUDGING
#define TS_FIXED
#undef TS_ADVECTION
#undef TS_C4ADVECTION
Thank you very much for your help
Josep Maria Solé
# define TS_DIF4
# define DIFF_GRID
# define MIX_GEO_TS
# define UV_VIS4
# define VISC_GRID
# define MIX_GEO_UV
#define BULK_FLUXES
#undef LONGWAVE
#undef SALINITY
#define SPLINES
#undef QCORRECTION
#undef SRELAXATION
#define SPONGE
#undef GLS_MIXING
#define LMD_MIXING
#ifdef LMD_MIXING
# define LMD_RIMIX
# define LMD_CONVEC
# define LMD_SKPP
#undef TCLIMATOLOGY
#undef TCLM_NUDGING
#define TS_FIXED
#undef TS_ADVECTION
Josep Maria Solé
westmed.in
- (100.64 KiB) Downloaded 606 times
westmed.log
- (33.01 KiB) Downloaded 559 times
- inifile2.nc
- (16.92 MiB) Downloaded 496 times
- frc_bulk2.nc
- (9.93 MiB) Downloaded 568 times
- westmed_rst.nc
- (64.58 MiB) Downloaded 688 times
Did you mean to define TS_FIXED? That means T and S will not be evolving. Whatever density field they prescribe, the velocities will be spinning up to match. Perhaps your T/S fields provide strong density gradients that you have prevented the model from damping out or turning into a wave field.
Off topic comment/question:
When doing a pressure gradient test (i.e. all forcing and initial fields zero except for an arbitrary stratification), initially velocities are due to pressure gradient error but eventually the advection and difussion of T,S will also be involved in the development of velocities. My question is: seems that fixing T and S would be a good way of evaluating the pressure gradient's evolution without other factors chipping in, am I right?
thanks!
thanks!
