ROMS plotting package installation
rbauer
#1 Unread post by rbauer »
Hello!
I am trying to install the ROMS plotting package.
I downloaded the "NCL Version 5.2.1 precompiled binaries, OPeNDAP-enabled" and used the manual on
http://www.ncl.ucar.edu/get_started.shtml
to set it up.
However, I am getting the following error messsage when compiling the plotting package:
/usr/bin/gfortran -c -frepack-arrays -x f95-cpp-input -O3 -ffast-math slevels.f90
slevels.f90:180.33:
      integer file, nc_gid, tindx
                                 1
Error: Symbol 'tindx' at (1) already has basic type of INTEGER
slevels.f90:189.10:
      file=1
          1
Error: Symbol 'file' at (1) has no IMPLICIT type
slevels.f90:192.14:
        nc_gid=ncgrd
              1
Error: Symbol 'nc_gid' at (1) has no IMPLICIT type
I've chosen the gfortran compiler (as you can see from the code above).
Thank you for your help!
Robert
robertson
Re: ROMS plotting package installation
#2 Unread post by robertson »
On line 35 of src/Utility/slevels.F you need to remove ", tindx" from the end of that line so it reads:
This doesn't phase most compilers but gfortran is quite picky about types. This typo will probably be fixed soon, but for now you can correct it yourself. The error is caused by the fact that tindx is declared an integer in src/Include/ncinfo.h which is included before line 35 of the src/Utility/slevels.F file.
