I am running ROMS and it suddenly blows up saying :
WRT_RST - wrote re-start fields (Index=1,1) into time record = 0000001
When I look at the contents of the restart file or the screen output log file (I also write-out the maximum CFL number and its u-, v- and w- components), I do not see anything abnormal. Hence, I am totally confused as to why ROMS is blowing up.
My application only uses the Nonlinear model and I am not using any 4DVar, Tangent, Representer, etc. options and is hence quite a straightforward and simple application.
A reduction in time step causes it to blow-up some time later also.
What is the criterion built into ROMS to detect a blow-up?
Unexpected ROMS blow-up
Re: Unexpected ROMS blow-up
I've found the best way to diagnose a blow-up like the one you describe is to save restart output very frequently and look at the fields of zeta, u, v; and also the change in those fields between the last time step and the second-to-last time step. This usually shows you where problems may be.
You can look in diag.F to see the criterion for blowing up. I've added code there to make it more verbose about its blowing up.
