I am having a little bit of problems with setting up a simulation in
ROMS, particularly with the initial and boundary conditions, and I will be
most grateful if you could please help me.
Basically the problem is in setting up the initial and boundary conditions
in ROMS.
I have the bathymetry for the model region, T and S profiles to
be used as initial conditions, and barotropic components of u, v, and
surface elevation zeta.
I have been able to create the grid, that is not a problem now. But I do
have problems in generating the initial conditions from the measured T and S
profiles. The attached figure shows the data from the ascii file that I have.
What I need is to enter the initial conditions from the ascii (please see
attached) and set the upper boundary as shear free (non-deformable).
So the questions is how to setup the initial and boundary conditions of the
problem with non-reflective lateral boundaries and top non-deformable shear-
free surface in ROMS.
The temperature and salinity should be applied to my domain throughout.
As I mentioned before, I have measurements of barotropic components of u, v,
and surface elevation zeta.
Thank you!
Rafael
initial and boundary conditions from measured data
Re: initial and boundary conditions from measured data
Easiest would be to provide the values as analytic functions in ana_initial.h. Failing that, create an initial netcdf file that matches the supplied cdl file using matlab or the tool of your choice. What is the tool of your choice? There are several with netcdf interfaces - we have some useful pieces for some.
Same story for the boundary conditions.
I did it before using following steps,
1 - if you don't have actual numeric values of the data. You should get them from the plot. You can use the PlotDigitizer to do that and can be downloaded from following link,
http://plotdigitizer.sourceforge.net/
2 - After getting the data (it is values and depth). You could the MATLAB curve fitting toolbox to fit a curve to data. In my case, i used exponential function but it could be different in your case. If you don't have MATLAB you can do it any other open source tool such as R, octave etc.
3 - Now, you have function and it's coefficients for both temperature and salinity field. It is important that the function gets the depth as a argument and outputs the actual value of the temperature or salinity.
4 - Now you have to implement the function in the ana_initial.h (you can copy this file into your case director and point it in the *.in file)
The basic modification but be include the following,
In subroutine "ana_initial_tile" define the coefficients in the local variable declaration section,
In this case the a0,b0,c0 and d0 is for temperature and others for salinity. Then put the functions into the following section,
That is all. In this case the temperature is constant in the upper layer of the ocean (set it to 13.6). So, if you want you can delete that part for your application. Now, you can compile the model. By the way, don't forget the set #define ANA_INITIAL in the cpp definitions. Please correct me Kate, if i miss something.
--ufuk
real(r8) :: a0=6.675_r8
real(r8) :: b0=-0.01719_r8
real(r8) :: c0=7.774_r8
real(r8) :: d0=-0.003026_r8
real(r8) :: a1=11.81_r8
real(r8) :: b1=-2.169e-05_r8
real(r8) :: c1=-1.541_r8
real(r8) :: d1=-0.1927_r8
# if defined MY_APPLICATION
DO k=1,N(ng)
DO j=JstrR,JendR
DO i=IstrR,IendR
! homogeneous
!t(i,j,k,1,itemp)=7.0_r8
! stratified
if (z_r(i,j,k) .lt. -10.0_r8) then
t(i,j,k,1,itemp)=a0*exp(b0*-1.0_r8*z_r(i,j,k)) + &
c0*exp(d0*-1.0_r8*z_r(i,j,k))
else
t(i,j,k,1,itemp)=13.6_r8
end if
# ifdef SALINITY
t(i,j,k,1,isalt)=a1*exp(b1*-1.0_r8*z_r(i,j,k)) + &
c1*exp(d1*-1.0_r8*z_r(i,j,k))
--ufuk
I am most grateful Kate and Ufuk for your suggestions.
Kate, my preference is fortran but I can use matlab as well.
What about the lateral (non-reflective) boundary conditions? the region is a rectangle, where do I set those BC?
Could you please also tell me where to set the top (rigid free shear) and bottom boundary conditions.
Thank you truly!
Rafael
Thank you truly!
Rafael
Hernan once had Fortran codes for making IC/BC files. I haven't used them in over ten years and Hernan is now supporting the matlab option.
The top and bottom BC are in ana_smflux, ana_stflux, ana_btflux and so forth.
All this stuff should be in the wiki - did you look there? Try https://www.myroms.org/wiki/index.php/B ... Conditions.
Ufuk/Kate, if I am using the curve fitting as suggested, should I use positive 'z' or negative, as written above? Please let me know, I thought ROMS uses positive depth.turuncu wrote:Hi,
In this case the a0,b0,c0 and d0 is for temperature and others for salinity. Then put the functions into the following section,Code: Select all
... real(r8) :: a0=6.675_r8 real(r8) :: b0=-0.01719_r8 real(r8) :: c0=7.774_r8 real(r8) :: d0=-0.003026_r8 real(r8) :: a1=11.81_r8 real(r8) :: b1=-2.169e-05_r8 real(r8) :: c1=-1.541_r8 real(r8) :: d1=-0.1927_r8 ...
That is all. In this case the temperature is constant in the upper layer of the ocean (set it to 13.6). So, if you want you can delete that part for your application. Now, you can compile the model. By the way, don't forget the set #define ANA_INITIAL in the cpp definitions. Please correct me Kate, if i miss something.Code: Select all
... # if defined MY_APPLICATION DO k=1,N(ng) DO j=JstrR,JendR DO i=IstrR,IendR ! homogeneous !t(i,j,k,1,itemp)=7.0_r8 ! stratified if (z_r(i,j,k) .lt. -10.0_r8) then t(i,j,k,1,itemp)=a0*exp(b0*-1.0_r8*z_r(i,j,k)) + & c0*exp(d0*-1.0_r8*z_r(i,j,k)) else t(i,j,k,1,itemp)=13.6_r8 end if # ifdef SALINITY t(i,j,k,1,isalt)=a1*exp(b1*-1.0_r8*z_r(i,j,k)) + & c1*exp(d1*-1.0_r8*z_r(i,j,k)) # endif END DO END DO END DO ...
--ufuk
ROMS uses positive depth, but negative z. The bottom is at z = -h.
