I am trying to implement river discharge in an idealized domain using input forcing files. I constructed my river forcing file using the CDL file that comes with ROMS trunk. The implementation has been going well in 3D runs for one river or multiple rivers.
HOWEVER, problems occur when I try to run it in 2D mode. It works well when the number of river is ONE, but when it's more than one, it has the following run time error about reading the river_Vshape parameter:
NETCDF_GET_FVAR_1D - error while reading variable: river_Vshape
in input file: input/frc11.nc
call from: get_cycle.F
GET_NGFLD - error while reading variable: river_Vshape at TIME index = 6
REASON: NetCDF: Index exceeds dimension bound
I have no idea why the error refers to the TIME index, when the river_Vshape should only have dimensions in S_rho (number of layers) and number of rivers. I've made many futile attempt to change the dimensions and definition of river_Vshape and none works. I even tried to remove river_Vshape from my forcing file, because apparently it shouldn't be required for 2D run (i.e. it must be unity at each river!). But in this case, the model still asks for this variable.
I'm attaching the he full running log and the ncdump of my forcing file for your inspection below. Any prompt help will be greatly appreciated.
Simon Wong
Running log
Model Input Parameters: ROMS/TOMS version 3.5
Monday - October 3, 2011 - 10:46:13 AM
SZ Plume Grid Sensitivity
Operating system : Linux
CPU/hardware : i686
Compiler system : gfortran
Compiler command : /usr/bin/gfortran
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
SVN Revision : 566M
Local Root : /home/whcsimon/research/ROMS/trunk
Header Dir : /home/whcsimon/research/ROMS/projects/square_toy/header
Header file : square4.h
Analytical Dir: /home/whcsimon/research/ROMS/projects/square_toy
Resolution, Grid 01: 0005x0040x001, Parallel Threads: 1, Tiling: 001x001
200000 ntimes Number of timesteps for 3-D equations.
0.020 dt Timestep size (s) for 3-D equations.
1 ndtfast Number of timesteps for 2-D equations between
10000000 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
1000 nHIS Number of timesteps between the writing fields
into history file.
7.0000E-01 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
0.0000E+00 rdrg Linear bottom drag coefficient (m/s).
1.0000E-02 rdrg2 Quadratic bottom drag coefficient.
3.0000E-02 Zob Bottom roughness (m).
Output Restart File: output/ocean_rst_3.nc
Output History File: output/ocean_his_6.nc
Input Grid File: input/grid4.nc
Tile partition information for Grid 01: 0005x0040 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 5 1 40 200
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 -2.50 7.50 0.50 41.50 RHO-points
0 -3.00 7.00 0.50 41.50 U-points
0 -2.50 7.50 0.00 41.00 V-points
sz SZ Plume Grid Sensitivity
EW_PERIODIC East-West periodic boundaries.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NORTHERN_WALL Wall boundary at Northern edge.
SOUTHERN_WALL Wall boundary at Southern edge.
THREE_GHOST Using three Ghost Points in halo regions.
UV_ADV Advection of momentum.
UV_PSOURCE Mass point sources and sinks.
Process Information:
Thread # 0 (pid= 1102) is active.
Minimum X-grid spacing, DXmin = 1.00000000E-03 km
Maximum X-grid spacing, DXmax = 1.00000000E-03 km
Minimum Y-grid spacing, DYmin = 2.50000000E-03 km
Maximum Y-grid spacing, DYmax = 2.50000000E-03 km
Minimum barotropic Courant Number = 9.54132066E-02
Maximum barotropic Courant Number = 9.54132066E-02
Maximum Coriolis Courant Number = 0.00000000E+00
(Min = 1.00000000E+00 Max = 5.00000000E+00)
(Min = 1.00000000E+00 Max = 4.20000000E+01)
(Min = 1.00000000E+00 Max = 1.00000000E+00)
Elapsed CPU time (seconds):
Thread # 0 CPU: 0.008
Total: 0.008
Allocation and array initialization .............. 0.004 (50.0062 %)
Total: 0.004 50.0062
All percentages are with respect to total time = 0.008
Analytical header files used:
nudump of forcing
NetCDF frc/frc11.nc {
dimensions:
xi_rho = 7 ;
xi_u = 6 ;
xi_v = 7 ;
eta_rho = 42 ;
eta_u = 42 ;
eta_v = 41 ;
s_rho = 1 ;
river = 6 ;
river_time = 3 ;
variables:
// Preference 'PRESERVE_FVD': false,
// dimensions consistent with ncBrowse, not with native MATLAB netcdf package.
double river(river), shape = [6]
river:long_name = "river runoff identification number"
double river_Xposition(river), shape = [6]
river_Xposition:long_name = "river XI-position at RHO-points"
river_Xposition:valid_min = 1
river_Xposition:valid_max = 41
double river_Eposition(river), shape = [6]
river_Eposition:long_name = "river ETA-position at RHO-points"
river_Eposition:valid_min = 1
river_Eposition:valid_max = 69
double river_direction(river), shape = [6]
river_direction:long_name = "river runoff direction"
double river_time(river_time), shape = [3]
river_time:long_name = "river runoff time"
river_time:units = "days since 00:00:00"
river_time:add_offset = 0
double river_Vshape(s_rho,river), shape = [1 6]
river_Vshape:long_name = "river runoff mass transport vertical profile"
double river_transport(river_time,river), shape = [3 6]
river_transport:long_name = "river runoff vertically integrated mass transport"
river_transport:units = "meter3 second-1"
river_transport:time = "river_time"
double river_temp(river_time,s_rho,river), shape = [3 1 6]
river_temp:long_name = "river runoff potential temperature"
river_temp:units = "Celsius"
river_temp:time = "river_time"
double river_salt(river_time,s_rho,river), shape = [3 1 6]
river_salt:long_name = "river runoff salinity"
river_salt:time = "river_time"
//global Attributes:
:type = "ROMS FORCING file"
:title = "RIVERPLUME1 test case"
:grd_file = "xxx.nc"
:rivers = "Random rivers"
Error of having input of multiple rivers in 2D run
Re: Error of having input of multiple rivers in 2D run
Hi, everyone! I also have met the same problem, " GET_NGFLD -error while reading variable: river_Vshape at TIME index = 1"
I also wondered what wrong is it, please help me,thank you very much.
What happens if you tell it not to read Vshape in get_idata.F? You can put "#ifdef SOLVE3D" around that section.
