USE exchange_3d_mod, How to fix this.
pip39
#1 Unread post by pip39 »
I want use ini_sed.nc (The initial sediment data from roms_ini.nc)
so In cppdefs.h
I should have
#undef ana_initial
#undef ana_sediment
but #undef ana_sediment have some Problem
/game/Build; /usr/bin/mpif90 -c -frepack-arrays -O3 -ffast-math mod_arrays.f90
cd /home/pip/roms/projects/game/Build; /usr/bin/mpif90 -c -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none analytical.f90
analytical.f90:83.33:
USE exchange_3d_mod, ONLY : exchange_r3d_tile
1
Error: Symbol 'exchange_r3d_tile' referenced at (1) not found in module 'exchange_3d_mod'
I don't really dig what the message says and even less how I could fix this.
Does anyone have an idea to sort this out ?
As information, here is my CPP options:
#define UV_QDRAG /* use to turn ON or OFF quadratic bottom friction */
#define UV_VIS4 /* use to turn ON or OFF harmonic horizontal mixing */
#define MIX_S_UV /* momentum mixing on s-surfaces */
#define DJ_GRADPS /* use if splines density Jacobian (Shchepetkin, 2000) */
#define TS_U3HADVECTION /* use if 3rd-order upstream horiz. advection */
#define TS_C4VADVECTION /* use if 4th-order centered vertical advection */
#define SOLVE3D /* use if solving 3D primitive equations */
#define SPLINES /* use to activate parabolic splines reconstruction */
#define SEDIMENT
#define SUSPLOAD
#define AVERAGES_AKV
#define AVERAGES_AKS
#define AVERAGES_BEDLOAD
#define BVF_MIXING
#define SPONGE
#define SOUTH_M3RADIATION
#define SOUTH_M3NUDGING
#define NORTH_M3CLAMPED
#define NORTH_M3NUDGING
#define NORTH_TRADIATION
#define NORTH_TNUDGING
#define WEST_M3RADIATION
#define EAST_M3RADIATION
#undef ana_initial
#undef ana_sediment
#define ANA_TOBC
#define ANA_SMFLUX
#define ANA_STFLUX
#define ANA_SSFLUX
#define ANA_SPFLUX
#define ANA_BPFLUX
#define ANA_BMFLUX
#define MIX_GEO_UV
#define KANTHA_CLAYSON
#define N2S2_HORAVG
#define BEDLOAD_MPM
#define SED_DENS
#define NLM_DRIVER
