Hey Folks
I am running ROMS with the input file ocean_benchmark4.in with NtileI = 2 and NtileJ = 4 and number of processes = 8 on 1 node.It is giving the following error in the output file :
REASON: No such file or directory
Please help asap
Prakrati
Abnormal Termination of ROMS run
Re: Abnormal Termination of ROMS run
You really do not provide a great deal the information and want our help right away... The benchmark does not use I/O files. You can activate writing history NetCDF files, if you like. You need to redirect standard output into a log file. You will find out that there is a lot of information dumped that helps to diagnose the problem. You are just printing out the last line of standard output. There is not way for us to tell what it is going on.
Please check your standard output carefully.
Benchmark Test, Idealized Southern Ocean, Large Grid
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /app/intel/impi/3.1/bin64/mpiifort
Compiler flags : -heap-arrays -g -ftrapuv -traceback -free
Input Script : /homenc/ipaes84/FinalROMS/ROMS/ROMS/roms-3.1/ROMS/ocean_benchmark4.in
SVN Revision :
Local Root : /homenc/ipaes84/FinalROMS/ROMS/ROMS/roms-3.1
Header Dir : /homenc/ipaes84/FinalROMS/ROMS/ROMS/roms-3.1/ROMS
Header file : benchmark.h
Analytical Dir: /homenc/ipaes84/FinalROMS/ROMS/ROMS/roms-3.1/ROMS
Resolution, Grid 01: 4192x0272x030, Parallel Nodes: 8, Tiling: 002x004
17532 ntimes Number of timesteps for 3-D equations.
150.000 dt Timestep size (s) for 3-D equations.
17532 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
17532 nHIS Number of timesteps between the writing fields
into history file.
17532 ndefHIS Number of timesteps between creation of new
history files.
5.0000E+02 tnu2(01) Horizontal, harmonic mixing coefficient (m2/s)
5.0000E+02 tnu2(02) Horizontal, harmonic mixing coefficient (m2/s)
for tracer 02: salt
5.0000E+03 visc2 Horizontal, harmonic mixing coefficient (m2/s)
1.0000E-05 Akt_bak(01) Background vertical mixing coefficient (m2/s)
1.0000E-05 Akt_bak(02) Background vertical mixing coefficient (m2/s)
for tracer 02: salt
1.0000E-04 Akv_bak Background vertical mixing coefficient (m2/s)
1.0000E+01 blk_ZQ Height (m) of surface air humidity measurement.
1.0000E+01 blk_ZT Height (m) of surface air temperature measurement.
1.0000E+01 blk_ZW Height (m) of surface winds measurement.
1 lmd_Jwt Jerlov water type.
5.0000E+00 theta_s S-coordinate surface control parameter.
4.0000E-01 theta_b S-coordinate bottom control parameter.
200.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
T Hout(idTsur) Write out surface net heat flux.
T Hout(idTsur) Write out surface net salt flux.
T Hout(idSrad) Write out shortwave radiation flux.
T Hout(idLrad) Write out longwave radiation flux.
T Hout(idLhea) Write out latent heat flux.
T Hout(idShea) Write out sensible heat flux.
T Hout(idHsbl) Write out depth of surface boundary layer.
Output Restart File: ./output/ocean_rst.nc
Prefix for History Files: ./output/ocean_his
Tile partition information for Grid 01: 4192x0272x0030 tiling: 002x004
tile Istr Iend Jstr Jend Npts
0 1 2096 1 68 4275840
1 2097 4192 1 68 4275840
2 1 2096 69 136 4275840
3 2097 4192 69 136 4275840
4 1 2096 137 204 4275840
5 2097 4192 137 204 4275840
6 1 2096 205 272 4275840
7 2097 4192 205 272 4275840
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 2096.50 0.50 68.50 RHO-points
1 2096.50 4192.50 0.50 68.50 RHO-points
2 0.50 2096.50 68.50 136.50 RHO-points
3 2096.50 4192.50 68.50 136.50 RHO-points
4 0.50 2096.50 136.50 204.50 RHO-points
5 2096.50 4192.50 136.50 204.50 RHO-points
6 0.50 2096.50 204.50 272.50 RHO-points
7 2096.50 4192.50 204.50 272.50 RHO-points
0 1.00 2096.50 0.50 68.50 U-points
1 2096.50 4192.00 0.50 68.50 U-points
2 1.00 2096.50 68.50 136.50 U-points
3 2096.50 4192.00 68.50 136.50 U-points
4 1.00 2096.50 136.50 204.50 U-points
5 2096.50 4192.00 136.50 204.50 U-points
6 1.00 2096.50 204.50 272.50 U-points
7 2096.50 4192.00 204.50 272.50 U-points
0 0.50 2096.50 1.00 68.50 V-points
1 2096.50 4192.50 1.00 68.50 V-points
2 0.50 2096.50 68.50 136.50 V-points
3 2096.50 4192.50 68.50 136.50 V-points
4 0.50 2096.50 136.50 204.50 V-points
5 2096.50 4192.50 136.50 204.50 V-points
6 0.50 2096.50 204.50 272.00 V-points
7 2096.50 4192.50 204.50 272.00 V-points
HaloSizeI(1) = 6327
HaloSizeJ(1) = 240
TileSide(1) = 2103
TileSize(1) = 155622
BENCHMARK Benchmark Test, Idealized Southern Ocean, Large Grid
ALBEDO Shortwave radiation from albedo equation.
ANA_CLOUD Analytical cloud fraction.
ANA_HUMIDITY Analytical surface air humidity.
ANA_PAIR Analytical surface air pressure.
ANA_RAIN Analytical rain fall rate.
ANA_SRFLUX Analytical kinematic shortwave radiation flux.
ANA_WINDS Analytical surface wind components.
BULK_FLUXES Surface bulk fluxes parametererization.
EW_PERIODIC East-West periodic boundaries.
LMD_CONVEC LMD convective mixing due to shear instability.
LMD_MIXING Large/McWilliams/Doney interior mixing.
LMD_NONLOCAL LMD convective nonlocal transport.
LMD_RIMIX LMD diffusivity due to shear instability.
LMD_SKPP KPP surface boundary layer mixing.
LONGWAVE Compute net longwave radiation internally.
NONLINEAR Nonlinear Model.
NORTHERN_WALL Wall boundary at Northern edge.
SALINITY Using salinity.
SOUTHERN_WALL Wall boundary at Southern edge.
SPHERICAL Spherical grid configuration.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Vertical S-coordinate System:
30 0.0000000 0.0000000 0.000 0.000 0.000
29 -0.0333333 -0.0024174 -7.392 -11.622 -15.853
28 -0.0666667 -0.0052838 -14.918 -24.165 -33.412
27 -0.1000000 -0.0087922 -22.638 -38.024 -53.410
26 -0.1333333 -0.0131904 -30.624 -53.707 -76.790
25 -0.1666667 -0.0187972 -38.973 -71.868 -104.763
24 -0.2000000 -0.0260168 -47.805 -93.334 -138.864
23 -0.2333333 -0.0353508 -57.272 -119.136 -181.000
22 -0.2666667 -0.0473981 -67.553 -150.499 -233.446
21 -0.3000000 -0.0628318 -78.850 -188.805 -298.761
20 -0.3333333 -0.0823381 -91.368 -235.460 -379.551
19 -0.3666667 -0.1065031 -105.284 -291.665 -478.045
18 -0.4000000 -0.1356491 -120.695 -358.081 -595.466
17 -0.4333333 -0.1696534 -137.563 -434.456 -731.349
16 -0.4666667 -0.2078237 -155.680 -519.372 -883.063
15 -0.5000000 -0.2489214 -174.676 -610.289 -1045.901
14 -0.5333333 -0.2913811 -194.081 -703.998 -1213.915
13 -0.5666667 -0.3336756 -213.436 -797.368 -1381.301
12 -0.6000000 -0.3746809 -232.404 -888.096 -1543.788
11 -0.6333333 -0.4138998 -250.837 -975.161 -1699.486
10 -0.6666667 -0.4514899 -268.780 -1058.888 -1848.995
9 -0.7000000 -0.4881475 -286.444 -1140.702 -1994.960
8 -0.7333333 -0.5249360 -304.147 -1222.785 -2141.423
7 -0.7666667 -0.5631362 -322.274 -1307.762 -2293.251
6 -0.8000000 -0.6041494 -341.245 -1398.506 -2455.768
5 -0.8333333 -0.6494565 -361.504 -1498.053 -2634.601
4 -0.8666667 -0.7006196 -383.519 -1609.604 -2835.688
3 -0.9000000 -0.7593114 -407.793 -1736.588 -3065.383
2 -0.9333333 -0.8273620 -434.875 -1882.759 -3330.642
1 -0.9666667 -0.9068164 -465.378 -2052.307 -3639.236
0 -1.0000000 -1.0000000 -500.000 -2250.000 -4000.000
Time Splitting Weights: ndtfast = 20 nfast = 29
3-0.0011514592651645 0.0501156998674241-0.0034654566136460 0.1501639558342179
4-0.0003735756740661 0.0501732728306823-0.0038390322877122 0.2003372286649002
5 0.0009829200513762 0.0501919516143856-0.0028561122363360 0.2505291802792858
6 0.0029141799764308 0.0501428056118168 0.0000580677400948 0.3006719858911026
7 0.0054132615310267 0.0499970966129952 0.0054713292711215 0.3506690825040978
8 0.0084687837865132 0.0497264335364439 0.0139401130576347 0.4003955160405417
9 0.0120633394191050 0.0493029943471183 0.0260034524767397 0.4496985103876600
10 0.0161716623600090 0.0486998273761630 0.0421751148367486 0.4983983377638230
11 0.0207585511322367 0.0478912442581626 0.0629336659689853 0.5462895820219856
12 0.0257765478740990 0.0468533167015507 0.0887102138430843 0.5931428987235363
13 0.0311633730493853 0.0455644893078458 0.1198735868924696 0.6387073880313821
14 0.0368391158442262 0.0440063206553765 0.1567127027366958 0.6827137086867585
15 0.0427031802506397 0.0421643648631652 0.1994158829873354 0.7248780735499237
16 0.0486309868367616 0.0400292058506332 0.2480468698240970 0.7649072794005569
17 0.0544704302037591 0.0375976565087951 0.3025173000278562 0.8025049359093520
18 0.0600380921294285 0.0348741349986072 0.3625553921572847 0.8373790709079592
19 0.0651152103984763 0.0318722303921358 0.4276706025557610 0.8692513013000949
20 0.0694434033194839 0.0286164698722119 0.4971140058752449 0.8978677711723068
21 0.0727201499285569 0.0251442997062377 0.5698341558038018 0.9230120708785445
22 0.0745940258796570 0.0215082922098099 0.6444281816834588 0.9445203630883544
23 0.0746596950216180 0.0177785909158270 0.7190878767050768 0.9622989540041814
24 0.0724526566618460 0.0140456061647461 0.7915405333669228 0.9763445601689276
25 0.0674437485167025 0.0104229733316538 0.8589842818836253 0.9867675335005814
26 0.0590334053485720 0.0070507859058187 0.9180176872321973 0.9938183194064002
27 0.0465456732896125 0.0040991156383901 0.9645633605218099 0.9979174350447904
28 0.0292219798521905 0.0017718319739095 0.9937853403740005 0.9996892670186999
29 0.0062146596259994 0.0003107329813000 0.9999999999999999 0.9999999999999999
Minimum X-grid spacing, DXmin = 3.26041548E+00 km
Maximum X-grid spacing, DXmax = 6.14309257E+00 km
Minimum Y-grid spacing, DYmin = 8.17650180E+00 km
Maximum Y-grid spacing, DYmax = 8.17650180E+00 km
Minimum Z-grid spacing, DZmin = 7.39187981E+00 m
Maximum Z-grid spacing, DZmax = 3.60764219E+02 m
Minimum barotropic Courant Number = 1.62217863E-01
Maximum barotropic Courant Number = 4.49102838E-01
Maximum Coriolis Courant Number = 2.05618380E-02
Maximum grid stiffness ratios: rx0 = 3.966042E-01 (Beckmann and Haidvogel)
rx1 = 1.150589E+01 (Haney)
Initial basin volumes: TotVolume = 1.65993987026582E+17 m3
MinVolume = 1.97754634567622E+08 m3
MaxVolume = 1.80931355725002E+10 m3
Max/Min = 9.14928523018421E+01
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00017532)
0 0 00:00:00 0.000000E+00 1.963001E+04 1.963001E+04 1.659940E+17
DEF_HIS - creating history file: ./output/ocean_his_0001.nc
NETCDF_CREATE - unable to create output NetCDF file:
call from: def_his.F
DEF_HIS - unable to create history NetCDF file: ./output/ocean_his_0001.nc
Elapsed CPU time (seconds):
Node # 1 CPU: 23.822
Node # 2 CPU: 24.275
Node # 6 CPU: 24.522
Node # 5 CPU: 24.664
Node # 3 CPU: 24.089
Node # 7 CPU: 24.488
Node # 0 CPU: 24.254
Node # 4 CPU: 24.625
Total: 194.741
Initialization ................................... 46.832 (24.0482 %)
Processing of input data ......................... 0.426 ( 0.2187 %)
Computation of vertical boundary conditions ...... 0.241 ( 0.1237 %)
Computation of global information integrals ...... 4.905 ( 2.5189 %)
2D/3D coupling, vertical metrics ................. 7.077 ( 3.6340 %)
Omega vertical velocity .......................... 5.294 ( 2.7186 %)
Equation of state for seawater ................... 34.125 (17.5231 %)
Atmosphere-Ocean bulk flux parameterization ...... 3.658 ( 1.8786 %)
KPP vertical mixing parameterization ............. 50.665 (26.0167 %)
Total: 153.224 78.6806
Nonlinear model message Passage profile:
Message Passage: 2D halo exchanges ............... 3.334 ( 1.7118 %)
Message Passage: 3D halo exchanges ............... 5.504 ( 2.8264 %)
Message Passage: 4D halo exchanges ............... 1.132 ( 0.5812 %)
Message Passage: data broadcast .................. 0.892 ( 0.4580 %)
Message Passage: data reduction .................. 0.195 ( 0.1001 %)
Total: 11.056 5.6774
All percentages are with respect to total time = 194.741
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_cloud.h
ROMS/Functionals/ana_grid.h
ROMS/Functionals/ana_humid.h
ROMS/Functionals/ana_pair.h
ROMS/Functionals/ana_rain.h
ROMS/Functionals/ana_srflux.h
ROMS/Functionals/ana_stflux.h
ROMS/Functionals/ana_tair.h
ROMS/Functionals/ana_winds.h
ROMS/TOMS - Output error ............ exit_flag: 3
PS:
Read file <err_file> for stderr output of this job.
The error cannot be clearer It is telling that the model is unable to create the file ./output/ocean_his_0001.nc. Either the directory ./output doesn't exist or you don't have privileges to write into that directory. If this is not the case, something is wrong with your NetCDF library. The NetCDF library has to be build with the same compiler used in ROMS.prakrati wrote: NETCDF_CREATE - unable to create output NetCDF file: ./output/ocean_his_0001.nc
Please can you help and tell me where this output file should be? I created the output file in the same directory which contains my executable but it still gave the same error .
Also the NetCDF library has been compiled with the same compilers as the ROMS
Please help
Please help
Did you build netcdf and run it through its own tests with "make check"?
I always get in trouble when I fill my disk quota. Do you have a system with quotas? Are you running interactively or through some batch system with possibly different permissions?
You can set NHIS and NRST in ocean_benchmark4.in to a value larger than 17532, so no output files are created. This will allow the model to continue running. Your grid is very large 4192x0272x030 and you may be having memory issues. Perhaps, you also need to increase the number of nodes to fit your model in cache. You are using a 2x4 partition. Your tile in the x-dimension is still large. Try any of the other input script like ocean_benchmark1.in to see if run with smaller grid.
