Why is my ouput directory always empty at the end of the run
prakrati
#1 Unread post by prakrati »
Hey
When I run ROMS in the end when it has run successfully my outpot directory is empty.Is it normal??
Please clarify.
Thanks and Regards
Prakrati
Re: Why is my ouput directory always empty at the end of the run
You're running BENCHMARK? The default is to run for fewer steps than your output frequency. In that case it won't create the output files.
prakrati
#3 Unread post by prakrati »
Yes I am running BENCHMARK and please can you be a bit more explicit as to what I have to do exactly
Thanks!!!
Look here. If NTIMES is less than NHIS, there will be no writing of history fields.
prakrati
#5 Unread post by prakrati »
Thanks a lot !!! Got it !!!
