passive temperature and salinity
asujrpv
#1 Unread post by asujrpv »
Hello everybody,
I have been able to run ROMS for a small area, with stratification in Temperature and Salt.
I would like to do the same but without stratification at all, just for comparison. My question is what flags should I use in my cdw.h file?
in the *.in file, what should I write for active/innactive tracers?
NAT = 0 ! Number of active tracers (usually, 2)
NPT = 1 ! Number of inactive passive tracers
Here is what I think should be, but please let correct me. As I said, I would like to run my case without scalars (for comparison).
** svn $Id: basin.h 547 2011-04-13 21:32:58Z arango $
** Copyright (c) 2002-2011 The ROMS/TOMS Group **
** See License_ROMS.txt **
** Options for Big Bad Basin.
** Application flag: CDW
** Input script: ocean_cdw.in
** Options for cdw example
/* Model physics */
/* #define SALINITY */
#define T_PASSIVE
#define SPLINES
#define GLS_MIXING /* use if Generic Length-Scale mixing */
#define N2S2_HORAVG
#define KANTHA_CLAYSON
#define MIX_S_UV /* use if mixing along constant S-surfaces */
#define MIX_S_TS /* use if mixing along constant S-surfaces */
#define RAMP_TIDES
#define SSH_TIDES
#define UV_TIDES
#define NORTH_FSCHAPMAN
#define NORTH_M2FLATHER
#define SOUTH_FSCHAPMAN
#define SOUTH_M2FLATHER
#define EAST_FSCHAPMAN
#define EAST_M2FLATHER
#define WEST_FSCHAPMAN
#define WEST_M2FLATHER
#define ANA_INITIAL
#define ANA_FSOBC
#define ANA_M2OBC
#define ANA_SMFLUX
#define ANA_STFLUX
#define ANA_SSFLUX
#define ANA_SRFLUX
/* Lateral boundary conditions*/
/* #define EAST_FSRADIATION /* use if free-surface radiation condition */
#define EAST_M3RADIATION /* use if 3D momentum radiation condition */
#define EAST_KRADIATION /* use if TKE fields radiation condition */
#define EAST_TRADIATION /* use if tracers radiation condition */
/* #define WEST_FSRADIATION /* use if free-surface radiation condition */
#define WEST_M3RADIATION /* use if 3D momentum radiation condition */
#define WEST_KRADIATION /* use if TKE fields radiation condition */
#define WEST_TRADIATION /* use if tracers radiation condition */
/* #define NORTH_FSRADIATION /* use if free-surface radiation condition */
#define NORTH_M3RADIATION /* use if 3D momentum radiation condition */
#define NORTH_KRADIATION /* use if TKE fields radiation condition */
#define NORTH_TRADIATION /* use if tracers radiation condition */
/* #define SOUTH_FSRADIATION /* use if free-surface radiation condition */
#define SOUTH_M3RADIATION /* use if 3D momentum radiation condition */
#define SOUTH_KRADIATION /* use if TKE fields radiation condition */
#define SOUTH_TRADIATION /* use if tracers radiation condition */
Re: passive temperature and salinity
My guess, not being in the office, is that the setup you propose will not work. ROMS will be expecting two active tracers with the use of the nonlinear equation of state. I think you need to have at least one active tracer and you should use a linear equation of state, with coefficients provided in the ocean.in file. Likewise, GLS_MIXING is going to be looking at your tracer, density, etc. fields so you might want to switch to a more predictable vertical viscosity. You will also need tracer boundary conditions of some sort or the other - just be aware that not setting any will provide a wall boundary condition.
Beyond that, try some things and see what happens.
#3 Unread post by arango »
If you want a run without stratification just set temperature and salinity to be spatially uniform. For example, temp(i,j,k)=25 and salt(i,j,k)=35. You need to use the linear equation of state with perhaps SCOEF=0 (temperature is a proxy for density). You also need to have zero surface and bottom vertical fluxes for temperature and salinity. This is equivalent to have a shallow-water set-up but with vertical levels.
:idea: Perhaps, what you just need is just to solve the vertically integrated ROMS equations (SOLVE3D is undefined).
asujrpv
#4 Unread post by asujrpv »
Many thanks, this worked the way you mentioned.
thanks!
Rafael
