This river has a mean depth around 5m, and a damn regulated flow around 200 m3/s.
I define v_south/north by dividing Q by the cross-sectional area. I set the outflow (NORTH) zeta to zero and calculate zeta_south by calculating a slope:
dz/dx = ( drag * u2 ) / ( Hyd.Rad * g )
my time stepping is dt=0.05s (half of CFL), DTF=20, DT=1
I currently think my problem is in my number of vertical layers, the most I can get to run is 5.
The model will run fine up to 1.5hrs past the one hour ramp (see t=150min), and then these lengthwise velocity perturbations grow from the edges and propagate down the river. The models typically run the full 4hrs without blow up, but the results clearly are not right.
Is this a problem with too many layers? Too small an hmin? bad options? I pretty new at this so any insight or recommended articles are welcome!
I've included my model options and small snap shots of the inflow region.
-Kyle
NoCPP KO-3D-07E
COSINE2 Cosine-squared shape time-averaging barotropic filter.
EASTERN_WALL Wall boundary at Eastern edge.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NORTH_FSCHAPMAN Northern edge, free-surface, Chapman condition.
NORTH_M2FLATHER Northern edge, 2D momentum, Flather condition.
TS_C4HADVECTION Fourth-order centered horizontal advection of tracers.
UV_ADV Advection of momentum.
UV_SADVECTION Parabolic splines vertical advection of momentum.
WET_DRY Wetting and drying activated.
