unexpected temperature distribution ...
turuncu
#1 Unread post by turuncu »
I try to set-up ROMS model for Caspian Sea. The result is little bit strange. The unrealistic cold regions over deepest regions. It seems that there is a problem in horizontal and vertical diffusion but i am not sure. I plot the surface and vertical temperature distribution and they can be seen at the end of the message. The used options are;
** Options associated with momentum equations:
#define UV_LDRAG
#undef  UV_VIS4
** Options associated with tracers equations:
#define TS_U3HADVECTION
#define TS_C4VADVECTION
#define SOLAR_SOURCE
#undef  TS_DIF4
** Options for pressure gradient algorithm:
#define ATM_PRESS
** Options for atmospheric boundary layer:
#define BULK_FLUXES
#define EMINUSP
#define LONGWAVE_OUT
** Options for model configuration:
#undef  STATION
** Options for analytical fields configuration:
#define ANA_INITIAL
** Options for horizontal mixing of momentum:
#define MIX_S_UV       /* mixing along constant s surfaces */
#undef  MIX_GEO_UV     /* mixing on z surfaces */
#define MIX_GEO_TS
#undef  MIX_S_TS
** Options for vertical mixing momentum and tracers:
#define MY25_MIXING
#define KANTHA_CLAYSON
#define N2S2_HORAVG
** Options for close boundary conditions:
#define EASTERN_WALL
#define NORTHERN_WALL
#define SOUTHERN_WALL
#define WESTERN_WALL
Model has 32 vertical level and grid resolution is 10 km.
  Vtransform == 2                          ! transformation equation
 Vstretching == 2                          ! stretching function
     THETA_S == 8.0d0                      ! surface stretching parameter
     THETA_B == 0.4d0                      ! bottom  stretching parameter
      TCLINE == 10.0d0                     ! critical depth (m)
The problem might be related with the viscosity and diffusion parameters (TUN*, VISC* and AKT_BAK). What is the real effects of these parameter over the model? I have some difficulties about setting right parameters. So, is there any simple combination of them. What do you suggest?
Surface temperature (Seasonal average, MAM):
1st column AVHRR
2nd column ARCLAKE
3rd column Model Results
Bathymetry and cross section positions:
Vertical cross section of temperature field (Seasonal average, MAM):
Regards,
--ufuk
susonic
Re: unexpected temperature distribution ...
#2 Unread post by susonic »
I can't see the images.
Would you attach them?
Joonho Lee
turuncu
#3 Unread post by turuncu »
Sorry about that. I don't know why you didn't see the plots but i replaced them with their gif versions. So, i can see the plots now.
--ufuk
susonic
#4 Unread post by susonic »
Before you think about the wrong use of horizontal/vertical diffusion cpp option,
did you check out the value of surface forcing whether it's reasonable?
Sometimes we find some weird value in the forcing file due to mistake
from the building script.
Joonho Lee
