I ran ocean_benchmark4.in on 1024 cores for 17532 iterations but its giving NetCDF output error
Kindly help
Resource usage summary:
CPU time : 1.56 sec.
Max Memory : 5 MB
Max Swap : 36 MB
The output (if any) follows:
Process Information:
Model Input Parameters: ROMS/TOMS version 3.2
Friday - November 12, 2010 - 11:36:24 AM
Benchmark Test, Idealized Southern Ocean, Large Grid
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /app/intel/impi/3.1/bin64/mpiifort
Compiler flags : -ip -O3 -no-prec-div -xT -ftz -fno-alias -funroll-loops -ip -O3 -xW -free
Input Script : /homenc/ipaes84/optimisedROMS/ROMS/ROMS/roms-3.1/ROMS/ocean_benchmark4.in
SVN Revision :
Local Root : /homenc/ipaes84/optimisedROMS/ROMS/ROMS/roms-3.1
Header Dir : /homenc/ipaes84/optimisedROMS/ROMS/ROMS/roms-3.1/ROMS/Include
Header file : benchmark.h
Analytical Dir: /homenc/ipaes84/optimisedROMS/ROMS/ROMS/roms-3.1/ROMS/Functionals
Resolution, Grid 01: 4192x0272x030, Parallel Nodes: ***, Tiling: 128x008
17532 ntimes Number of timesteps for 3-D equations.
150.000 dt Timestep size (s) for 3-D equations.
17532 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
17532 nHIS Number of timesteps between the writing fields
into history file.
17532 ndefHIS Number of timesteps between creation of new
history files.
5.0000E+02 tnu2(01) Horizontal, harmonic mixing coefficient (m2/s)
5.0000E+02 tnu2(02) Horizontal, harmonic mixing coefficient (m2/s)
for tracer 02: salt
5.0000E+03 visc2 Horizontal, harmonic mixing coefficient (m2/s)
1.0000E-05 Akt_bak(01) Background vertical mixing coefficient (m2/s)
1.0000E-05 Akt_bak(02) Background vertical mixing coefficient (m2/s)
for tracer 02: salt
1.0000E-04 Akv_bak Background vertical mixing coefficient (m2/s)
1.0000E+01 blk_ZT Height (m) of surface air temperature measurement.
1 lmd_Jwt Jerlov water type.
200.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
T Hout(idSrad) Write out shortwave radiation flux.
T Hout(idLrad) Write out longwave radiation flux.
T Hout(idLhea) Write out latent heat flux.
T Hout(idShea) Write out sensible heat flux.
T Hout(idHsbl) Write out depth of surface boundary layer.
Output Restart File: ./output/ocean_rst.nc
Prefix for History Files: ./output/ocean_his
Tile partition information for Grid 01: 4192x0272x0030 tiling: 128x008
HaloSizeI(1) = 135
HaloSizeJ(1) = 138
TileSide(1) = 40
TileSize(1) = 1560
BENCHMARK Benchmark Test, Idealized Southern Ocean, Large Grid
ALBEDO Shortwave radiation from albedo equation.
ANA_CLOUD Analytical cloud fraction.
ANA_GRID Analytical grid set-up.
ANA_HUMIDITY Analytical surface air humidity.
ANA_PAIR Analytical surface air pressure.
ANA_RAIN Analytical rain fall rate.
ANA_SRFLUX Analytical kinematic shortwave radiation flux.
ANA_WINDS Analytical surface wind components.
BULK_FLUXES Surface bulk fluxes parametererization.
EW_PERIODIC East-West periodic boundaries.
LONGWAVE Compute net longwave radiation internally.
NONLINEAR Nonlinear Model.
NORTHERN_WALL Wall boundary at Northern edge.
SALINITY Using salinity.
SOUTHERN_WALL Wall boundary at Southern edge.
SPHERICAL Spherical grid configuration.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Vertical S-coordinate System:
30 0.0000000 0.0000000 0.000 0.000 0.000
29 -0.0333333 -0.0024174 -7.392 -11.622 -15.853
28 -0.0666667 -0.0052838 -14.918 -24.165 -33.412
27 -0.1000000 -0.0087922 -22.638 -38.024 -53.410
26 -0.1333333 -0.0131904 -30.624 -53.707 -76.790
25 -0.1666667 -0.0187972 -38.973 -71.868 -104.763
24 -0.2000000 -0.0260168 -47.805 -93.334 -138.864
23 -0.2333333 -0.0353508 -57.272 -119.136 -181.000
22 -0.2666667 -0.0473981 -67.553 -150.499 -233.446
21 -0.3000000 -0.0628318 -78.850 -188.805 -298.761
20 -0.3333333 -0.0823381 -91.368 -235.460 -379.551
19 -0.3666667 -0.1065031 -105.284 -291.665 -478.045
18 -0.4000000 -0.1356491 -120.695 -358.081 -595.466
17 -0.4333333 -0.1696534 -137.563 -434.456 -731.349
16 -0.4666667 -0.2078237 -155.680 -519.372 -883.063
15 -0.5000000 -0.2489214 -174.676 -610.289 -1045.901
14 -0.5333333 -0.2913811 -194.081 -703.998 -1213.915
13 -0.5666667 -0.3336756 -213.436 -797.368 -1381.301
12 -0.6000000 -0.3746809 -232.404 -888.096 -1543.788
11 -0.6333333 -0.4138998 -250.837 -975.161 -1699.486
10 -0.6666667 -0.4514899 -268.780 -1058.888 -1848.995
9 -0.7000000 -0.4881475 -286.444 -1140.702 -1994.960
8 -0.7333333 -0.5249360 -304.147 -1222.785 -2141.423
7 -0.7666667 -0.5631362 -322.274 -1307.762 -2293.251
6 -0.8000000 -0.6041494 -341.245 -1398.506 -2455.768
5 -0.8333333 -0.6494565 -361.504 -1498.053 -2634.601
4 -0.8666667 -0.7006196 -383.519 -1609.604 -2835.688
3 -0.9000000 -0.7593114 -407.793 -1736.588 -3065.383
2 -0.9333333 -0.8273620 -434.875 -1882.759 -3330.642
1 -0.9666667 -0.9068164 -465.378 -2052.307 -3639.236
0 -1.0000000 -1.0000000 -500.000 -2250.000 -4000.000
Time Splitting Weights: ndtfast = 20 nfast = 29
3-0.0011514592651644 0.0501156998674241-0.0034654566136460 0.1501639558342180
4-0.0003735756740661 0.0501732728306823-0.0038390322877121 0.2003372286649003
5 0.0009829200513762 0.0501919516143856-0.0028561122363360 0.2505291802792859
6 0.0029141799764308 0.0501428056118168 0.0000580677400949 0.3006719858911027
7 0.0054132615310267 0.0499970966129953 0.0054713292711216 0.3506690825040980
8 0.0084687837865133 0.0497264335364439 0.0139401130576348 0.4003955160405419
9 0.0120633394191050 0.0493029943471183 0.0260034524767398 0.4496985103876602
10 0.0161716623600090 0.0486998273761630 0.0421751148367488 0.4983983377638232
11 0.0207585511322367 0.0478912442581626 0.0629336659689856 0.5462895820219857
12 0.0257765478740990 0.0468533167015507 0.0887102138430846 0.5931428987235364
13 0.0311633730493854 0.0455644893078458 0.1198735868924700 0.6387073880313822
14 0.0368391158442262 0.0440063206553765 0.1567127027366962 0.6827137086867586
15 0.0427031802506397 0.0421643648631652 0.1994158829873359 0.7248780735499238
16 0.0486309868367617 0.0400292058506332 0.2480468698240976 0.7649072794005570
17 0.0544704302037592 0.0375976565087951 0.3025173000278568 0.8025049359093521
18 0.0600380921294286 0.0348741349986072 0.3625553921572854 0.8373790709079593
19 0.0651152103984763 0.0318722303921357 0.4276706025557617 0.8692513013000950
20 0.0694434033194839 0.0286164698722119 0.4971140058752456 0.8978677711723069
21 0.0727201499285570 0.0251442997062377 0.5698341558038026 0.9230120708785446
22 0.0745940258796570 0.0215082922098099 0.6444281816834596 0.9445203630883545
23 0.0746596950216180 0.0177785909158270 0.7190878767050776 0.9622989540041815
24 0.0724526566618460 0.0140456061647461 0.7915405333669235 0.9763445601689277
25 0.0674437485167025 0.0104229733316538 0.8589842818836260 0.9867675335005816
26 0.0590334053485719 0.0070507859058187 0.9180176872321979 0.9938183194064003
27 0.0465456732896124 0.0040991156383901 0.9645633605218102 0.9979174350447905
28 0.0292219798521903 0.0017718319739095 0.9937853403740006 0.9996892670187000
29 0.0062146596259995 0.0003107329813000 1.0000000000000000 1.0000000000000000
ndtfast, nfast = 20 29 nfast/ndtfast = 1.45000
Minimum X-grid spacing, DXmin = 3.26041548E+00 km
Maximum X-grid spacing, DXmax = 6.14309257E+00 km
Minimum Y-grid spacing, DYmin = 8.17650180E+00 km
Maximum Y-grid spacing, DYmax = 8.17650180E+00 km
Minimum Z-grid spacing, DZmin = 7.39187981E+00 m
Maximum Z-grid spacing, DZmax = 3.60764219E+02 m
Minimum barotropic Courant Number = 1.62217863E-01
Maximum barotropic Courant Number = 4.49102838E-01
Maximum Coriolis Courant Number = 2.05618380E-02
Maximum grid stiffness ratios: rx0 = 3.966042E-01 (Beckmann and Haidvogel)
rx1 = 1.150589E+01 (Haney)
Initial basin volumes: TotVolume = 1.65993987026488E+17 m3
MinVolume = 1.97754634567622E+08 m3
MaxVolume = 1.80931355725002E+10 m3
Max/Min = 9.14928523018421E+01
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00017532)
0 0 00:00:00 0.000000E+00 1.963001E+04 1.963001E+04 1.659940E+17
DEF_HIS - creating history file: ./output/ocean_his_0001.nc
NETCDF_CREATE - unable to create output NetCDF file:
call from: def_his.F
DEF_HIS - unable to create history NetCDF file: ./output/ocean_his_0001.nc
Elapsed CPU time (seconds):
Node # 1 CPU: 31.808
Node # 2 CPU: 32.160
Node # 4 CPU: 32.197
Node # 5 CPU: 31.822
Node # 11 CPU: 31.789
Node # 12 CPU: 31.882
Node # 25 CPU: 33.336
Node # 6 CPU: 32.078
Node # 13 CPU: 31.872
Node # 14 CPU: 31.793
Node # 0 CPU: 31.172
Node # 23 CPU: 31.846
Node # 26 CPU: 33.336
Node # 29 CPU: 33.332
Node # 30 CPU: 33.331
Node # 27 CPU: 33.336
Node # 28 CPU: 33.333
Node # 54 CPU: 31.978
Node # 49 CPU: 31.975
Node # 60 CPU: 32.063
Node # 57 CPU: 32.026
Node # 55 CPU: 31.941
Node # 53 CPU: 31.979
Node # 3 CPU: 31.868
Node # 7 CPU: 31.855
Node # 15 CPU: 31.693
Node # 65 CPU: 31.800
Node # 31 CPU: 33.331
Node # 9 CPU: 31.755
Node # 10 CPU: 31.775
Node # 22 CPU: 31.938
Node # 20 CPU: 31.907
Node # 21 CPU: 31.957
Node # 19 CPU: 31.783
Node # 44 CPU: 31.846
Node # 46 CPU: 31.883
Node #129 CPU: 31.494
Node # 42 CPU: 31.783
Node # 41 CPU: 31.873
Node # 39 CPU: 31.805
Node # 33 CPU: 31.911
Node # 63 CPU: 32.075
Node # 43 CPU: 31.792
Node # 89 CPU: 32.033
Node # 45 CPU: 31.881
Node # 91 CPU: 32.070
Node #190 CPU: 32.082
Node # 47 CPU: 31.885
Node # 62 CPU: 32.001
Node # 59 CPU: 32.043
Node #121 CPU: 32.009
Node # 58 CPU: 32.149
Node # 51 CPU: 31.827
Node #110 CPU: 33.213
Node #107 CPU: 33.211
Node #109 CPU: 33.211
Node #222 CPU: 31.403
Node #193 CPU: 31.809
Node # 61 CPU: 32.011
Node #126 CPU: 32.028
Node #122 CPU: 31.995
Node #207 CPU: 31.959
Node #215 CPU: 31.736
Node #219 CPU: 31.738
Node #220 CPU: 31.809
Node #431 CPU: 31.703
Node #113 CPU: 31.989
Node #111 CPU: 33.210
Node #238 CPU: 31.553
Node #123 CPU: 32.027
Node #254 CPU: 31.913
Node #241 CPU: 31.688
Node #246 CPU: 31.609
Node #245 CPU: 31.638
Node #223 CPU: 31.461
Node #116 CPU: 31.771
Node #118 CPU: 31.925
Node #478 CPU: 31.256
Node #237 CPU: 31.629
Node #225 CPU: 31.638
Node #447 CPU: 31.764
Node # 52 CPU: 31.945
Node #103 CPU: 31.642
Node #415 CPU: 31.900
Node #221 CPU: 31.424
Node #441 CPU: 31.693
Node #442 CPU: 31.756
Node #439 CPU: 31.947
Node #863 CPU: 31.617
Node # 95 CPU: 31.989
Node #387 CPU: 31.503
Node #191 CPU: 31.961
Node #388 CPU: 31.443
Node #383 CPU: 31.667
Node #385 CPU: 31.403
Node #772 CPU: 31.824
Node #497 CPU: 31.855
Node #247 CPU: 31.674
Node #495 CPU: 31.912
Node #125 CPU: 32.028
Node #510 CPU: 31.882
Node #119 CPU: 31.858
Node #494 CPU: 31.801
Node #493 CPU: 31.887
Node #492 CPU: 31.807
Node #491 CPU: 31.840
Node #985 CPU: 31.758
Node #115 CPU: 31.797
Node #117 CPU: 31.788
Node #105 CPU: 33.209
Node #211 CPU: 31.822
Node #423 CPU: 31.420
Node #849 CPU: 31.791
Node #106 CPU: 33.209
Node #214 CPU: 31.739
Node #213 CPU: 31.608
Node #429 CPU: 31.683
Node #430 CPU: 31.621
Node #427 CPU: 31.729
Node #428 CPU: 31.583
Node #857 CPU: 32.005
Node #831 CPU: 31.872
Node #847 CPU: 31.935
Node #860 CPU: 31.894
Node #855 CPU: 31.864
Node #862 CPU: 31.750
Node #859 CPU: 31.991
Node #445 CPU: 31.691
Node #446 CPU: 31.766
Node #444 CPU: 31.714
Node #443 CPU: 31.773
Node #889 CPU: 31.966
Node #886 CPU: 31.740
Node #108 CPU: 33.211
Node #865 CPU: 31.460
Node # 50 CPU: 32.055
Node #102 CPU: 31.737
Node #101 CPU: 31.639
Node #206 CPU: 31.813
Node #414 CPU: 31.937
Node #413 CPU: 31.752
Node #205 CPU: 31.951
Node #204 CPU: 31.911
Node #409 CPU: 31.748
Node #410 CPU: 31.722
Node #203 CPU: 32.002
Node #407 CPU: 31.679
Node #412 CPU: 31.792
Node #411 CPU: 31.719
Node #825 CPU: 31.728
Node #828 CPU: 31.774
Node #817 CPU: 31.863
Node #815 CPU: 31.593
Node #823 CPU: 31.758
Node #826 CPU: 31.904
Node # 97 CPU: 31.568
Node #775 CPU: 31.652
Node #777 CPU: 31.845
Node #386 CPU: 31.490
Node #774 CPU: 31.851
Node #773 CPU: 31.609
Node #769 CPU: 31.536
Node #767 CPU: 31.691
Node #498 CPU: 31.905
Node #991 CPU: 31.421
Node #251 CPU: 31.927
Node #503 CPU: 31.827
Node #*** CPU: 31.937
Node #239 CPU: 31.617
Node #479 CPU: 31.289
Node #484 CPU: 31.805
Node #483 CPU: 31.721
Node #969 CPU: 31.740
Node #970 CPU: 31.914
Node #967 CPU: 31.636
Node #243 CPU: 31.633
Node #990 CPU: 31.391
Node #988 CPU: 31.806
Node #987 CPU: 31.812
Node #986 CPU: 31.492
Node #983 CPU: 31.719
Node #897 CPU: 31.553
Node #895 CPU: 31.938
Node #898 CPU: 31.602
Node #233 CPU: 31.547
Node #468 CPU: 31.578
Node #234 CPU: 31.556
Node #470 CPU: 31.615
Node #469 CPU: 31.618
Node #467 CPU: 31.582
Node #476 CPU: 31.640
Node #475 CPU: 31.575
Node #477 CPU: 31.574
Node #957 CPU: 31.650
Node #235 CPU: 31.718
Node #471 CPU: 31.626
Node #236 CPU: 31.553
Node #473 CPU: 31.600
Node #474 CPU: 31.354
Node #943 CPU: 32.020
Node #948 CPU: 31.839
Node #950 CPU: 31.874
Node #949 CPU: 31.967
Node #417 CPU: 31.734
Node #836 CPU: 32.048
Node #835 CPU: 32.024
Node #850 CPU: 31.700
Node #892 CPU: 31.847
Node #890 CPU: 31.971
Node #879 CPU: 31.498
Node #884 CPU: 31.599
Node #885 CPU: 31.700
Node #866 CPU: 31.681
Node #217 CPU: 31.742
Node #436 CPU: 32.015
Node #435 CPU: 32.013
Node #873 CPU: 31.450
Node #874 CPU: 31.476
Node #871 CPU: 31.646
Node #894 CPU: 31.994
Node #891 CPU: 31.987
Node #887 CPU: 31.649
Node #881 CPU: 31.807
Node #883 CPU: 31.601
Node #771 CPU: 31.546
Node #770 CPU: 31.882
Node #259 CPU: 31.370
Node #127 CPU: 31.955
Node #130 CPU: 31.846
Node #262 CPU: 31.747
Node #261 CPU: 31.442
Node #526 CPU: 31.775
Node #524 CPU: 31.874
Node #523 CPU: 31.740
Node #255 CPU: 31.894
Node #513 CPU: 31.483
Node #511 CPU: 31.849
Node #260 CPU: 31.731
Node #519 CPU: 31.415
Node #522 CPU: 31.761
Node #521 CPU: 31.724
Node #514 CPU: 31.882
Node #*** CPU: 31.672
Node #525 CPU: 31.792
Node #257 CPU: 31.383
Node #516 CPU: 31.739
Node #515 CPU: 31.511
Node #256 CPU: 31.319
Node # 81 CPU: 32.236
Node # 79 CPU: 32.126
Node # 83 CPU: 32.262
Node # 90 CPU: 32.162
Node #180 CPU: 32.126
Node # 94 CPU: 31.939
Node #189 CPU: 31.899
Node #164 CPU: 32.140
Node #159 CPU: 32.190
Node # 85 CPU: 32.360
Node #181 CPU: 32.091
Node #364 CPU: 31.716
Node #182 CPU: 32.075
Node #366 CPU: 31.761
Node #179 CPU: 31.995
Node #361 CPU: 31.694
Node #362 CPU: 31.716
Node #175 CPU: 31.999
Node #351 CPU: 31.431
Node #183 CPU: 32.071
Node #367 CPU: 31.778
Node #382 CPU: 31.751
Node #380 CPU: 31.727
Node #379 CPU: 31.751
Node #369 CPU: 31.536
Node #161 CPU: 32.196
Node #324 CPU: 31.844
Node #321 CPU: 31.470
Node #319 CPU: 33.224
Node #363 CPU: 31.842
Node #359 CPU: 31.545
Node # 87 CPU: 32.353
Node #381 CPU: 31.734
Node # 92 CPU: 32.052
Node #737 CPU: 31.699
Node #258 CPU: 31.718
Node #518 CPU: 31.733
Node #517 CPU: 31.407
Node #128 CPU: 31.588
Node #132 CPU: 31.792
Node #131 CPU: 31.544
Node #265 CPU: 31.879
Node #266 CPU: 31.829
Node #263 CPU: 31.461
Node #534 CPU: 31.968
Node #527 CPU: 31.652
Node #532 CPU: 31.901
Node #531 CPU: 31.789
Node #529 CPU: 31.954
Node #530 CPU: 31.962
Node #533 CPU: 31.936
Node #264 CPU: 31.735
Node # 64 CPU: 31.844
Node #134 CPU: 31.817
Node #270 CPU: 31.886
Node #269 CPU: 31.930
Node #542 CPU: 31.810
Node #539 CPU: 31.769
Node #541 CPU: 31.853
Node #540 CPU: 31.905
Node # 66 CPU: 31.942
Node #133 CPU: 31.524
Node #268 CPU: 32.000
Node #267 CPU: 31.873
Node #537 CPU: 31.816
Node #535 CPU: 31.863
Node #538 CPU: 31.862
Node #512 CPU: 31.414
Node # 32 CPU: 31.949
Node #167 CPU: 32.068
Node #335 CPU: 31.624
Node #337 CPU: 31.854
Node #671 CPU: 32.244
Node #174 CPU: 31.955
Node #350 CPU: 31.453
Node # 86 CPU: 32.339
Node #173 CPU: 32.035
Node #348 CPU: 31.715
Node #349 CPU: 31.701
Node #347 CPU: 31.749
Node #697 CPU: 31.678
Node #698 CPU: 31.677
Node #171 CPU: 31.970
Node #343 CPU: 31.949
Node #172 CPU: 32.062
Node #345 CPU: 31.721
Node #346 CPU: 31.829
Node #365 CPU: 31.749
Node #734 CPU: 31.303
Node #726 CPU: 31.840
Node #719 CPU: 31.681
Node #721 CPU: 31.818
Node #703 CPU: 31.672
Node #641 CPU: 31.516
Node #644 CPU: 31.822
Node #643 CPU: 31.581
Node #646 CPU: 31.868
Node #642 CPU: 31.896
Node #639 CPU: 31.467
Node #673 CPU: 31.826
Node #687 CPU: 31.863
Node #694 CPU: 31.762
Node #692 CPU: 31.644
Node #761 CPU: 31.690
Node #759 CPU: 31.517
Node #766 CPU: 31.548
Node #763 CPU: 31.575
Node #764 CPU: 31.680
Node #765 CPU: 31.679
Node #185 CPU: 31.910
Node #372 CPU: 31.373
Node #735 CPU: 31.394
Node #738 CPU: 31.821
Node #729 CPU: 31.651
Node #730 CPU: 31.438
Node #727 CPU: 31.882
Node #731 CPU: 31.614
Node #732 CPU: 31.724
Node #733 CPU: 31.330
Node #724 CPU: 31.820
Node #725 CPU: 31.708
Node #722 CPU: 31.760
Node #353 CPU: 31.413
Node #708 CPU: 31.830
Node #707 CPU: 31.832
Node #705 CPU: 31.726
Node #723 CPU: 31.790
Node #360 CPU: 31.710
Node #706 CPU: 31.821
Node #322 CPU: 31.844
Node #645 CPU: 31.584
Node #649 CPU: 31.814
Node #650 CPU: 31.750
Node #647 CPU: 31.988
Node #323 CPU: 31.635
Node # 84 CPU: 32.359
Node #338 CPU: 31.869
Node #677 CPU: 31.776
Node #678 CPU: 31.752
Node #702 CPU: 31.671
Node #699 CPU: 31.690
Node #700 CPU: 31.932
Node #701 CPU: 31.815
Node #689 CPU: 31.606
Node #690 CPU: 31.857
Node #693 CPU: 31.844
Node #691 CPU: 31.656
Node #169 CPU: 32.034
Node #339 CPU: 31.875
Node #679 CPU: 31.615
Node #170 CPU: 32.031
Node #342 CPU: 31.958
Node #341 CPU: 31.953
Node #686 CPU: 31.784
Node #684 CPU: 31.873
Node #683 CPU: 31.790
Node #340 CPU: 31.954
Node #685 CPU: 31.847
Node #674 CPU: 31.824
Node #676 CPU: 31.781
Node #675 CPU: 31.823
Node #762 CPU: 31.563
Node #371 CPU: 31.407
Node #745 CPU: 31.561
Node #746 CPU: 31.585
Node #186 CPU: 31.957
Node #374 CPU: 31.531
Node #750 CPU: 31.556
Node #749 CPU: 31.482
Node #373 CPU: 31.448
Node #370 CPU: 31.569
Node #741 CPU: 31.847
Node #742 CPU: 31.826
Node #177 CPU: 31.824
Node #356 CPU: 31.637
Node #713 CPU: 31.573
Node #714 CPU: 31.745
Node #355 CPU: 31.514
Node #711 CPU: 31.690
Node #709 CPU: 31.697
Node #354 CPU: 31.587
Node #710 CPU: 31.669
Node #160 CPU: 32.209
Node #325 CPU: 31.510
Node #651 CPU: 31.790
Node #652 CPU: 31.863
Node #695 CPU: 31.763
Node #681 CPU: 31.857
Node #682 CPU: 31.749
Node #168 CPU: 31.849
Node #162 CPU: 32.185
Node #326 CPU: 31.780
Node #654 CPU: 31.652
Node #653 CPU: 31.765
Node # 93 CPU: 31.963
Node #743 CPU: 31.861
Node #747 CPU: 31.594
Node #748 CPU: 31.401
Node #739 CPU: 31.770
Node #740 CPU: 31.864
Node #184 CPU: 32.099
Node #358 CPU: 31.639
Node #718 CPU: 31.639
Node #717 CPU: 31.791
Node #178 CPU: 32.141
Node #357 CPU: 31.540
Node #715 CPU: 31.872
Node #716 CPU: 31.738
Node #176 CPU: 32.043
Node #704 CPU: 31.643
Node #720 CPU: 31.719
Node #696 CPU: 31.950
Node #680 CPU: 31.481
Node #672 CPU: 31.839
Node #640 CPU: 31.608
Node #163 CPU: 32.182
Node #327 CPU: 31.838
Node #655 CPU: 31.831
Node #329 CPU: 31.495
Node #330 CPU: 31.548
Node #660 CPU: 31.864
Node #661 CPU: 31.747
Node #662 CPU: 31.817
Node #657 CPU: 31.804
Node #658 CPU: 31.912
Node #328 CPU: 31.392
Node #659 CPU: 31.728
Node #656 CPU: 31.779
Node # 80 CPU: 32.139
Node #187 CPU: 31.957
Node #751 CPU: 31.639
Node #375 CPU: 31.458
Node #753 CPU: 31.657
Node #754 CPU: 31.632
Node #188 CPU: 32.040
Node #377 CPU: 31.734
Node #378 CPU: 31.851
Node #758 CPU: 31.422
Node #756 CPU: 31.760
Node #757 CPU: Node # 67 CPU: 31.853
Node #135 CPU: 31.959
Node #271 CPU: 31.804
Node #543 CPU: 31.878
Node #545 CPU: 31.450
Node #546 CPU: 31.444
Node # 68 CPU: 31.740
Node #273 CPU: 33.202
Node #548 CPU: 31.365
Node #547 CPU: 31.470
Node #274 CPU: 33.204
Node #550 CPU: 31.415
Node #549 CPU: 31.344
Node #136 CPU: 32.037
Node #137 CPU: 32.116
Node #275 CPU: 33.202
Node #276 CPU: 33.204
Node #551 CPU: 31.291
Node #554 CPU: 31.576
Node #553 CPU: 31.830
Node #138 CPU: 32.055
Node #278 CPU: 33.201
Node #277 CPU: 33.200
Node #558 CPU: 31.798
Node #556 CPU: 31.592
Node #557 CPU: 31.799
Node #555 CPU: 31.622
31.466
Node #755 CPU: 31.445
Node #736 CPU: 31.653
Node #744 CPU: 31.671
Node #752 CPU: 31.524
Node #712 CPU: 31.617
Node #728 CPU: 31.438
Node #688 CPU: 31.616
Node #336 CPU: 31.863
Node #648 CPU: 31.734
Node #320 CPU: 31.445
Node #368 CPU: 31.221
Node #760 CPU: 31.499
Node #376 CPU: 31.707
Node # 88 CPU: 32.070
Node #352 CPU: 31.491
Node # 17 CPU: 31.976
Node #344 CPU: 31.626
Node #166 CPU: 32.156
Node #334 CPU: 31.408
Node #333 CPU: 31.681
Node # 82 CPU: 32.253
Node #165 CPU: 32.128
Node #331 CPU: 31.539
Node #332 CPU: 31.531
Node #670 CPU: 32.289
Node #669 CPU: 32.138
Node #665 CPU: 32.140
Node #666 CPU: 32.158
Node #663 CPU: 31.736
Node #668 CPU: 32.191
Node #667 CPU: 32.239
Node #664 CPU: 32.191
Node # 40 CPU: 31.743
Node # 34 CPU: 31.920
Node # 70 CPU: 31.944
Node # 69 CPU: 31.830
Node #142 CPU: 31.944
Node #139 CPU: 32.078
Node #279 CPU: 33.203
Node #141 CPU: 32.050
Node #286 CPU: 33.217
Node #285 CPU: 33.220
Node #283 CPU: 33.219
Node #284 CPU: 33.220
Node #569 CPU: 31.567
Node #559 CPU: 31.808
Node #574 CPU: 31.559
Node #561 CPU: 31.838
Node #570 CPU: 31.703
Node #571 CPU: 31.528
Node #567 CPU: 31.823
Node #140 CPU: 32.156
Node #562 CPU: 31.905
Node #573 CPU: 31.496
Node #572 CPU: 31.619
Node #281 CPU: 33.217
Node #564 CPU: 31.803
Node #563 CPU: 31.673
Node #280 CPU: 33.219
Node #282 CPU: 33.217
Node #566 CPU: 31.787
Node #565 CPU: 31.851
Node #560 CPU: 31.595
Node # 36 CPU: 31.835
Node # 35 CPU: 31.948
Node # 73 CPU: 31.905
Node # 74 CPU: 32.082
Node # 71 CPU: 31.864
Node #148 CPU: 32.045
Node #147 CPU: 31.907
Node #149 CPU: 31.940
Node #150 CPU: 32.014
Node #143 CPU: 32.116
Node #297 CPU: 33.220
Node #298 CPU: 33.220
Node #295 CPU: 33.300
Node #302 CPU: 33.224
Node #301 CPU: 33.221
Node #300 CPU: 33.221
Node #299 CPU: 33.220
Node #287 CPU: 33.220
Node #598 CPU: 31.578
Node #601 CPU: 31.801
Node #606 CPU: 31.664
Node #577 CPU: 31.644
Node #591 CPU: 31.773
Node #593 CPU: 31.490
Node #596 CPU: 31.656
Node #602 CPU: 31.940
Node #599 CPU: 31.682
Node #604 CPU: 31.830
Node #603 CPU: 31.834
Node #289 CPU: 33.294
Node #575 CPU: 31.618
Node #578 CPU: 31.940
Node #594 CPU: 31.500
Node #605 CPU: 31.846
Node #290 CPU: 33.300
Node #582 CPU: 32.004
Node #581 CPU: 31.665
Node #597 CPU: 31.652
Node #595 CPU: 31.510
Node #296 CPU: 33.221
Node #288 CPU: 33.296
Node #580 CPU: 31.581
Node #579 CPU: 31.661
Node #144 CPU: 31.932
Node #145 CPU: 31.958
Node #292 CPU: 33.301
Node #291 CPU: 33.297
Node #586 CPU: 31.729
Node #585 CPU: 31.563
Node #583 CPU: 31.663
Node #146 CPU: 32.115
Node #294 CPU: 33.300
Node #293 CPU: 33.303
Node #590 CPU: 31.684
Node #588 CPU: 31.715
Node #587 CPU: 31.721
Node #589 CPU: 31.861
Node # 72 CPU: 31.951
Node #576 CPU: 31.686
Node #592 CPU: 31.394
Node #584 CPU: 31.610
Node # 18 CPU: 31.944
Node # 37 CPU: 31.852
Node # 76 CPU: 32.064
Node # 75 CPU: 32.079
Node #153 CPU: 32.091
Node #154 CPU: 32.105
Node #151 CPU: 31.935
Node #310 CPU: 33.222
Node # 38 CPU: 31.927
Node # 78 CPU: 31.929
Node #158 CPU: 32.214
Node #157 CPU: 32.115
Node #318 CPU: 33.226
Node #317 CPU: 33.224
Node #303 CPU: 33.220
Node #308 CPU: 33.224
Node #316 CPU: 33.223
Node #315 CPU: 33.227
Node #638 CPU: 31.543
Node #607 CPU: 31.711
Node #309 CPU: 33.225
Node #622 CPU: 31.569
Node #307 CPU: 33.228
Node #618 CPU: 31.669
Node #617 CPU: 31.674
Node #620 CPU: 31.635
Node #619 CPU: 31.728
Node #633 CPU: 31.633
Node #636 CPU: 31.541
Node #634 CPU: 31.650
Node #631 CPU: 31.533
Node #305 CPU: 33.228
Node #612 CPU: 31.591
Node #611 CPU: 31.539
Node #615 CPU: 31.584
Node #635 CPU: 31.572
Node #637 CPU: 31.540
Node #609 CPU: 31.506
Node #610 CPU: 31.635
Node #621 CPU: 31.589
Node # 77 CPU: 32.170
Node #306 CPU: 33.228
Node #614 CPU: 31.670
Node #613 CPU: 31.669
Node #304 CPU: 33.228
Node #152 CPU: 32.117
Node #155 CPU: 32.140
Node #311 CPU: 33.225
Node Node #544 CPU: 31.502
Node #552 CPU: 31.353
#623 CPU: 31.660
Node #625 CPU: 31.674
Node #626 CPU: 31.606
Node #312 CPU: 33.225
Node #156 CPU: 32.146
Node #313 CPU: 33.226
Node #314 CPU: 33.229
Node #630 CPU: 31.622
Node #628 CPU: 31.468
Node #629 CPU: 31.487
Node #627 CPU: 31.491
Node #624 CPU: 31.346
Node #632 CPU: 31.616
Node #608 CPU: 31.480
Node #600 CPU: 31.647
Node #568 CPU: 31.615
Node #536 CPU: 31.479
Node # 8 CPU: 31.652
Node #616 CPU: 31.637
Node # 16 CPU: 31.743
Node #520 CPU: 31.674
Node #272 CPU: 33.204
Node #528 CPU: 31.785
Node #996 CPU: 31.940
Node #997 CPU: 31.919
Node #998 CPU: 31.925
Node #993 CPU: 31.819
Node #509 CPU: 31.851
Node #252 CPU: 31.909
Node #*** CPU: 31.621
Node #959 CPU: 31.729
Node #481 CPU: 31.666
Node #964 CPU: 31.734
Node #963 CPU: 31.774
Node #961 CPU: 31.697
Node #962 CPU: 31.714
Node #487 CPU: 31.837
Node #975 CPU: 31.920
Node #977 CPU: 31.689
Node #249 CPU: 31.909
Node #499 CPU: 31.836
Node #999 CPU: 31.936
Node #500 CPU: 31.906
Node #*** CPU: 31.887
Node #*** CPU: 31.907
Node #*** CPU: 31.670
Node #*** CPU: 31.664
Node #505 CPU: 31.879
Node #*** CPU: 31.701
Node #*** CPU: 31.536
Node #506 CPU: 31.889
Node #*** CPU: 31.658
Node #*** CPU: 31.700
Node #*** CPU: 31.853
Node #833 CPU: 31.875
Node #418 CPU: 31.580
Node #838 CPU: 32.004
Node #837 CPU: 31.921
Node #858 CPU: 31.985
Node #861 CPU: 32.003
Node #424 CPU: 31.264
Node #834 CPU: 32.028
Node #416 CPU: 31.596
Node #433 CPU: 31.769
Node #868 CPU: 31.868
Node #867 CPU: 31.529
Node #893 CPU: 31.994
Node #882 CPU: 31.835
Node #440 CPU: 31.767
Node #201 CPU: 31.798
Node #403 CPU: 31.641
Node #404 CPU: 31.773
Node #807 CPU: 31.364
Node #809 CPU: 31.664
Node #810 CPU: 31.815
Node #202 CPU: 31.919
Node #405 CPU: 31.680
Node #406 CPU: 31.746
Node #812 CPU: 31.470
Node #814 CPU: 31.889
Node #813 CPU: 31.579
Node #811 CPU: 31.718
Node #100 CPU: 31.656
Node #199 CPU: 31.785
Node #399 CPU: 31.924
Node #799 CPU: 31.784
Node #801 CPU: 31.809
Node #802 CPU: 31.804
Node #800 CPU: 31.893
Node #212 CPU: 31.707
Node #208 CPU: 31.637
Node #218 CPU: 31.501
Node #438 CPU: 31.955
Node #437 CPU: 31.884
Node #878 CPU: 31.498
Node #876 CPU: 31.440
Node #877 CPU: 31.440
Node #875 CPU: 31.576
Node #768 CPU: 31.536
Node #192 CPU: 31.842
Node #384 CPU: 31.501
Node #822 CPU: 31.767
Node #820 CPU: 31.727
Node #818 CPU: 31.905
Node #829 CPU: 31.813
Node #827 CPU: 31.845
Node #830 CPU: 31.808
Node #821 CPU: 31.892
Node #819 CPU: 31.615
Node #408 CPU: 31.616
Node #816 CPU: 31.655
Node #824 CPU: 31.827
Node #425 CPU: 31.809
Node #852 CPU: 31.860
Node #851 CPU: 31.715
Node #426 CPU: 31.555
Node #854 CPU: 31.818
Node #853 CPU: 31.863
Node #210 CPU: 31.645
Node #422 CPU: 31.506
Node #421 CPU: 31.557
Node #846 CPU: 31.645
Node #845 CPU: 31.922
Node #843 CPU: 31.807
Node #844 CPU: 31.921
Node #432 CPU: 31.894
Node #434 CPU: 31.982
Node #870 CPU: 31.684
Node #869 CPU: 31.601
Node #872 CPU: 31.451
Node #216 CPU: 31.519
Node #778 CPU: 31.856
Node #776 CPU: 31.751
Node #195 CPU: 31.947
Node #196 CPU: 31.724
Node #391 CPU: 31.457
Node #783 CPU: 31.806
Node #785 CPU: 31.658
Node #786 CPU: 31.833
Node #393 CPU: 31.862
Node #787 CPU: 31.810
Node #788 CPU: 31.827
Node #394 CPU: 31.824
Node #790 CPU: 31.744
Node #789 CPU: 31.825
Node #392 CPU: 31.792
Node #808 CPU: 31.247
Node # 99 CPU: 31.610
Node #401 CPU: 31.683
Node #804 CPU: 31.701
Node #803 CPU: 31.780
Node #402 CPU: 31.765
Node #806 CPU: 31.654
Node #805 CPU: 31.656
Node #200 CPU: 31.840
Node #400 CPU: 31.785
Node #209 CPU: 31.727
Node #420 CPU: 31.550
Node #419 CPU: 31.731
Node #841 CPU: 31.644
Node #842 CPU: 31.930
Node #839 CPU: 32.046
Node #840 CPU: 31.668
Node #104 CPU: 33.209
Node #880 CPU: 31.482
Node #194 CPU: 31.812
Node #389 CPU: 31.466
Node #779 CPU: 31.879
Node #780 CPU: 31.960
Node #390 CPU: 31.497
Node #782 CPU: 31.951
Node #781 CPU: 31.906
Node # 98 CPU: 31.695
Node #197 CPU: 31.776
Node #396 CPU: 31.942
Node #395 CPU: 31.867
Node #793 CPU: 31.701
Node #794 CPU: 31.749
Node #791 CPU: 31.634
Node #792 CPU: 31.425
Node #198 CPU: 31.875
Node #397 CPU: 31.849
Node #398 CPU: 31.740
Node #796 CPU: 31.840
Node #795 CPU: 31.824
Node #798 CPU: 31.837
Node #797 CPU: 31.840
Node # 24 CPU: 33.327
Node #848 CPU: 31.714
Node # 96 CPU: 31.518
Node # 48 CPU: 31.810
Node #832 CPU: 31.838
Node #864 CPU: 31.542
Node #856 CPU: 31.753
Node #888 CPU: 31.941
Node #784 CPU: 31.714
Node #452 CPU: 31.576
Node #451 CPU: 31.496
Node #903 CPU: 31.593
Node #905 CPU: 31.948
Node #906 CPU: 31.939
Node #231 CPU: 31.774
Node #463 CPU: 31.686
Node #927 CPU: 31.842
Node #929 CPU: 31.792
Node #942 CPU: 31.999
Node #941 CPU: 32.014
Node #939 CPU: 31.989
Node #940 CPU: 31.994
Node #937 CPU: 32.010
Node #938 CPU: 31.937
Node #935 CPU: 31.617
Node #953 CPU: 31.662
Node #951 CPU: 31.903
Node #956 CPU: 31.696
Node #955 CPU: 31.763
Node #958 CPU: 31.744
Node #945 CPU: 31.664
Node #946 CPU: 31.933
Node #947 CPU: 31.819
Node #449 CPU: 31.397
Node #448 CPU: 31.605
Node #454 CPU: 31.462
Node #909 CPU: 31.971
Node #226 CPU: 31.724
Node #453 CPU: 31.365
Node #907 CPU: 31.943
Node #908 CPU: 31.978
Node #910 CPU: 31.822
Node #482 CPU: 31.776
Node #966 CPU: 31.728
Node #965 CPU: 31.663
Node #960 CPU: 31.699
Node #995 CPU: 31.897
Node #994 CPU: 31.894
Node #250 CPU: 32.029
Node #502 CPU: 31.811
Node #501 CPU: 31.816
Node #*** CPU: 31.871
Node #*** CPU: 31.945
Node #*** CPU: 31.916
Node #*** CPU: 31.875
Node #465 CPU: 31.608
Node #930 CPU: 31.781
Node #936 CPU: 31.667
Node #899 CPU: 31.599
Node #900 CPU: 31.556
Node #450 CPU: 31.559
Node #902 CPU: 31.618
Node #901 CPU: 31.610
Node #224 CPU: 31.528
Node #112 CPU: 31.656
Node #954 CPU: 31.733
Node #952 CPU: 31.737
Node #932 CPU: 31.740
Node #931 CPU: 31.769
Node #466 CPU: 31.679
Node #934 CPU: 31.786
Node #933 CPU: 31.754
Node #928 CPU: 31.810
Node #232 CPU: 31.653
Node #896 CPU: 31.640
Node #989 CPU: 31.729
Node #244 CPU: 31.748
Node #978 CPU: 32.033
Node #490 CPU: 31.844
Node #982 CPU: 31.700
Node #981 CPU: 31.708
Node #489 CPU: 31.817
Node #980 CPU: 31.667
Node #979 CPU: 31.665
Node #242 CPU: 31.790
Node #485 CPU: 31.787
Node #971 CPU: 31.837
Node #972 CPU: 31.890
Node #486 CPU: 31.772
Node #974 CPU: 31.795
Node #973 CPU: 31.896
Node #240 CPU: 31.586
Node #480 CPU: 31.599
Node #253 CPU: 31.906
Node #504 CPU: 31.806
Node #248 CPU: 31.839
Node #124 CPU: 32.018
Node #*** CPU: 31.950
Node #507 CPU: 31.891
Node #*** CPU: 31.601
Node #*** CPU: 31.586
Node #508 CPU: 31.857
Node #*** CPU: 31.671
Node #*** CPU: 31.663
Node #*** CPU: 31.488
Node #472 CPU: 31.358
Node #464 CPU: 31.492
Node #944 CPU: 31.758
Node #984 CPU: 31.511
Node #488 CPU: 31.909
Node #968 CPU: 31.807
Node #120 CPU: 31.973
Node #976 CPU: 31.591
Node #496 CPU: 31.786
Node #992 CPU: 31.790
Node #455 CPU: 31.369
Node #457 CPU: 31.470
Node #227 CPU: 31.679
Node #911 CPU: 32.001
Node #913 CPU: 31.863
Node #228 CPU: 31.787
Node #914 CPU: 31.964
Node #456 CPU: 31.667
Node #915 CPU: 31.838
Node #916 CPU: 31.935
Node #458 CPU: 31.836
Node #918 CPU: 31.763
Node #917 CPU: 31.750
Node #912 CPU: 31.919
Node #904 CPU: 31.886
Node #229 CPU: 31.774
Node #459 CPU: 31.664
Node #460 CPU: 31.846
Node #230 CPU: 31.747
Node #461 CPU: 31.679
Node #924 CPU: 31.797
Node #462 CPU: 31.520
Node #925 CPU: 31.763
Node #114 CPU: 32.003
Node #919 CPU: 31.841
Node #921 CPU: 31.811
Node #922 CPU: 31.825
Node #926 CPU: 31.893
Node #923 CPU: 31.749
Node #920 CPU: 31.637
Node # 56 CPU: 32.085
Total: 32621.340
Initialization ................................... 18360.049 (56.2823 %)
Processing of input data ......................... 1015.436 ( 3.1128 %)
Computation of vertical boundary conditions ...... 87.350 ( 0.2678 %)
Computation of global information integrals ...... 1880.285 ( 5.7640 %)
2D/3D coupling, vertical metrics ................. 486.022 ( 1.4899 %)
Omega vertical velocity .......................... 375.724 ( 1.1518 %)
Equation of state for seawater ................... 1370.897 ( 4.2025 %)
Atmosphere-Ocean bulk flux parameterization ...... 327.061 ( 1.0026 %)
KPP vertical mixing parameterization ............. 364.822 ( 1.1184 %)
Total: 24267.645 74.3919
Message Passage: 2D halo exchanges ............... 7772.868 (23.8276 %)
Message Passage: 3D halo exchanges ............... 3648.635 (11.1848 %)
Message Passage: 4D halo exchanges ............... 442.725 ( 1.3572 %)
Message Passage: data broadcast .................. 2629.493 ( 8.0607 %)
Message Passage: data reduction .................. 12382.207 (37.9574 %)
Total: 26875.928 82.3876
All percentages are with respect to total time = 32621.340
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_cloud.h
ROMS/Functionals/ana_grid.h
ROMS/Functionals/ana_humid.h
ROMS/Functionals/ana_pair.h
ROMS/Functionals/ana_rain.h
ROMS/Functionals/ana_srflux.h
ROMS/Functionals/ana_stflux.h
ROMS/Functionals/ana_tair.h
ROMS/Functionals/ana_winds.h
REASON: No such file or directory
PS:
Read file <benchmark4_err_file> for stderr output of this job.
