error while reading global attribute
pavel_fayman
#1 Unread post by pavel_fayman »
i used ROMS/TOMS Framework: September 23, 2011
when i submit the job i reseived following:
LBC_GETATT - error while reading global attribute: NLM_LBC
in input file: /home/jaguar/data1/pfayman/initial_2008_10_2.nc
call from: checkvars.F
ROMS/TOMS - Output error ............ exit_flag: 3
REASON: NetCDF: Attribute not found
What is the global attribute: NLM_LBC?
in previous version this kind error is absent
rduran
Re: error while reading global attribute
#2 Unread post by rduran »
I believe the answer (at least partial) to your question is here:
viewtopic.php?f=17&t=2411
#3 Unread post by arango »
ROMS is telling you exactly what is the problem with the NLM_LBC global attribute:
All the lateral boundary conditions C-preprocessing options were removed in ROMS 3.6. Check the following :arrow: post for more information about this new version of ROMS. Your restart file /home/jaguar/data1/pfayman/initial_2008_10_2.nc was created with an older version of the code and doesn't have the NLM_LBC global attribute. The new version of ROMS is checking the lateral boundary conditions specified in your standard input script(s) with the restart file for consistency.
I just updated the code and introduced a new C-preprocessing option NO_LBC_ATT which allows to restart ROMS with older NetCDF files. Please update. See the following :arrow: trac ticket for more information. If you activate NO_LBC_ATT, ROMS will not check the lateral boundary conditions during restart. Warning: it is your responsibility to make sure that you specified consistent lateral boundary condition when restarting.
