diagnostics in roms
xqzhang
diagnostics in roms
#1 Unread post by xqzhang »
I am doing a realistic run in the Gulf of Mexico from 2003 to 2011.
The model has run through 2003 and 2010. For the last year, I want to turn on the diagnostics for momentum.
So I added the flag #define DIAGNOSTICS_UV in the header file.
When I tried to submit my job, I got the error message asking for previous diagnostic output.
And I have LDEFOUT == T in the input file.
Pls see the following error message:
******* 14975 00:00:00 1.487406E-02 7.814395E+03 7.814410E+03 1.209005E+14
DEF_HIS - inquiring history file: ocean_his_0174.nc
DEF_DIAGS - inquiring diagnostics file: ocean_dia_0029.nc
ocean_dia_0029.nc
call from: def_diags.F
Since the diagnostics are quite huge, I only want the diagnostic output for one year.
How could I solve this problem? Any suggestions? Thanks a lot!
Re: diagnostics in roms
You can trick ROMS into thinking this is the start of a new run instead of a continuation of an old one by changing NRREC to 0. You might have to provide it with a file containing only one time record as the initial condition.
xqzhang
#3 Unread post by xqzhang »
Kate,
Thanks for the reply. I will give it a try.
