Hi, everyone!
I changed the vertical turbulent mixing scheme from gls(k-kl) to MY25, the problem is still existing.
MY25 with U3HADVECTION + C4VADVECTION
The temperature is high on the bottom layer and it is low in the upper layer.
Here's my parameters:
7.5000E+02 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
7.5000E+02 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
5.0000E+01 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
1.5000E-03 rdrg2 Quadratic bottom drag coefficient.
1.0000E-03 Zob Bottom roughness (m).
1 lmd_Jwt Jerlov water type.
4.0000E+00 theta_s S-coordinate surface control parameter.
20000101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
3.6000E+02 Tnudg(01) Nudging/relaxation time scale (days)
3.6000E+02 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
3.6000E+02 Znudg Nudging/relaxation time scale (days)
3.6000E+02 M2nudg Nudging/relaxation time scale (days)
3.6000E+02 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.2000E+02 obcfac Factor between passive and active
ADD_FSOBC Adding tidal elevation to proccesed OBC data.
ADD_M2OBC Adding tidal currents to proccesed OBC data.
EAST_M3NUDGING Eastern edge, 3D momentum, passive/active outflow/inflow.
EAST_TNUDGING Eastern edge, tracers, passive/active outflow/inflow.
EAST_VOLCONS Eastern edge, enforce mass conservation.
MASKING Land/Sea masking.
MY25_MIXING Mellor/Yamada Level-2.5 mixing closure.
NONLINEAR Nonlinear Model.
QCORRECTION Surface net heat flux correction.
RAMP_TIDES Ramping tidal forcing for one day.
SALINITY Using salinity.
SOUTH_M3NUDGING Southern edge, 3D momentum, passive/active outflow/inflow.
SOUTH_TNUDGING Southern edge, tracers, passive/active outflow/inflow.
SOUTH_VOLCONS Southern edge, enforce mass conservation.
SPHERICAL Spherical grid configuration.
TS_PSOURCE Tracers point sources and sinks.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_PSOURCE Mass point sources and sinks.
VISC_3DCOEF Horizontal, time-dependent 3D viscosity coefficient.
