compiling ROMS
rbauer
compiling ROMS
#1 Unread post by rbauer »
hey there!
i tried to compile roms but i get the following error message:
makefile:237: INCLUDING FILE Build/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE DEFINITIONS
cd Build; -c -O3 mod_kinds.f90
/bin/sh: -c: not found
make: *** [Build/mod_kinds.o] Error 127
beforehand i had to change the path of netcdf within the Linux-g95.mk file.
i appreciate any help!
thanks a lot!
Re: compiling ROMS
It doesn't know what Fortran compiler to invoke. Are you telling it:
FORT ?= g95
then in the Linux-g95.mk file,
FC := g95
rbauer
Re: compiling ROMS
#3 Unread post by rbauer »
thank you for your response, kate. well, as far as i've understood, there's a list of mk-files which relate to different compilers. i am running linux ubuntu 10.04 64bit and the gfortran compiler is installed. therefore i changed the path of netcdf within the Linux-gfortran.mk file too.
however, i am still getting the same response.
these are the settings within the default section of the Linux-gfortran.mk file:
# First the defaults
FC := gfortran
FFLAGS := -frepack-arrays
CPP := /usr/bin/cpp
CPPFLAGS := -P -traditional
LDFLAGS :=
AR := ar
ARFLAGS := -r
MKDIR := mkdir -p
RM := rm -f
RANLIB := ranlib
PERL := perl
TEST := test
MDEPFLAGS := --cpp --fext=f90 --file=- --objdir=$(SCRATCH_DIR)
# Library locations, can be overridden by environment variables.
again, thank you for your help!
Re: compiling ROMS
Well, you can try something like "make -p | grep FC" to see what it thinks FC is. I get:
make -f makefile.UP -p | grep FC
FC := /usr/local/pkg/pgi/pgi-9.0.4/linux86-64/9.0-4/bin/pgf90
which reminds me of this little piece of Linux-pgi.mk:
# Use full path of compiler.
               FC := $(shell which ${FC})
               LD := $(FC)
Is gfortran in your path?
rbauer
Re: compiling ROMS
#5 Unread post by rbauer »
if i run"make -p | grep FC" i get this:
PREPROCESS.F = $(FC) $(FFLAGS) $(CPPFLAGS) $(TARGET_ARCH) -F
LINK.r = $(FC) $(FFLAGS) $(RFLAGS) $(LDFLAGS) $(TARGET_ARCH)
COMPILE.f = $(FC) $(FFLAGS) $(TARGET_ARCH) -c
COMPILE.F = $(FC) $(FFLAGS) $(CPPFLAGS) $(TARGET_ARCH) -c
PREPROCESS.r = $(FC) $(FFLAGS) $(RFLAGS) $(TARGET_ARCH) -F
cd $$(SCRATCH_DIR); $$(FC) -c $$(FFLAGS) $(notdir $2)
FC :=
F77 = $(FC)
COMPILE.r = $(FC) $(FFLAGS) $(RFLAGS) $(TARGET_ARCH) -c
LINK.F = $(FC) $(FFLAGS) $(CPPFLAGS) $(LDFLAGS) $(TARGET_ARCH)
LINK.f = $(FC) $(FFLAGS) $(LDFLAGS) $(TARGET_ARCH)
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) $(notdir $<)
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) frc_weak.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) def_dim.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) wrt_impulse.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) oi_update.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) back_cost.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) def_impulse.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) ini_hmixcoef.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) distribute.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_kinds.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) stats_modobs.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_nesting.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) zetabc.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) checkerror.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) set_ngfldr.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) sed_surface.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) bulk_flux.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_coupling.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) nf_fread3d_bry.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) shapiro.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_coupler.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) grid_coords.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) u3dbc_im.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) step3d_uv.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_stepping.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) def_hessian.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) nf_fwrite3d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) cgradient.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) radiation_stress.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_ocean.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) def_mod.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) def_tides.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) main2d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) interp_floats.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) get_2dfld.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) wrt_diags.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) frc_adjust.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) bc_bry2d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) checkvars.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) sum_grad.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) pre_step3d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_eclight.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mp_routines.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) conv_bry2d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_parallel.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) metrics.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) nf_fread3d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) gasdev.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) rep_matrix.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) ludcmp.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) get_data.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) wpoints.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) state_initialize.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) get_3dfld.f90
# CPPFLAGS += -DMY_OS='"$(OS)"' -DMY_CPU='"$(CPU)"' -DMY_FORT='"$(FORT)"' -DMY_FC='"$(FC)"' -DMY_FFLAGS='"$(FFLAGS)"'
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) set_zeta.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_sediment.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) set_diags.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) posterior.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) strings.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) bbl.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) stiffness.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) omega.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_mixing.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_fourdvar.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) hmixing.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) ocean_coupler.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) prsgrd.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) congrad.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) output.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) packing.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_storage.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) regrid.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_strings.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) lmd_bkpp.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) tkebc_im.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) esmf_roms.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) gls_corstep.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_floats.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) ran_state.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) close_io.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) extract_sta.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) ran1.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) initial.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) set_3dfld.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_diags.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) sed_bedload.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) wrt_error.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) main3d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) wetdry.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) sed_bed.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) lmd_vmix.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) conv_2d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) wrt_station.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_arrays.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) def_error.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mpdata_adiff.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) state_addition.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) random_ic.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) def_station.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) step_floats.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_biology.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_bbl.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) wrt_info.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_obs.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) wrt_hessian.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) rho_eos.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_tides.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) set_avg.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) get_3dfldr.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) get_ngfld.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) get_state.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) wrt_gst.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) obs_cost.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) t3dmix.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) wrt_ini.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) set_2dfld.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) sed_fluxes.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_param.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) def_gst.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_grid.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) obs_depth.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) lmd_skpp.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) sediment.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) def_ini.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_sedbed.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) nf_fwrite4d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) abort.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_clima.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) wrt_his.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) wrt_floats.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) interpolate.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) set_vbc.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) posterior_var.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) bc_bry3d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) def_var.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) get_idata.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) exchange_2d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) conv_bry3d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) state_scale.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) def_his.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) def_floats.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) def_info.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) conv_3d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) master.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) def_diags.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) white_noise.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) bc_2d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) v2dbc_im.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) obc_volcons.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) obs_read.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) inp_par.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) roms_import.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) nf_fread4d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_boundary.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_forces.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) checkadj.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) biology.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) obc_adjust.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) my25_prestep.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) set_data.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) vwalk_floats.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) set_depth.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) get_bounds.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) sed_settling.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) state_dotprod.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) set_weights.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) step3d_t.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) cost_grad.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) set_tides.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_scalars.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) checkdefs.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) diag.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) ocean_control.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) propagator.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) t3dbc_im.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) extract_obs.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) get_varcoords.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) step2d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) def_lanczos.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) vorticity.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) lubksb.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) gls_prestep.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) get_gst.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) get_ngfldr.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) wrt_avg.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) wrt_tides.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) def_avg.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) nrutil.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_sources.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) wrt_rst.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mp_exchange.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) ini_fields.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) rhs3d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_average.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) analytical.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) set_massflux.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) nf_fwrite2d_bry.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) def_rst.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) nf_fread2d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) get_cycle.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) set_2dfldr.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) uv3dmix.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) utility.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) array_modes.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) v3dbc_im.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) zeta_balance.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) exchange_3d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) u2dbc_im.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) obs_write.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) state_product.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) set_scoord.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) def_norm.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) normalization.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) my25_corstep.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) set_3dfldr.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) nf_fread2d_bry.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) set_ngfld.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) ini_lanczos.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_eoscoef.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_netcdf.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) nf_fwrite2d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) get_date.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) get_2dfldr.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_ncparam.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) forcing.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) state_copy.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) timers.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) obs_initial.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) wvelocity.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) ini_adjust.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) bc_3d.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) roms_export.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) get_grid.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) mod_iounits.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) dotproduct.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) bvf_mix.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) nf_fwrite3d_bry.f90
cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) lmd_swfrac.f90
it seems like i've do define the fortran compiler... . but where?
Re: compiling ROMS
#6 Unread post by kate »
Above, you show part of your Linux-gfortran.mk file. Below that in the same file, there should be:
               LD := $(FC)
This sets FC to be not just gfortran but /some/long/path/to/gfortran assuming it is in your path. What do you get from:
cygnus.arsc.edu 244% which gfortran
/usr/bin/gfortran
or
be1005en% which gfortran
gfortran: Command not found.
If make isn't finding it, but you know it's there, you can always just tell it:
               FC := /some/long/path/to/gfortran
               LD := $(FC)
Of course, put this after the one with "shell which".
robertson
Re: compiling ROMS
#7 Unread post by robertson »
Sometimes gfortran is not called gfortran, sometimes it's something like gfortran44 for gfortran version 4.4.x. You need to find out what gfortran is actually called on your machine and use that name when making the adjustment Kate mentioned.
rbauer
Re: compiling ROMS
#8 Unread post by rbauer »
i specified the gfortran compiler within the makefile and its location as you recommended within the Linux-gfortran.mk file. so i guess i managed the fortran compiler issue.
however, i am still getting the following error message:
robert@bauer:~/ROMS/trunk$ make
cd Build; /usr/bin/gfortran -c -frepack-arrays -O3 -ffast-math bc_2d.f90
bc_2d.f90:100.18:
USE mod_grid
1
Fatal Error: Can't open module file 'mod_grid.mod' for reading at (1): No such file or directory
make: *** [Build/bc_2d.o] Error 1
i've put my makefile and Linux-gfortran.mk file on a server:
http://dl.dropbox.com/u/1777473/ROMS/Linux-gfortran.mk
http://dl.dropbox.com/u/1777473/ROMS/makefile
thanks!
Re: compiling ROMS
#9 Unread post by kate »
Now you are facing a dependency issue which should be fixed by Build/MakeDepend, one of the first things that gets built by the makefile. If you type:
make clean
then
make
what is the first big chunk of output? What does MakeDepend look like?
cebalhos
Re: compiling ROMS
#10 Unread post by cebalhos »
Hello!
I'm finding the same thing.
Someone managed to fix this error?
Re: compiling ROMS
#11 Unread post by kate »
Exactly which error are you seeing? Have you read this entire thread carefully?
