Hi All,
Should the occurence of ncid1 in lines 805 and 812 be ncgrd instead? Had to make this change (and a few additions to hbackground.F for ncl 5.2.0) in order for stuff to work.
On a kind of related note is there a ncl-ized versions of matlab set_depth and stretching functions. Or maybe an example of how to make a plot of say temperature and interpolated depth of 100m using ncl.
Simon.
Possible bug in roms-plot/src/Utility/opencdf.F
Re: Possible bug in roms-plot/src/Utility/opencdf.F
Yes, good catch. Thank you for reporting this typo. I updated the plotting repository.
I haven't downloaded a new version of the NCAR's GKS library in long time. It is annoying the they change things in this legacy library and it is not backward compatible. I have struggled with their changes to the internal common blocks for years.
Please send me you modified hbackground.F to see what do they changed this time. I have several CPP flags in the makefile to control these changes according with the libary version. It seem that the last one that I did was for version 4.4.1.
Hi Hernan,
Attached should be my modified hbackground.F, following the convention have added tests for NCARG520.
Simon.
Simon.
hbackground.F
- modified to test for NCARG520
- (32.08 KiB) Downloaded 442 times
Great, thank you. I updated the plotting package. See
ticket for more information.
