software or matlab script for edit netcdf bathymetry file
flcastej
Location: Technical University of Cartagena,Murcia, Spain
#1 Unread post by flcastej »
Hi everybody!!
I will like to know if there are any software o matlab script that allow me to modify my netcdf bathy file. Sometimes I detected an error in some points on the bathymetry and I will like to change this values, but I don't know how. it could be something like the editmask.m used to modify the mask, but for the bathymetry.
Thanks in advice
andres
Re: software or matlab script for edit netcdf bathymetry fil
#2 Unread post by andres »
We developed a tool to modify the depth in the roms_grd.nc file generated by ROMSTOOLS. For the moment it just changes the value of a specific matrix and leaves everything else as it is, which most probably is a bad idea, but here is the code for you to improve it.
It is based on a previous idea to modify the input bathymetry file (e.g. etopo2.nc)
viewtopic.php?f=23&t=990
Send me an email if you need details on how to use it.
edit_grdbat.m
Basic GRD file editor
(21.49 KiB) Downloaded 1019 times
Andres Sepulveda
Geophysics Department
University of Concepcion
flcastej
#3 Unread post by flcastej »
Thanks a lot!!
Tomorrow I start my holidays, so I will look the code and test it for my case at the end August. But thanks a lot for your answer, the code and the link cause I need to change the points by hand too.
mashinde
Location: Indian Institute of Tropical Meteorology, Pune, INDIA
#4 Unread post by mashinde »
Hi Andres Sepulveda,
I am working on ROMS application in the Mediterranean sea. I need to modify manually the bathymetry after smoothing to reach the required sill depth at Gibraltar straits. I had seen this post and tried the script. But I don't know how to use it properly. Is there any user manual for the edit bathymetry scirpt. The wiki is also not working.
Thanking you
andres
#5 Unread post by andres »
Our wiki server died and all the documentation was lost.
Try to contact me in Skype (username: andres_udec) to explain you how it works.
mashinde wrote:Hi Andres Sepulveda,
Thanking you
Andres Sepulveda
