coupled ice options
coupled ice options
I thought it might be a good idea to list current and future ice options for use with the ROMS model to try to limit the duplication of effort. Please add anything you know of too!
1. We have Paul Budgell's ice (EVP on an Arakawa C-grid, Mellor-Kantha thermodynamics). It is working with the bulk flux option, available to the daring. It is using a tight coupling, same grid and timestep for both models.
2. This summer we hope to get help from the CCSM team to put ROMS into that coupled model framework, so that ROMS would be an option along with POP, the ice, land, and atmospheric components. It would be a loose coupling, making different grids possible.
3. Jia Wang's group at IARC is exploring a loosely coupled ROMS-CICE model for their Arctic research. They are still at the stage of investigating the couplers.
4. I heard that Cecilia Bitz is helping someone with ROMS-ice and have written to ask for more information.
Btw, Hibler's latest thing is having ice that is embedded in the ocean rather than floating up in the atmosphere. I should probably go find out more about that.
CICE sea ice model
Sinan Husrevoglu (sinan@ccpo.odu.edu) has coupled CICE to roms. He is running cases for our Ross Sea domain. We hope to also use this model for the peninsula domainl. He should be finished with his dissertation work sometime this year.
At the moment, the model is running. Sinan had a poster at the recent Ocean Sciences meeting. We are trying to make sure the model works realistically.
Once we are sure that this is working ok, we plan to send the changes to Hernan so it can be part of the distribution.
John
John
Re: coupled ice options
Bump.
Has anyone tried to couple CICE 4.0 to ROMS? Or is someone perhaps contemplating doing so?
I saw a poster today by a student (Kyle Armour) working with Luanne Thompson and Cecilia Bitz at UW that uses ROMS, however, the ice model and coupler is not one that has been discussed here. The application described in the poster is the Sea of Okhotsk.
Bump again. Does anyone know of successful efforts to couple CICE and ROMS? Some of those mentioned in this post seem to have faded away.
It's one of my unfunded back burner projects. I could probably whip it out in a week based on Cecilia's fake coupler if I needed to.
What troubled me for a long time was that how to turn on or buildup a coupling to ice model(CICE etc) in a ROMS run. I have successfully achieved a quarter-resolution simulation of Southern Ocean(30S-75S) without coupling to a ice model, whcih may cause much deviation to real ocean state. My ROMS trunk version is 751. Thanks for any following responses very much!
![Wink :wink:](./images/smilies/icon_wink.gif)
Hernan is working on the coupling to CICE and other models via NUOPC caps. You'd have to ask him where that stands.
The Norwegians are running a ROMS-CICE coupled system (via MCT) which they have put out on github, called metroms.
