I had successfully compiled and executed the 514 version of roms in parallel mode (openMP) using ifort. Recently, I have done an update for roms to the latest version ( 564 version) unfortunately I get the following error message while compiling
[/tmp/ifortL6LoRo.f90(89) : (col. 6) remark: OpenMP DEFINED REGION WAS PARALLELIZED.
fortcom: Severe: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
in file (null), line 0, column 0
compilation aborted for mod_parallel.f90 (code 3)
make: *** [Build/mod_parallel.o] Error 3]
Can you help me please ?
