I performed some simulations with a modified GRAV_ADJ case with the latest source code which I downloaded a few weeks ago, the model resulted in really different solutions when my rectangular basin is closed with MASKING option instead of the WALL CPPFLAGS, actually when the masking is activated mpdata scheme finds really lower salinity values than the minumum of the initial field (without any forcing), this difference increases when the grid size is increased. When MPDATA is switched with TS_U3HADVECTION and TS_SVADVECTION schemes, masking and wall definitions don't differ much.
I did lots of tests to resolve this situation, finally I thought that the MPDATA advection scheme may have a little bug when used with the masking option. After some searching in the code, I concluded that the problem is; mpdata_adiff.F's supressing false oscillations by limiting the transport fluxes without skipping the masked points, it is better to consider the mask array while calculating the Max and Min of the advected tracer. My solution is (with line numbers) modifying the mpdata_adiff.F as:
adding a mask_min array
143 real(r8), dimension(IminS:ImaxS,JminS:JmaxS) :: mask_min
870 ! Scale advected tracer to Tunits.
871 !
872 DO k=1,N(ng)
873 DO j=-1+J_RANGE+1
874 DO i=-1+I_RANGE+1
875 Tadv(i,j,k)=t(i,j,k)
876 if (rmask(i,j).lt.0.5) then
877 mask_min(i,j)=100.0_r8
878 Tadv(i,j,k)=1.0
879 Ta(i,j,k)=1.0
880 else
881 mask_min(i,j)=1.0_r8
882 endif
883 END DO
884 END DO
885 END DO
and skip masked points while calculating Max and Min.
! Compute UP and DOWN beta-ratios.
888 !
889 DO j=J_RANGE
890 k=1
891 DO i=I_RANGE
892 Tmax=MAX(Ta(i-1,j ,k )*rmask(i-1,j ),Tadv(i-1,j ,k ) &
893 & *rmask(i-1,j ), &
894 & Ta(i ,j ,k )*rmask(i ,j ),Tadv(i ,j ,k ) &
895 & *rmask(i ,j ), &
896 & Ta(i+1,j ,k )*rmask(i+1,j ),Tadv(i+1,j ,k ) &
897 & *rmask(i+1,j ), &
898 & Ta(i ,j-1,k )*rmask(i ,j-1),Tadv(i ,j-1,k ) &
899 & *rmask(i ,j-1), &
900 & Ta(i ,j+1,k )*rmask(i ,j+1),Tadv(i ,j+1,k ) &
901 & *rmask(i ,j+1), &
902 & Ta(i ,j ,k+1)*rmask(i ,j ),Tadv(i ,j ,k+1) &
903 *rmask(i ,j ))
904 cff1=Ta(i-1,j ,k )*MAX(0.0_r8,Ua(i ,j ,k ))- &
905 & Ta(i+1,j ,k )*MIN(0.0_r8,Ua(i+1,j ,k ))+ &
906 & Ta(i ,j-1,k )*MAX(0.0_r8,Va(i ,j ,k ))- &
907 & Ta(i ,j+1,k )*MIN(0.0_r8,Va(i ,j+1,k ))- &
908 & Ta(i ,j ,k+1)*MIN(0.0_r8,Wa(i ,j ,k ))
909 beta_up(i,j,k)=(Tmax-Ta(i,j,k))/(cff1+eps)
910 !
911 Tmin=MIN(Ta(i-1,j ,k )*mask_min(i-1,j ),Tadv(i-1,j ,k ) &
912 & *mask_min(i-1,j ), &
913 & Ta(i ,j ,k )*mask_min(i ,j ),Tadv(i ,j ,k ) &
914 & *mask_min(i ,j ), &
915 & Ta(i+1,j ,k )*mask_min(i+1,j ),Tadv(i+1,j ,k ) &
916 & *mask_min(i+1,j ), &
917 & Ta(i ,j-1,k )*mask_min(i ,j-1),Tadv(i ,j-1,k ) &
918 & *mask_min(i ,j-1), &
919 & Ta(i ,j+1,k )*mask_min(i ,j+1),Tadv(i ,j+1,k ) &
920 & *mask_min(i ,j+1), &
921 & Ta(i ,j ,k+1)*mask_min(i ,j ),Tadv(i ,j ,k+1) &
922 & *mask_min(i ,j ))
923 cff2=Ta(i ,j ,k )*MAX(0.0_r8,Ua(i+1,j ,k ))- &
924 & Ta(i ,j ,k )*MIN(0.0_r8,Ua(i ,j ,k ))+ &
925 & Ta(i ,j ,k )*MAX(0.0_r8,Va(i ,j+1,k ))- &
926 & Ta(i ,j ,k )*MIN(0.0_r8,Va(i ,j ,k ))+ &
927 & Ta(i ,j ,k )*MAX(0.0_r8,Wa(i ,j ,k ))
928 beta_dn(i,j,k)=(Ta(i,j,k)-Tmin)/(cff2+eps)
929 END DO
930 DO k=2,N(ng)-1
931 DO i=I_RANGE
932 Tmax=MAX(Ta(i-1,j ,k )*rmask(i-1,j ),Tadv(i-1,j ,k ) &
933 *rmask(i-1,j ), &
934 & Ta(i ,j ,k )*rmask(i ,j ),Tadv(i ,j ,k ) &
935 & *rmask(i ,j ), &
936 & Ta(i+1,j ,k )*rmask(i+1,j ),Tadv(i+1,j ,k ) &
937 & *rmask(i+1,j ), &
938 & Ta(i ,j-1,k )*rmask(i ,j-1),Tadv(i ,j-1,k ) &
939 & *rmask(i ,j-1), &
940 & Ta(i ,j+1,k )*rmask(i ,j+1),Tadv(i ,j+1,k ) &
941 & *rmask(i ,j+1), &
942 & Ta(i ,j ,k-1)*rmask(i ,j ),Tadv(i ,j ,k-1) &
943 & *rmask(i ,j ), &
944 & Ta(i ,j ,k+1)*rmask(i ,j ),Tadv(i ,j ,k+1) &
945 & *rmask(i ,j ))
946 cff1=Ta(i-1,j ,k )*MAX(0.0_r8,Ua(i ,j ,k ))- &
947 & Ta(i+1,j ,k )*MIN(0.0_r8,Ua(i+1,j ,k ))+ &
948 & Ta(i ,j-1,k )*MAX(0.0_r8,Va(i ,j ,k ))- &
949 & Ta(i ,j+1,k )*MIN(0.0_r8,Va(i ,j+1,k ))+ &
950 & Ta(i ,j ,k-1)*MAX(0.0_r8,Wa(i ,j ,k-1))- &
951 & Ta(i ,j ,k+1)*MIN(0.0_r8,Wa(i ,j ,k ))
952 beta_up(i,j,k)=(Tmax-Ta(i,j,k))/(cff1+eps)
953 !
954 Tmin=MIN(Ta(i-1,j ,k )*mask_min(i-1,j ),Tadv(i-1,j ,k) &
955 & *mask_min(i-1,j ), &
956 & Ta(i ,j ,k )*mask_min(i ,j ),Tadv(i ,j ,k) &
957 & *mask_min(i ,j ), &
958 & Ta(i+1,j ,k )*mask_min(i+1,j ),Tadv(i+1,j ,k) &
959 & *mask_min(i+1,j ), &
960 & Ta(i ,j-1,k )*mask_min(i ,j-1),Tadv(i ,j-1,k) &
961 & *mask_min(i ,j-1), &
962 & Ta(i ,j+1,k )*mask_min(i ,j+1),Tadv(i ,j+1,k) &
963 & *mask_min(i ,j+1), &
964 & Ta(i ,j ,k-1)*mask_min(i ,j ),Tadv(i ,j,k-1) &
965 & *mask_min(i ,j ),&
966 & Ta(i ,j ,k+1)*mask_min(i ,j ),Tadv(i ,j,k+1) &
967 & *mask_min(i ,j ))
968 cff2=Ta(i ,j ,k )*MAX(0.0_r8,Ua(i+1,j ,k ))- &
969 & Ta(i ,j ,k )*MIN(0.0_r8,Ua(i ,j ,k ))+ &
970 & Ta(i ,j ,k )*MAX(0.0_r8,Va(i ,j+1,k ))- &
971 & Ta(i ,j ,k )*MIN(0.0_r8,Va(i ,j ,k ))+ &
972 & Ta(i ,j ,k )*MAX(0.0_r8,Wa(i ,j ,k ))- &
973 & Ta(i ,j ,k )*MIN(0.0_r8,Wa(i ,j ,k-1))
974 beta_dn(i,j,k)=(Ta(i,j,k)-Tmin)/(cff2+eps)
975 END DO
976 END DO
977 k=N(ng)
978 DO i=I_RANGE
979 Tmax=MAX(Ta(i-1,j ,k )*rmask(i-1,j ),Tadv(i-1,j ,k ) &
980 & *rmask(i-1,j ), &
981 & Ta(i ,j ,k )*rmask(i ,j ),Tadv(i ,j ,k ) &
982 & *rmask(i ,j ), &
983 & Ta(i+1,j ,k )*rmask(i+1,j ),Tadv(i+1,j ,k ) &
984 & *rmask(i+1,j ), &
985 & Ta(i ,j-1,k )*rmask(i ,j-1),Tadv(i ,j-1,k ) &
986 & *rmask(i ,j-1), &
987 & Ta(i ,j+1,k )*rmask(i ,j+1),Tadv(i ,j+1,k ) &
988 & *rmask(i ,j+1), &
989 & Ta(i ,j ,k-1)*rmask(i ,j ),Tadv(i ,j ,k-1) &
990 & *rmask(i ,j ))
991 cff1=Ta(i-1,j ,k )*MAX(0.0_r8,Ua(i ,j ,k ))- &
992 & Ta(i+1,j ,k )*MIN(0.0_r8,Ua(i+1,j ,k ))+ &
993 & Ta(i ,j-1,k )*MAX(0.0_r8,Va(i ,j ,k ))- &
994 & Ta(i ,j+1,k )*MIN(0.0_r8,Va(i ,j+1,k ))+ &
995 & Ta(i ,j ,k-1)*MAX(0.0_r8,Wa(i ,j ,k-1))
996 beta_up(i,j,k)=(Tmax-Ta(i,j,k))/(cff1+eps)
997 !
998 Tmin=MIN(Ta(i-1,j ,k )*mask_min(i-1,j ),Tadv(i-1,j ,k ) &
999 & *mask_min(i-1,j ), &
1000 & Ta(i ,j ,k )*mask_min(i ,j ),Tadv(i ,j ,k ) &
1001 & *mask_min(i ,j ), &
1002 & Ta(i+1,j ,k )*mask_min(i+1,j ),Tadv(i+1,j ,k ) &
1003 & *mask_min(i+1,j ), &
1004 & Ta(i ,j-1,k )*mask_min(i ,j-1),Tadv(i ,j-1,k ) &
1005 & *mask_min(i ,j-1), &
1006 & Ta(i ,j+1,k )*mask_min(i ,j+1),Tadv(i ,j+1,k ) &
1007 & *mask_min(i ,j+1), &
1008 & Ta(i ,j ,k-1)*mask_min(i ,j ),Tadv(i ,j ,k-1) &
1009 & *mask_min(i ,j ))
1010 cff2=Ta(i ,j ,k )*MAX(0.0_r8,Ua(i+1,j ,k ))- &
1011 & Ta(i ,j ,k )*MIN(0.0_r8,Ua(i ,j ,k ))+ &
1012 & Ta(i ,j ,k )*MAX(0.0_r8,Va(i ,j+1,k ))- &
1013 & Ta(i ,j ,k )*MIN(0.0_r8,Va(i ,j ,k ))- &
1014 & Ta(i ,j ,k )*MIN(0.0_r8,Wa(i ,j ,k-1))
1015 beta_dn(i,j,k)=(Ta(i,j,k)-Tmin)/(cff2+eps)
1016 END DO
1017 END DO
1018
1019 DO k=1,N(ng)
1020 DO j=J_RANGE
1021 DO i=I_RANGE
1022 if (rmask(i,j).lt.0.5) then
1023 beta_up(i,j,k)=2.0
1024 beta_dn(i,j,k)=2.0
1025 endif
1026 END DO
1027 END DO
1028 END DO
Adil Sozer (Phd student)
Metu Institute of Marine Sciences, Turkey
