the g77 compiler version 3.3.5 using the command
make -f Makefile.Gnu
When I try execute the program with
oa <oa.in
the system returns:
Killed
Then, i decided to investigate some extrange messages i watch at compiling
time. Here is that i found:
*A)
According to the unidata manual for the f77 version of the netcdf library at
http://www.unidata.ucar.edu/software/ne ... f-f77.html
the function "NF_PUT_ATT_TEXT" is defined by this way:
INTEGER FUNCTION NF_PUT_ATT_TEXT (INTEGER NCID,
INTEGER VARID, CHARACTER*(*) NAME, INTEGER LEN,
CHARACTER*(*) TEXT)
Despite, in the file "def_oa.F" there are some calls to this function that
don't follows this prototipe:
-at line 240:
status=nf_put_att_text(ncoutid,varid,'units',5,'meter',varid)
status=nf_put_att_text(ncoutid,'nfrq',nf_int,0,0,varid)
status=nf_put_att_text(ncoutid,lonrid,'field',15,
& 'lon_rho, scalar',rcode)
status=nf_put_att_text(ncoutid,ncfldid(n),'field',lstr,
& text(1:lstr),rcode)
the type...
what's the way to correct this mismatch?
*B)
In same file ("def_oa.F") is used a macro, "nf_put_var1_FTYPE", defined in
the file "cppdefs.h" that in my case is expanded to "nf_put_var1_double".
According to the unidata manual for the f77 version of the netcdf library,
this function is defined like:
INTEGER FUNCTION NF_PUT_VAR1_DOUBLE(INTEGER NCID,
INTEGER VARID, INTEGER INDEX(*), DOUBLE DVAL)
-at line 593:
status=nf_put_var1_FTYPE(ncoutid,varid,1,nord)
status=nf_put_var1_FTYPE(ncoutid,varid,1,nfrq)
Can we make a cast using the "dble()" function in order to transtale the
integers to doubles?
Perhaps we must use the "nf_put_var1_int" function instead?
Thanks for your time...
Ruben
