dhtjtks
#1 Unread post by dhtjtks »
When I tried to run ROMS (example case, 'upwelling'), I had this error. I tried to use both netcdf-3.6.3 and netcdf-4.1.1, however, both cases have same errors. What does it mean?
dhtjtks
# Alabama Supercomputer Center - PBS Prologue
# Your job id is : 622741
# Your job name is : runSCRIPT
# Your job's queue is : large-serial
# Your username for this job is : usajxl
# Your group for this job is : usacveng
# Your job used :
# 1 CPU on dmc87
# Your job started at : Mon Jan 23 13:39:42 CST 2012
setting dmc scratch directory
===== Summary of your script job =====
The script file is: run
The time limit is 240:00:00 HH:MM:SS.
The target directory is: /home/usajxl/jung/upwelling
The working directory is: /tmp/usajxl.runSCRIPT.622741
The memory limit is: 1gb
The job will start running after: 201201231339.03
Look for: runSCRIPT in queue: large-serial
Monday - January 23, 2012 - 1:39:44 PM
Wind-Driven Upwelling/Downwelling over a Periodic Channel
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /apps/intel/Compiler/11.1/046/bin/intel64/ifort
Compiler flags : -heap-arrays -fp-model precise -ip -O3 -free -free -free
SVN Revision :
Local Root : /home/usajxl/ROMS/src
Header Dir : /home/usajxl/jung/upwelling
Header file : upwelling.h
Analytical Dir: /home/usajxl/ROMS/src/ROMS/Functionals
Resolution, Grid 01: 0041x0080x016, Parallel Threads: 1, Tiling: 001x001
1440 ntimes Number of timesteps for 3-D equations.
300.000 dt Timestep size (s) for 3-D equations.
288 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
72 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
72 nAVG Number of timesteps between the writing of
1 ntsDIA Starting timestep for the accumulation of output
72 nDIA Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
25.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
of State.
0.0000E+00 Scoef Saline contraction coefficient (1/PSU).
T Dout(M2rate) Write out 2D momentun acceleration.
T Dout(M2pgrd) Write out 2D momentum pressure gradient.
T Dout(M2fcor) Write out 2D momentum Coriolis force.
T Dout(M2hadv) Write out 2D momentum horizontal advection.
T Dout(M2xadv) Write out 2D momentum horizontal X-advection.
T Dout(M2yadv) Write out 2D momentum horizontal Y-advection.
T Dout(M2hvis) Write out 2D momentum horizontal viscosity.
T Dout(M2xvis) Write out 2D momentum horizontal X-viscosity.
T Dout(M2yvis) Write out 2D momentum horizontal Y-viscosity.
T Dout(M2sstr) Write out 2D momentum surface stress.
T Dout(M2bstr) Write out 2D momentum bottom stress.
T Dout(M3rate) Write out 3D momentun acceleration.
T Dout(M3pgrd) Write out 3D momentum pressure gradient.
T Dout(M3fcor) Write out 3D momentum Coriolis force.
T Dout(M3hadv) Write out 3D momentum horizontal advection.
T Dout(M3xadv) Write out 3D momentum horizontal X-advection.
T Dout(M3yadv) Write out 3D momentum horizontal Y-advection.
T Dout(M3vadv) Write out 3D momentum vertical advection.
T Dout(M3hvis) Write out 3D momentum horizontal viscosity.
T Dout(M3xvis) Write out 3D momentum horizontal X-viscosity.
T Dout(M3yvis) Write out 3D momentum horizontal Y-viscosity.
T Dout(M3vvis) Write out 3D momentum vertical viscosity.
T Dout(iTrate) Write out rate of change of tracer 01: temp
T Dout(iTrate) Write out rate of change of tracer 02: salt
T Dout(iThadv) Write out horizontal advection, tracer 01: temp
T Dout(iThadv) Write out horizontal advection, tracer 02: salt
T Dout(iTxadv) Write out horizontal X-advection, tracer 01: temp
T Dout(iTxadv) Write out horizontal X-advection, tracer 02: salt
T Dout(iTyadv) Write out horizontal Y-advection, tracer 01: temp
T Dout(iTyadv) Write out horizontal Y-advection, tracer 02: salt
T Dout(iTvadv) Write out vertical advection, tracer 01: temp
T Dout(iTvadv) Write out vertical advection, tracer 02: salt
T Dout(iThdif) Write out horizontal diffusion, tracer 01: temp
T Dout(iThdif) Write out horizontal diffusion, tracer 02: salt
T Dout(iTxdif) Write out horizontal X-diffusion, tracer 01: temp
T Dout(iTxdif) Write out horizontal X-diffusion, tracer 02: salt
T Dout(iTydif) Write out horizontal Y-diffusion , tracer 01: temp
T Dout(iTydif) Write out horizontal Y-diffusion , tracer 02: salt
T Dout(iTvdif) Write out vertical diffusion, tracer 01: temp
T Dout(iTvdif) Write out vertical diffusion, tracer 02: salt
Output Diagnostics File: ocean_dia.nc
Tile partition information for Grid 01: 0041x0080x0016 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 41 1 80 52480
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 -1.50 42.50 0.50 81.50 RHO-points
0 -2.00 42.00 0.50 81.50 U-points
0 -1.50 42.50 0.00 81.00 V-points
zeta 1 Periodic Closed Periodic Closed
ubar 1 Periodic Closed Periodic Closed
vbar 1 Periodic Closed Periodic Closed
u 1 Periodic Closed Periodic Closed
v 1 Periodic Closed Periodic Closed
temp 1 Periodic Closed Periodic Closed
salt 1 Periodic Closed Periodic Closed
UPWELLING Wind-Driven Upwelling/Downwelling over a Periodic Channel
ANA_GRID Analytical grid set-up.
ANA_VMIX Analytical vertical mixing coefficients.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Thread # 0 (pid= 26230) is active.
Vertical S-coordinate System:
15 -0.0625000 -0.0019442 -0.809 -0.806 -1.348 -1.589
14 -0.1250000 -0.0078455 -1.668 -1.661 -2.966 -3.687
13 -0.1875000 -0.0179119 -2.580 -2.568 -4.867 -6.321
12 -0.2500000 -0.0324983 -3.549 -3.531 -7.077 -9.535
11 -0.3125000 -0.0521190 -4.581 -4.558 -9.630 -13.397
10 -0.3750000 -0.0774659 -5.686 -5.656 -12.573 -17.996
9 -0.4375000 -0.1094327 -6.875 -6.837 -15.967 -23.445
8 -0.5000000 -0.1491465 -8.162 -8.114 -19.889 -29.890
7 -0.5625000 -0.1980075 -9.564 -9.506 -24.435 -37.512
6 -0.6250000 -0.2577387 -11.104 -11.034 -29.721 -46.531
5 -0.6875000 -0.3304460 -12.808 -12.724 -35.892 -57.218
4 -0.7500000 -0.4186931 -14.709 -14.609 -43.121 -69.903
3 -0.8125000 -0.5255915 -16.846 -16.726 -51.622 -84.987
2 -0.8750000 -0.6549105 -19.266 -19.124 -61.651 -102.953
1 -0.9375000 -0.8112096 -22.028 -21.859 -73.518 -124.388
0 -1.0000000 -1.0000000 -25.200 -25.000 -87.600 -150.000
Time Splitting Weights: ndtfast = 30 nfast = 42
37 0.0473537721847153 0.0063819206892258 0.8558961515079423 0.9882658063583315
42 0.0109897377911118 0.0003663245930371 1.0000000000000004 0.9999999999999999
Minimum X-grid spacing, DXmin = 1.00000000E+00 km
Maximum X-grid spacing, DXmax = 1.00000000E+00 km
Minimum Y-grid spacing, DYmin = 1.00000000E+00 km
Maximum Y-grid spacing, DYmax = 1.00000000E+00 km
Minimum Z-grid spacing, DZmin = 8.08965824E-01 m
Maximum Z-grid spacing, DZmax = 2.56123321E+01 m
Minimum barotropic Courant Number = 2.22358627E-01
Maximum barotropic Courant Number = 5.42494240E-01
Maximum Coriolis Courant Number = 2.47800000E-02
Maximum grid stiffness ratios: rx0 = 6.931666E-02 (Beckmann and Haidvogel)
rx1 = 8.661243E-01 (Haney)
Initial basin volumes: TotVolume = 3.8843755884E+11 m3
MinVolume = 8.4521383562E+05 m3
MaxVolume = 2.5612332106E+07 m3
Max/Min = 3.0302783777E+01
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00001440)
0 0 00:00:00 0.000000E+00 6.585677E+02 6.585677E+02 3.884376E+11
(00,00,00) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
DEF_HIS - creating history file: ocean_his.nc
DEF_AVG - creating average file: ocean_avg.nc
DEF_DIAGS - creating diagnostics file: ocean_dia.nc
1 0 00:05:00 6.479408E-13 6.585677E+02 6.585677E+02 3.884376E+11
(01,01,01) 1.069435E-09 1.950204E-06 0.000000E+00 9.216783E-06
2 0 00:10:00 9.293195E-12 6.585677E+02 6.585677E+02 3.884376E+11
(01,02,08) 6.735167E-08 1.785829E-06 1.433648E-05 3.660353E-05
Image PC Routine Line Source
oceanS 0000000000481977 Unknown Unknown Unknown
oceanS 0000000000475173 Unknown Unknown Unknown
oceanS 000000000045D4B8 Unknown Unknown Unknown
oceanS 0000000000403FE1 Unknown Unknown Unknown
oceanS 0000000000403E2D Unknown Unknown Unknown
oceanS 0000000000403D3C Unknown Unknown Unknown
libc.so.6 00007F80D51CBBC6 Unknown Unknown Unknown
oceanS 0000000000403C39 Unknown Unknown Unknown
# Your job finished at : Mon Jan 23 13:39:50 CST 2012
# Your job requested : cput=240:00:00,mem=1gb,neednodes=1:ppn=1,nodes=1:ppn=1,walltime=336:00:00
# Your job used : cput=00:00:00,mem=0kb,vmem=0kb,walltime=00:00:08
# Your job's cpu utilization : 0%
# Your job's memory utilization (mem) : 0.00%
# Alabama Supercomputer Center - PBS Epilogue
Re: forrtl: severe (174): SIGSEGV, segmentation fault occurr
I would recompile with the USE_DEBUG flag turned on, then execute the oceanG file. It should be able to tell you line numbers then, perhaps even give array-out-of-bounds info if appropriate.
dhtjtks
#3 Unread post by dhtjtks »
kate wrote:I would recompile with the USE_DEBUG flag turned on, then execute the oceanG file. It should be able to tell you line numbers then, perhaps even give array-out-of-bounds info if appropriate.
Hi Kate,
When I turned on USE_DEBUG flag, it worked fine both in serial and parallel mode. I don't know why this happens. Anyway, it works now. Thank you so much.
dhtjtks
Don't you love it? It could be that the optimizer makes the code bigger so it wants more than 1 GB. Or it could be an optimizer bug. You do want to optimize for non-trivial runs.
cousins
#5 Unread post by cousins »
Did you ever figure out what this was? I'm getting the same thing now from a recent (608) download using SVN. Using USE_DEBUG allows it to work. Running it without USE_DEBUG but adding -g -traceback (Intel compiler 11.1) in FFLAGS yielded:
oceanS 000000000046685F set_avg_mod_mp_se 558 set_avg.f90
oceanS 000000000045B7F0 set_avg_mod_mp_se 59 set_avg.f90
oceanS 0000000000445F56 main3d_ 185 main3d.f90
oceanS 0000000000403B6F ocean_control_mod 140 ocean_control.f90
oceanS 00000000004039D5 MAIN__ 86 master.f90
oceanS 00000000004037EC Unknown Unknown Unknown
libc.so.6 000000364EC1D994 Unknown Unknown Unknown
oceanS 00000000004036F9 Unknown Unknown Unknown
Line 558 of set_avg.f90 in the Build directory is:
!  Accumulate time-averaged fields.
      ELSE IF (iic(ng).gt.ntsAVG(ng)) THEN
!  Accumulate state variables.
        IF (Aout(idFsur,ng)) THEN
          DO j=JstrR,JendR
            DO i=IstrR,IendR
558 ->        AVERAGE(ng)%avgzeta(i,j)=AVERAGE(ng)%avgzeta(i,j)+        &
     &                                 OCEAN(ng)%zeta(i,j,Kout)
I have tried:
-O2 instead of -O3
not using -ip
ulimit -s unlimited
-no-heap-arrays
without -fp-model precise
Any ideas?
Maybe it is just something to do with this version of the compiler. I had troubles with later Intel compilers so I just kept this one.
Steve
colberg
#6 Unread post by colberg »
Yes, I had the same problem with the Intel 11.x compiler recently. Needed to switch to Intel 10.x or Intel 12.x. The segmentation error only occurred when "define AVERAGES" and writing into average file.
Everything worked fine with other compiler versions...
cousins
#7 Unread post by cousins »
Bizarre. We've had no problem with earlier versions of ROMS (at least a year old) and this compiler,
Thanks for the confirmation.
Steve
cousins
#8 Unread post by cousins »
Just to close this up, Intel Composer XE 2011 SP1 9.293 is working as expected.
gaokun227
#9 Unread post by gaokun227 »
I ran into the same issue when 'AVERAGES' is defined (ROMS version 3.7 is used).
oceanM_ave 00000000004D002E set_avg_mod_mp_se 562 set_avg.f90
oceanM_ave 00000000004C47A0 set_avg_mod_mp_se 60 set_avg.f90
oceanM_ave 00000000004A56F1 main3d_ 199 main3d.f90
oceanM_ave 00000000004240EF ocean_control_mod 164 ocean_control.f90
oceanM_ave 0000000000423F05 MAIN__ 108 master.f90
oceanM_ave 0000000000423D4C Unknown Unknown Unknown
libc.so.6 0000003BE1E1D994 Unknown Unknown Unknown
oceanM_ave 0000000000423C59 Unknown Unknown Unknown
Did anyone ever figure out what the problem was and how to resolve it?
cousins
#10 Unread post by cousins »
What compiler and version are you using? Upgrading to a newer version of the compiler allowed it to work for us previously. It would be good to know what compiler version you are using to know which versions to avoid.
gaokun227
#11 Unread post by gaokun227 »
cousins wrote:What compiler and version are you using? Upgrading to a newer version of the compiler allowed it to work for us previously. It would be good to know what compiler version you are using to know which versions to avoid.
The complier I use is Intel(R) Fortran Intel(R) 64 Compiler Professional for applications running on Intel(R) 64, Version 11.1.
I just found this issue only occurred when 2D averaged fields (ubar,vbar,zeta) were defined to be written out. If I only write out 3D averaged fields (u,v,temp,salt), there is no problem at all.
Be Good, Do Right!
cousins
#12 Unread post by cousins »
That is the version we had problems with before (see earlier in the thread). The answer still is to upgrade your compiler.
Good luck,
Steve
